Hitch Question
Discussion in 'Gen 3 Prius Main Forum' started by Redpoint5, Oct 14, 2015.
  1. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    Will a 2012 Prius V hitch fit on my 2012 PiP? I found a used one locally, but don't know if the bolt pattern is spaced the same.
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I sure doubt it, the v is a much larger vehicle
  3. Redpoint5
    1,026
    509
    Portland, OR
    I used the Amazon vehicle checking feature to see if a Curt hitch for a Prius was compatible with the Prius v, and it said it was, but I don't trust that, which is why I'm looking for someone that knows from experience. Torklift has different PN for the Prius and the v, which is why I ask.
  4. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    Call or email Torklift. They install their hitches there and should be able to tell you whether or not the hitch is interchangeable between the Prius Hatch and the V. I installed a Torklift hitch on our Prius. Excellently engineered piece and easy to install.
