Equal tire pressure?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LDB, Sep 17, 2015.
  1. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    Anyone running the same tire pressure in all 4 tires? Just curious about the 2psi differential and how important it may or may not be.
  2. xliderider
    xliderider Senior Member
    8,131
    3,268
    Honolulu, HI
    The rear is much lighter than the front end. It makes sense to have a lower pressure in back.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    928
    Monument, CO
    If you look at the door jam sticker for axle limits, you will see the front axle is rated at 2270 lbs and the rear 2175 lbs. So the front axle supports about 95 pounds more than the rear, thus the justification for adding 2 psi to the front tires.
  4. Mendel Leisk
    40,975
    I run the same pressure on all four tires, no issues. Been driving FWD (Honda) vehicles since the early '80's, they're always front-heavy, and this is the first car I've seen where they spec a lower pressure in the rear. My main motivation for setting them the same is to avoid the need to adjust them when rotating.
    Plus, I've got so much junk in the underfloor tray, maybe it all balances out, lol.
  5. LDB
    LDB Member
    279
    71
    ^^^^ That is exactly what I was thinking. I originally went 39/37. I think I'm going to go 40/40.
  6. Mendel Leisk
    40,975
    With our original low profile 17" I set them around 34~35 psi all around, higher is too rough. With our 15" snow tires higher pressures don't seem to affect the ride feel that much, so I use around 38~40 all around.
    I'm a little conservative on pressures: I've been finding little difference in mpg with higher pressures, and keep thinking higher is rougher on the suspension.
    For reference:
    #6 Mendel Leisk, Sep 17, 2015
  7. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I am setting them 37 front 35 rear.
    Adjusting them after rotation is not a big deal for me compared to the rotation itself (PiP comes with no spare but I have a donat one.
    Euro PiP spec is BTW 35/34.
  8. qdllc
    qdllc Senior Member
    1,375
    400
    Equal pressure all around.
    The only vehicle I've had where I'd justify less pressure in the rear is a pickup truck that's normally driven unloaded. Makes a difference on wet and slick roads when braking and accelerating (rear-wheel drive only).
  9. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    The 2lb difference probably makes no difference, except perhaps when you are in a critical crash avoidance maneuver when you need every ounce of traction, then maybe a difference. I follow Toyota's recommendations, I think their engineers know a bit more than I do about handling...........
    #9 Munpot42, Sep 17, 2015
  10. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    My goal is for the same pressure all around. If they are within a pound or so of max sidewall that is good enough. The tires on the sun side of the car are going to be 1+ psi higher than those on the shade side.
