RainEx Haze Removal?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusDad, May 1, 2006.
  1. PriusDad
    PriusDad New Member
    48
    So I decided to RainEx the windows on our new Prius, but I've come to regret that decision. There is now a hazy film that's especially noticable when driving into the sun. The odd thing is, I've never seen this on our other cars.
    In any case, I can't seem to get the darn stuff off the windows, now that it's on there. Does anyone have any suggestions for removing the RainEx haze from car windows?
    Also, is there some other product that repels water and protects the windows like RainEx does, but doesn't leave that hazy film?
    Thanks,
    Peter.
  2. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    PriusDad - RainX
    I've been using RainX on my 06 windshield for 5 months without any problems. Did you perform the last step and wipe off the dried haze with a sprinkle of water and a paper towel?
    I clean my windows with Hope's Perfect Glass and a cotton towel and I use the dry side of the towel to clean off any streaks. Are you sure the haze isn't on the inside of the windshield?
    Hope this helps.
  3. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(PriusDad @ May 1 2006, 01:49 AM) [snapback]247822[/snapback]</div>
    To get Rain-X off (or anything else that's stubborn) I use a glass polish. You can get this from Zaino Brothers or from Griot's Garage. Griot's used to have a mild and more agressive formulation. I have also seen Clay Bar recommended in Audi service bulletins - they say to not use it on paint after using it for glass.
    I gave up on Rain-X a few years ago when I discovered Aqua-Pel from PPG. It seems to last a lot longer and doesn't have as much haze left behind by the wipers in light rain. I can get away with putting it on twice a year. I have had Rain-X seem to wear out after only a day or two of all-day driving in the rain on a long trip.
    I have noticed that the windshield of the Prius seems to have a layer of quiet air on it that doesn't drive off the water when you are using Rain-X or Aqual-Pel. On other cars, the wind sluices the water droplets right off and you hardly need the wipers. This seems to not happen as much on my 2006 Prius.
    - Tom
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I like Rain-X and haven't had any trouble with it wearing off unless I go through a car was or something.
    I find that it takes some agressive rubbing to get the haze completely off, and almost without fail I'll have some spot that just doesn't quite get cleared up. But by the first rain it clear itself.
  5. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    i clean the windshields with stoner's invisible glass, apply rain-x, and clean again with the invisible glass. i also clean the inside of the front windshield with invisible glass. works great for me and i'm really picky about windshield clarity.
    the raindrops bead up and fly right up and off to the side on my 05, i haven't had any problems with that at all. i reapply every 4-6 months.
  6. PriusDad
    PriusDad New Member
    48
    <div class='quotetop'>QUOTE(efusco @ May 1 2006, 05:50 AM) [snapback]247885[/snapback]</div>
    Believe me... I've rubbed and rubbed and rubbed. It looks from the outside like the window is absolutely clear.... no streaks... but when I'm inside, and daylight is shining through (especially if the sun is towards the front), I see this milky, streaky haze. Bugs the heck out of me.
    Peter.
    <div class='quotetop'>QUOTE(Vincent @ May 1 2006, 03:05 AM) [snapback]247857[/snapback]</div>
    I had not actually performed the last step with water, but I definitely used a paper towel. I'll have to try that. And no, the haze is on the outside. The first time I noticed it was after applying RainEx, which I only apply to the outside of the window.
    Peter.
  7. koa
    koa Active Member
    980
    45
    Hawaii
    First, make sure that haze is not on the inside of your windshield. Sometimes it's hard to tell, wipe the inside where you see it and see if it changes. If it's on the outside use a little Joy dish soap and water, then squeegee it off and buff with a cotton towel.
  8. naterprius
    naterprius Senior Member
    1,843
    Brake Cleaner. We used to use it all the time at the dealership. Spray the rag, not the windshield. Keep it off of the mouldings and the plastics!
    Nate
  9. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    You're *supposed* to take that final pass with a dry towel, which
    effectively polishes the surface of the wax that rain-x effectively
    is. Just like any other wax.
    _H*
  10. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    I think the haze IS on the inside as a previous poster has implied...
    Just got my 06 and the RAINX actually cleaned/cleared (outside) my windshield significantly. I know this because I only treat 75% of the windshield (starting from the left) so I can really see the stuff working in the rain. After I washed the car the treated portion looks way clearer/cleaner than the untreated portion.
    Also, I noticed the plastics are really emitting gases that make the inside of the windows, ALL OF THEM, hazy.
    I love the RAINX stuff, I never use the wipers.
  11. Roger3125
    Roger3125 New Member
    199
    Orange County, So Calif
    <div class='quotetop'>QUOTE(bagwell @ May 1 2006, 02:13 PM) [snapback]248077[/snapback]</div>
    OK I'll bite. What exactly does RainX do? And what about using it at home in the shower?
    Doncha loe learning about new things?
    Roger3125
  12. bagwell
    592
    49
    the woodlands, tx
    <div class='quotetop'>QUOTE(Roger3125 @ May 1 2006, 03:05 PM) [snapback]248103[/snapback]</div>
    its like waxing the windshield...airflow across the windshield blows the rain right off. Doesn't work well below 40mph....but 40mph+ you won't need your wipers.
    I've actually tried it on my shower door....but the glass was already well gone by then and it had little effect.
