VW Faces $17B Fine for Emissions Scam
Discussion in 'Environmental Discussion' started by Jeff N, Sep 18, 2015.
  1. mikefocke
    3,997
    1,807
    Sanford, NC
    The US penalties are the tip of the iceberg.. Added attention to 2016 models tests, civil lawsuits relating to the performance of the cars after they are recalled/fixed and over false advertising, criminal penalties, etc are all going to trickle out and damage the VW group's reputation. OTOH, they could accelerate the group's shift to alternative fuels or electrics.
  2. austingreen
    austingreen Senior Member
    13,672
    4,210
    Austin, TX, USA
    Like I said if it's US only the hit is overblown. If it damages them in Europe and/or China then the stock will keep falling. VW was not doing well before this scandel.
    Volkswagen has massive sales problems in America - Business Insider
    Most of the audi and all the porsche are gasoline, so I don't think this will hit those brands. The history of vw is not good. I think the CEO was probably going before this, and my guess is he took the blame because he should have known this was happening. That is inexcusable.
  3. bisco
    51,920
    are we sure other diesel mfg.'s aren't gaming the system? i hope all vehicle models were checked.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Volkswagen’s dirty mission: Where’s the beginning and where’s the end? | Ars Technica
    "But it is not just emissions compliance that's under the microscope here. If—and that’s a big if—VW is allowed to repair the affected cars in the US market through a recall, it is virtually assured that the label values for those vehicles' fuel economy ratings will be void. VW will have therefore effectively falsified the EPA mileage ratings of 482,000 cars. And that may be more than just an EPA issue. It may involve the Department of Commerce."
    cwerdna likes this.
  5. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Don't overlook the long term implications of this VW admission. Diesels meeting future emission standards will be really complicated engine systems. That complexity may be the real worry for diesel proponents.
    GrumpyCabbie likes this.
  6. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  7. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    Troy!
    What's the German for Schadenfreude?
    Volkswagen US CEO Michael Horn admits carmaker 'totally screwed up' after emissions scandal - ABC News (Australian Broadcasting Corporation)
    bwilson4web likes this.
  8. bwilson4web
    16,212
    No correction, yet: Steenman: Portland Green Test Drive. What we did and why we did it. | Steenman Associates
    The Green Human team drove a 2009 Clean Burning Diesel Jetta and a 2008 Toyota Hybrid across the country almost 8,000 through a wide variety of terrain and conditions from Portland, Maine to Portland, Oregon via the Eastern seaboard, Florida and Colorado.
    Our goal was not to repeat previous tests, nor to challenge previous results. There are already lots of reviews and stats on each vehicle which anyone with an internet connection and enough time on their hands can read and use to support their own conclusions. We chose instead to do an “experiential” experiment where our objective was to intensively drive and experience the cars in a real world environment traveling a significant distance over a relatively short time.
    The original stunt:
    • 'cheated' EPA numbers 3x, now known to be 10-40x worse
    • ~64% of survey users chose Prius
    His business model is "A FULL SERVICE ADVERTISING AGENCY AND DIGITAL SERVICES FIRM." The only remaining question is credibility.
    usbseawolf2000 and telmo744 like this.
  9. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    usbseawolf2000 and cwerdna like this.
  10. godzillaismad
    godzillaismad Member
    199
    94
  11. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Klasterfukk
    This is probably on the minds of many vw owners and employees
  12. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    #212 GrumpyCabbie, Sep 22, 2015
    usbseawolf2000 and austingreen like this.
  13. godzillaismad
    199
    94
    Down another 23% today, so 43% in total over the past 2 days! Das Kaput Auto!
  14. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    We had to endure "clean" diesel spin for years. They knew gas hybrids offered greater potential, yet the rhetoric continues on anyway. Sadly, some has continued on even after being exposed for not being as clean as claimed. We knew that the "clean" claim was misleading right from the start. That simply meant it met minimum requirements. Exceeding them, as the SULEV & PHEV rating indicate, was certainly not what "clean" diesel delivered. It basically just made diesel vehicles like ordinary gas vehicles. No one imagined the "clean" level wasn't achieved either.
    What we want is significant improvement. Watching Toyota push into new territory with gen-4 Prius should serve as inspiration for others, not result in more undermining. That potential should be obvious. Adding a plug to Prius pushes it far beyond what diesel could aspire to. Even with the current 4.4 kWh battery-pack, there's no match with either efficiency or emissions... not even close.
    Put simply, diesel shouldn't be used for passenger vehicles anymore, just like our effort with hybrids to end the production of traditional vehicles. Offering viable hybrids is the key. Keeping our air clean and relying less on oil is a big deal. Having learned there are some who don't share those values and caused harm on an epic scale should help us all take that next step.
  15. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    I agree the overall implication turns out USA went with the correct cleaner fuel (gasoline vs. diesel), despite all the past rhetoric that Europe/diesel was the correct path. One problem for Europe is the diesel preference goes hand-in-hand with a refinery system that does not make as much gasoline. Assuming EU would probably rather fight than switch to gasoline, EV may indeed be popular there as a diesel alternative.
  16. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    Next car we "might". The trouble with Mazda that we have, is strictly dealer-related. Not the greatest dealer network around, but the only one locally I've had great dealings with is Toyota. I know that it's different everywhere, but many of our local dealers are not the greatest. I have family that takes Hyundais and other makes to the Toyota dealer for service and estimates.
    Currently, the Mazda 3 and the Mazda 6 are on the potential list, and it's not a huge list either.
  17. E Risch
    E Risch Junior Member
    49
    Nashville
    EPA threatens astronomical fines, lawyers get involved, Yota pays a few million and plants some trees. 15 years later it is all but forgotten. Yota is the #2 ranked manufacturer. In VW's case its years from the outcome, and the facts as to what VW/EPA/WVU/or the Feds fault is yet.
  18. HGS
    HGS Member
    307
    123
    We are at a transition period where EV, Hybrid, fuel cell, and diesel are the possible future majority. It will take decades to fully transition away from ICE only cars. Who will dominate in 25 to 50 years? I seriously doubt it will be diesel.
    #218 HGS, Sep 22, 2015
  19. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    On the one hand I can't help but feel sorry for so many who were duped into believing the "Clean Diesel" hype and bought a VW Diesel thinking they were doing something positive.
    On the other hand I can't help but go
  20. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    I moved from a Mazda3 hatchback to the Prius 3. The reason I did so was the solar roof option. The M is a great car. I had the 2.0L i Grand Touring automatic. It was good on fuel, around 30-31mpg in all local short trips and 40-42 on the highway. The Prius beats those numbers by a huge margin of course and although tape measure numbers suggest differently it feels much roomier as well. That solar roof is the best thing since sliced bread though.
