GPS mounting
Discussion in 'Gen 3 Prius Accessories and Modifications' started by LDB, Oct 4, 2015.
  1. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    I've got a Garmin 3597, currently on a sandbag mount on top of the dash roughly above the right center a/c vent. I'm not interested in one of the vent mounts that somehow uses the a/c vent as I don't want anything interfering with any of the a/c trying to get into the cabin. I don't want a windshield mount as it's way beyond reach. Does anyone have a mounting suggestion other than that, hopefully with photos and/or a link?
  2. Mendel Leisk
    41,903
    This what we're doing, pretty common I think.
  3. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Have ours on the "sandbag" stuffed over in the corner very similar to Mendel's location above. Never thought to stick it to the glass like Mendel did. Have a Garmin "Nuvi". Also have the onboard Nav. Both of them can lead you to dead end's if you are not careful. :eek:
  4. LDB
    LDB Member
    279
    71
    I'm using the 12v outlet below the dash so I didn't want the cord dangling around the steering column.
  5. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    I have mine on the flip down cover for the storage area under the radio, I used double sided tape, its been there for a year..DONT STICK IT TO THE TOUCH SCREEN I have seen so many people do that
  6. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    My bag is off to the left tucked in the side window too and I'm also using the front power outlet. Any excess cable is wrapped around the mount, so nothing dangles. And since the opening is covered with cloth, you might even be able to clip it behind the dash. I didn't do that because I use the Garmin in other vehicles. There are mounts that replace the shifter knob, but then you have to look down too much for my tastes.
    Nimbus Mount Co.
  7. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Bags over on the right, a piece of wire is threaded into the vents and around the bag, works for me.
  8. LDB
    LDB Member
    279
    71
    Yeah, I don't think I'd want to have to look that far down.
  9. Xterra72
    Xterra72 Senior Member
    1,437
    1,681
    This is a GPS mount but I used it for my Scangauge II. Works very well and it's a small footprint.
    20151004_193705.jpg 20151004_193653.jpg 20151004_193634.jpg 20151004_182354.jpg 20151004_182229.jpg
  10. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Been using the beanbag for years. It works so well, I wouldn't ever think of changing it.
  11. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    I've tried suction and adhesive, but the brutal summer heat here just makes those a non-starter for me.
  12. 2015Prius2
    2015Prius2 Member
    150
    67
    I've been using the Ram Mount suction cup with xgrip for a few years now and love it, no heat issues. Just figured I'd throw it out there
    SAMSUNG-SM-N910A ?
  13. Mendel Leisk
    41,903
    Our suction cup method does let loose, maybe two~three times a year. We're low mileage and garage stored tho.
  14. E Risch
    E Risch Junior Member
    49
    Nashville
    mine sits on the little door under the radio
  15. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I have a beanbag mount tucked into the left corner sitting on a nonslip mat. The mat bonded with the dash. It isn't pretty as the power cord/antenna is plugged into the power outlet on the dash but it works. Rock solid through 35mph turns.
