Hv battery exhaust tube missing
Discussion in 'Gen 2 Prius Technical Discussion' started by Aaron Vitolins, Sep 13, 2015.
  1. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Hey everyone, I've had my prius for 18 months now, it has 267,000 miles. in january i replaced my hv battery at 238,000 miles due to the fact it had lowered battery capacity, and that i got a great deal on a used hv battery from a wrecked 08 Prius.
    Well ever since I've owned this car the exhaust vent tube coming from the battery that vents hot air out to the passenger side rear finder is missing. Should i look in to finding that part. like is it even worth it?
    I guess I'm just trying to plan for the long run with this newer battery.
    It kinda makes me wonder how long that part has been missing, like how many years?? or if that could have possibly affected my previous battery capacity, since being subject to soaking in heat isn't good for the battery.
    What do y'all think? Thanks everyone :)
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Maybe a previous owner left it off when changing the 12 volt?
  3. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    I would definitely get one. I would probably try to find one from a salvage yard or off a wrecked car. No telling what Toyota would want for it.
  4. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    That's what I think too. It has an optima battery that seems pretty old (judging by the dust, and performance, about 12.3 volts nowdays)
  5. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    I'm still kicking my self for not buying the one out of the wrecked out.. I wasn't even thinking about it. They probably would have given it too me free aswell :( I think I will start looking for one now
  6. Patrick Wong
    18,204
    6,505
    #6 Patrick Wong, Sep 13, 2015
  7. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Is it true then gen 3 got rid of this tube? Maybe I'm wrong, but if so that would seem very odd of toyota
  8. bisco
    51,895
    maybe if it's vented to the 12v area, it has to leave via the fender grille.
  9. Mendel Leisk
    41,401
    On 3rd, there's tight ductwork from inlet to fan to battery, and on the far side just a short duct dumps air into the underfloor air pocket: from there on its just open. There's flap equipped air outlets at both back corners.
    #9 Mendel Leisk, Sep 13, 2015
  10. Patrick Wong
    18,204
    6,505
    I misunderstood your OP. You are referring to the duct that routes hot air from the traction battery to the area where the 12V battery is located - not the duct that provides air from the passenger compartment.
    The absence of that duct probably will slightly impair battery cooling, to the extent that a small vacuum is created when the car is in motion and can help suck air out of the exhaust duct. It probably is not the end of the world to have that duct missing though.
  11. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Thanks guys! I guess I'll look for one at some local salvage yards. I like to think I'm keeping my battery cool as possible
  12. dorunron
    3,318
    1,105
    Houston, TX
    If you do find it, try to get the fastener's at the same time.
    In the end, the car should look like this.
  13. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Thank you! Maybe I should just rob my sisters Prius for the parts? Lol :D
  14. dorunron
    3,318
    1,105
    Houston, TX
    If you can live with your conscience... Surely though you are just joking.
    All the best to you.
  15. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Thank you, and yes I'm joking! :).
    I'll update this thread if I get the part
    m.wynn and dorunron like this.
  16. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    Have a little ghetto fun and fab your own out of, say, cardboard and duct tape...
    I agree with Dr. Wong, and lean even more in the direction of thinking that thing has little to no effect on battery temp.
    Aaron Vitolins likes this.
  17. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    I agree. The only time it might actually make a difference is on a long road trip, because of long running time it could possible warm up everything under there after hours of warm air blowing around under the cargo floor. Still not too big of a deal
  18. Mendel Leisk
    41,401
    Strange, 3rd gen has dispensed with that exit duct, just dumps the air and counts on it to meander across the space and out the two exit ducts. Whenever the battery fan's running there's increased air pressure, to make this happen.
  19. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Odd. Some taxi drivers seem to think thats why the gen 3 battery doesn't last as long as a gen 2 taxi. Who knows!
