Tapturn / flasher relay
Discussion in 'Gen 3 Prius Accessories and Modifications' started by sarir97, Oct 19, 2013.
  1. sarir97
    sarir97 Member
    265
    74
    Scottsdale, Arizona
    For those looking to install one of these, here's the best how-to (if I can do it, so can you):
    Push your seat all the way back and get comfortable lying on your back with your head as close to the brake pedal as you can get. Look straight up. You'll barely be able to see the relay, and it may help you to snap some pictures to orient yourself. You're looking for this (best picture of it on PC so far):
    Once you find it, the rest is done with your right hand by feel only. Feel for the tab indicated by the arrow. You'll easily be able to press the tab with your index finger. Next, grab the harness with your thumb and index finger and push UP, then squeeze the tab hard, and only then do you pull down. Do not force it. If it doesn't come out easily, try again.
    Once it's out, you'll plug in your relay single-handed (again by feel - and it can only go in one way, don't force, you'll hear or feel a click once in) and you can either tuck it in or zip-tie it securely. The space up there is pretty small so tucking it in will keep it fairly secure. Zip-tying is just extra work.
    Good luck. And kudos to Dawit for his text support.
    Colton, avusblue, Dawit and 3 others like this.
  2. xliderider
    xliderider Senior Member
    8,049
    3,219
    Honolulu, HI
    Technically, it's the connector on the wiring harness that's being released from the OEM flasher relay. Then the aftermarket flasher relay is installed onto the connector, while leaving the OEM relay in place.
    SCH-I535
    sarir97 likes this.
  3. sarir97
    sarir97 Member
    265
    74
    Scottsdale, Arizona
    Yup. Sorry my bad.
    Finished work should look like this (without zip-tie):
    Colton and Dylan Doxey like this.
  4. mrbigh
    3,686
    699
    Long Island, NY
    and ...what's the features of this "tapturn flasher"? to make it so special?
  5. sarir97
    sarir97 Member
    265
    74
    Scottsdale, Arizona
  6. mrbigh
    3,686
    699
    Long Island, NY
    Nice !!! ;)
  7. AlexT
    AlexT Junior Member
    Orlando, FL
    I know its a old thread but thanks for the link, I have VWs and Audi's and really miss the tap-lane change function, now can also have it on my Prius. Thanks
  8. WE0H
    WE0H Senior Member
    3,247
    528
    Sometimes it is good to bring an old thread back from the dead ;) I completely forgot about this. Very nice to have this feature.
    Mike :)
  9. A.Reyes
    A.Reyes Active Member
    270
    178
    Beaufort, 29902
    I've been looking for this thread forever!! Thanks for the dead bump!!
    iPhone ?
  10. DFW
    DFW Member
    39
    31
    Dallas
    thanks for the instructions. it was harder for me to see than I thought it would be.
    Thanks for the "squeeze, push, pull" instructions, that was the key!
    sarir97 likes this.
  11. 3SUIRP
    3SUIRP Junior Member
    59
    SoCal
    great upgrade for Prius! :)
    sarir97 likes this.
  12. kennie
    kennie New Member
    St. Albert
    hi guys! can anyone lead me to the site so i can order one? been looking for one of these for my '14 Prius, please??? thanks
  13. xliderider
    8,049
    3,219
    Honolulu, HI
  14. kennie
    kennie New Member
    St. Albert
    okay but i think it says for led so i have to switch to leds first for this to work?
  15. xliderider
    8,049
    3,219
    Honolulu, HI
    No, it will work for any combination of incandescent and LEDs.
  16. DFW
    DFW Member
    39
    31
    Dallas
    If you just want to stop hyper flashing (caused by lowered resistance of LED replacement bulbs), there are numerous cheap options available on eBay.
    If you want the tap, 3 blink functionality, google "tapturn relay".
    That relay comes from Canada. It took about a week for mine to arrive.
  17. kennie
    kennie New Member
    St. Albert
    awesome, thanks!
  18. DFW
    DFW Member
    39
    31
    Dallas
    np...and sorry, the link is also posted in this thread.
    orderTAP.html
