If you've lowered your Prius, then this thread is for you...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by JFrentzen-closed, Jun 29, 2012.
  1. E46Prius
    E46Prius Active Member
    314
    220
    Costa Mesa
    ^Thanks for posting that. I may consider the TRD springs. I wish the drop was slightly less than 1.2" maybe .95 or something. But that's fine I guess. I want it slightly lower but want to retain a professional adult look.
    I'm glad the alignment doesn't really change with such a small drop. makes sense though. otherwise you'd need an alignment every time people sit in the car. 1" shouldn't really cause anything given a good installation. As long as my car drives straight, i'll probably skip the alignment (if I install TRD springs)
    I wonder if Toyota has spring pads you can buy? In the BMW world, BMW offers many various thickness of spring pads so you can adjust your ride height to your hearts content =)
  2. Xterra72
    Xterra72 Senior Member
    1,437
    1,683
    Modded "STOCK Looking" Prii sitting on TRD Springs.
    #162 Xterra72, Sep 21, 2015
    saulbassfan likes this.
  3. l1tch1
    l1tch1 New Member
    sacramento
    Hey guys, this is my first post. I just recently bought a 2015 Prius three. i want to lower the car all around maybe 1". In the past I have done this to my rsx and 335i via springs only and end up having to get a camber kit because my tires were butterflying. Will i have the same issue with just going with springs on the Prius? i don't want to have worn out tires due to lowering the car. or should i invest in coil-overs? Thanks.
    #163 l1tch1, Sep 23, 2015
  4. Xterra72
    1,437
    1,683
    TRD springs made to work with stock shocks. Barely affected alignment. Tires wearing out evenly.
    l1tch1 likes this.
  5. l1tch1
    l1tch1 New Member
    sacramento
    thanks for the input. where is the best place to purchase these? any recommended sites? i'm assuming dealership are marked up too high.
  6. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    There's quite a few people selling them in the Private Sales section for like $100. If you want a new set, I've seen them on Amazon for around $150 on lucky days.
  7. jepsprius23
    jepsprius23 Member
    77
    78
    orange county
  8. HelloHybrid
    482
    1,483
    Dylan Doxey, Burna J and SubCode like this.
  9. jepsprius23
    jepsprius23 Member
    77
    78
    orange county
    lol, no its perfect, im thinking of lowering it more:))
  10. markg1018
    markg1018 Junior Member
    22
    South Bay
    Is that a painted oem lower door molding?
    Salamat!
  11. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    When lowering a car, let's say 1.5 inches, would 18 x 8" rims and tires 225/40/18 fit without issue/rubbing?
    The ET on the rims are 35.
    Plug and play or need spacers, etc.? Tires not too wide so it will still be within the fenders?
    Thanks Ina advance.
    Sent from my
  12. Tcortez
    Tcortez Junior Member
    25
    42
    Lancaster
    image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg Lowered my car on Tein springs 1.5 inch drop , the ride quality is almost like oem I can't tell. When I make turns it feels sportier the body roll is gone. Here is a before and after pick with my new wheels image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg
    #172 Tcortez, Jan 1, 2016
  13. Drewintoledo
    Drewintoledo Junior Member
    49
    Ohio
    2015 Prius v wagon
    Has anyone noticed an improvement after lowering? This appears that it would be a practical method to reduce drag.
  14. SubCode
    SubCode Senior Member
    739
    1,341
    Actually I only notice the look of the car IMHO ...drivability steadier in the turns..
    Xterra72 likes this.
  15. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    I noticed a slight jump in my MPG after I installed the TRD springs -- about a 2" drop.
  16. Burna J
    1,071
    3,340
    53
    Long Beach, CA.
    Yes sir.... It improves the looks.
    Nothing else matters.. :):LOL::ROFLMAO:
    Starbrand, Dylan Doxey and Xterra72 like this.
  17. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    Tein H-techs. Put them in around 15k miles or so? I'm at 67200 and still on original struts/shocks. OEM tires went at 35k and the new ones are still going strong with maybe 1/32 discrepancy from outer to inner tread. Running 40/38 in summer and 38/36 winter.
    [​IMG][​IMG]
    #177 sdtundra, Jan 2, 2016
  18. SwamppThingg
    SwamppThingg Active Member
    235
    443
    Mount Prospect, IL
    What size are those new wheels?
  19. sdtundra
    1,314
    193
    Sacramento, CA
    They're 17 inch on 215/45r17. Stock wheels from a first gen scion tc.
  20. SwamppThingg
    235
    443
    Mount Prospect, IL
    That's where I've seen them before...
    I've seen a few sets for sale on craigslist near me.
    I like the look more than I thought I would.
    Might have to consider it.
