2nd Gen Main System Relay Open
Discussion in 'Gen 2 Prius Technical Discussion' started by Michael Szatmary, Sep 21, 2015.
  1. Michael Szatmary
    Michael Szatmary Junior Member
    Denver, Colorado USA
    2005 Prius USA. Just finished reconditioning HV battery pack at 136K miles, definitely had one very bad module and one that was questionable. Replaced both modules and ran every module through 5 charge/discharge cycles using Hitec X4 ACplus chargers #44167. Then wired all modules in parallel and let equalize for 24 hours. Battery pack looked perfect with all modules within .01 volts, approx. 7.98 volts per module and 223.7 volts at the input side of the main relays. Installed battery pack in car and main system relays will not close when I try to start car. Prior to HV battery reconditioning car would start, main relays would close. Did no other work on car but remove and reinstall HV battery pack. Completely disconnected 12V battery to clear all error codes prior to reinstalling HV pack. With HV pack installed in car and safety switch installed ON, I still read 223 volts at input side of relays, removed cover for access. What will keep these relays from closing when start button is pushed? What should I try next?
    52,275
    did you slide the main orange battery switch all the way up after closing it?
  3. Michael Szatmary
    Yes, slid the orange switch all the way up and verified it connected by measuring voltage at input side of main system relays. I have 223.7 volts at the relays but they do not close when I try to start the car.
  4. Patrick Wong
    18,210
    6,511
    Time to get Mini VCI so that you can retrieve the DTC. Maybe the traction battery ECU has a fault or there is a problem with the wiring to the system main relays, which results in the relays not closing when they should.
  5. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    Battery computer connection to car? , double check those low voltage connections
  6. ChapmanF
    18,451
    The computer is what commands the SMR to close. The answer to why the SMR isn't closing (barring some dead simple explanation like you left the wires unattached) is ... whatever the computer is detecting so it decides not to close the SMR.
    In other words ... read the codes.
    -Chap
  7. strawbrad
    strawbrad http://minnesotahybridbatteries.com
    953
    1,007
    Up ???????????????
    Inserting the orange safety disconnect takes three distinct movements.
    1. Push the plug in.
    2. Flip the lever up.
    3. Push the level straight down.
    Step three closes a 12 volt micro switch. This circuit lets your car know the plug is in place. The main relays will not close without this circuit being complete.
    Brad
    Xavier75 likes this.
  8. Michael Szatmary
    I am putting the HV pack back into the car now. I don't think I did the third operation of pushing the lever straight down to engage the micro switch but I will know shortly if that was indeed the problem. Thank you for the response it is always the really simple things that get you.
  9. bisco
    52,275
    right, when i said up, i had my laptop upside down.(n)
  10. techntrek
    techntrek Member
    263
    84
    MD
    I agree that last step is likely your problem. I've experienced the same thing - although I thought I also triggered the red triangle as a result.
  11. Michael Szatmary
    That was the problem and yes the red triangle along with every other light was lit on the dash, I assumed I got all of the lights on since the relays weren't closing. Thanks again, took car out for short test drive and it is running great.
    ftl likes this.
  12. bisco
    52,275
  13. xdimsum
    xdimsum New Member
    Long beach
    Hi all,
    I know this is an old post. But I am having similar problems as OP. I just replaced my hybrid battery and after reinstalling the car does not start, only dashboard, warning signs, radio and lights turn on. Cannot put in drive or reverse. I realized I did not click down on the orange plug to lock in place, so I did that but it still won't start. I have tried disconnecting 12V Aux battery to clear codes but that didn't work either. Tried clearing codes using Blue Driver OBD2 and that didn't help, warning signs come back instantly.
    I was able to gather some codes from the OBD2.
    Hybrid Control Codes:
    1) P0AE7: HV Precharge Contactor "A"
    - looked online and some people have mentioned replacing the system main relay
    Gateway code:
    2) B1271: ECU combination stop
    - looked online and some people have replaced ECU
    Just wondering if any of you folks have experienced this same issue.
    I will try checking the continuity of the relays and check if any contacts were damaged or corroded and let you guys know if failure still occurs.
  14. dolj
    dolj Senior Member
    8,516
    4,322
    Wellington, New Zealand
    Check you installed the safety interlock correctly, most importantly the third step to push the handle down till it clicks in.
    If this is all ok, check you connected the thin wire to the connector below the interlock.
    Let us know if this fixes it.
  15. xdimsum
    xdimsum New Member
    Long beach
    So damn HAPPY right now! I was so close to giving up, I even went to the dealership yesterday to get a quote for repairs. But finally, after 3 weeks of struggling i got the car to start! And im so pissed that it took me this long to figure it out. This whole time it was one of the green wires connected to the precharge relay. I checked every wired connection tonight and this one was loose and the pin was actually bent! And not directly connected even though it looked like it. As soon as I fixed the pin and plugged the wire in and cleared codes, the relay switched on and car started!
    Attached is a picture of the green wire, not exactly sure what the wire is but my guess is that its a neutral wire because its green?
  16. tallman
    tallman Junior Member
    60
    wv
    Having similar problem only getting 11.2 volts and to traction battery relays, 12 volt battery is up , need to check relay for this in front power box if that is where it is and I can find it!
