Need suggestions for a portable 12 volt air compressor to take on roadtrips.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Priusguy78213, Sep 22, 2015.
  1. Priusguy78213
    Priusguy78213 Junior Member
    94
    30
    San Antonio, TX
    I'm getting ready to do some pretty long road trips and going down the checklist to make sure I've got a good emergency kit in place. I've got the basics; portable 12 volt booster pack, extra oil, water, toolkit, etc. But I'm looking to get a small, light weight portable 12 volt air compressor to store onboard in case needed. Any suggestions? And probably an odd-ball question but does anyone know the amps on the 12 volt sockets in the 2013 Prius? I've looked at a few compressors and some specify that they need to be used with 15 amp 12 volt sockets. Not sure if that's something that would be specified in the owner's manual or not. Any ideas on that and suggestions on a portable compressor would be appreciated.
  2. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    I think I remember the 12V socket being limited to 10 amps, which is why I never bought a compressor. Most compressors run at 15 amps, and anything less would operate really slowly. So, I bought a foot pump and called it a day.
  3. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    For what purpose do you need the 12V compressor? There are various sizes for various pressure or volume applications.
  4. Priusguy78213
    94
    30
    San Antonio, TX
    Just to pump up a tire if need be.
  5. mrbigh
    3,686
    699
    Long Island, NY
    a foot pump will do the job ....
    Priusguy78213 likes this.
  6. jdonalds
    541
    225
    Well here is one, not too small, but priced right.
    I think I'd be tempted to go with a simple method and throw in a bicycle hand pump. While I don't want to be without a spare tire I only have a flat every 4 to 5 years. I would think a hand pump, although a lot of effort and slow, would provide a temporary solution in some cases. It would be light weight, small, and cheap.
    I presume your car does not have a spare tire or this subject wouldn't have come up.
    #6 jdonalds, Sep 23, 2015
  7. qdllc
    qdllc Senior Member
    1,377
    400
    Honestly, I got a 12v "bike pump" from WalMart for my motorcycle, and it does great on a motorcycle battery WITHOUT the engine running. At worst, you might need to by a 12v cord extension since you only get a couple feet of cord with the pump itself.
    More money for a better pump would only be warranted if you were going to use it a lot.
  8. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
  9. Mendel Leisk
    41,804
  10. TRUC NGUYEN
    TRUC NGUYEN Junior Member
    2014 Prius Plug-in
    Try this
    eBay item number:
    331661791665
    Dylan Doxey likes this.
  11. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    I have this one here/
    $42.-
    more than happy with it/
    #11 StarCaller, Sep 24, 2015
  12. Stevevee
    821
    224
    Vermont
    I have an older version (probably 6-7 years old now), of the Sears DieHard Platinum Portable Power 1150. Portable power for jump starts, compressor, gauge and tire pump. It also serves as an inverter. Holds a charge for a very long time, and saved me out on the lake a couple of times. Kind of hard to carry around all the time, but I'd definitely prefer a device like that to one that had to be plugged in to work.
  13. Mendel Leisk
    41,804
    I've got a jump pack without compressor, but good power and a 12 volt outlet. Guess I could use a 12 volt compressor with it.
  14. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    We have this:
    Very quiet and capable.
  15. dandeman
    dandeman Junior Member
    61
    Chapel Hill, NC
    www.amazon.com/s/?ie=UTF8&keywords=jump+n+carry+jnc660Highly recommend the Jump and Carry at this link..
    I have one and have used both the battery jumper and, the tire pump to save the day with the Prius.. My other primary vehicle is a Toyota 4Runner with onboard air compressor and dual battery system..
    I don't even think of taking long trips with the battery and tire pump backup as those two items are the most common on the road issue.
