Is 12 volt light bulb discharging really bad?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tommerdoo, Jun 29, 2015.
  1. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    Hello PriusChat members, I have a question for you! I have learned an incredible amount of information from this forum since I bought my 2004 Prius two weeks ago and I'm already looking to recondition my battery as a project in the future as my traction battery is about 7 years old (according to the previous owner).
    I have SO many questions (even after reading for hours and hours all the wonderful posts that people have made) but I will start off with what I think is the most important question first.....but before I pose the question, I would like to first quote from a video by Dr. Mark Quarto from The Hybrid Shop which has a series of Youtube Q and A videos to people looking to recondition their traction battery.
    When talking about DIY'ers reconditioning their batteries, Mark Quarto says that people out there may be doing it wrong when he says...
    "They may be using 12 volt light bulbs to discharge the battery which means they're over discharging the battery and they have absolutely no idea how much capacity the battery has ... using a light bulb had been tried and has not been successful. As a matter of fact when you do the light bulb methodology you wind up hurting the cell instead of helping it. When using this method they found the pack was worse than when they started."
    My question is this: Is Mark saying that 12 volts is a bad voltage to discharge at (versus 24 volts or something?) or is Mark saying that people won't carefully monitor their voltage and accidentally drop it too low (by not stepping down the light bulbs from higher wattage to lower wattage).
    It seems that all the people in the forums here have no problem using lightbulbs as a discharge interface if watched carefully. Would a person have to watch over their voltage like a small baby in a crib to insure that it doesn't drop too low (I'm guessing there are no smart dischargers out there yet, although Jeff looks like he's building one hopefully soon).
    Thanks for your answers! I look forward to learning more from everyone here.
  2. ChapmanF
    18,537
    There are smart dischargers in the RC world. Strangely, they all have really small discharge current capacities, often much smaller than their charge capacities, so you end up watching grass grow while discharging your modules. Only reason I can imagine is they don't want to build a bigger package/load resistor/heatsink combo.
    A 12 volt light bulb under the control of a smart discharge circuit would seem to be a fine thing, and I'm not sure why I can't remember reading about any such thing.
    -Chap
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    If you're going to do something, I say do it right. You can buy programmable loads. I have some four quadrant SMU's that allow me to charge and discharge using voltage or current.
    A Keithley 2657A can do up to 3000V, source or sink. Can also do loads up to 2KW pulsed, 200W continuous.
    If you don't have the right tools, you are most likely better off just leaving the battery alone. It is not something to play with, it WILL kill you if you don't know what you're doing. High voltage DC doesn't behave as nicely as high voltage AC like in the walls. It doesn't give you an escape route 60 times a second...
  4. ChapmanF
    18,537
    That's a good old meme that keeps making the rounds, but there are a couple good reasons for trying to slow it down. It's got both of the features that can make a meme especially pernicious: (a) it has what seems like a plausible basis (the many zero crossings of 60 Hz AC), and (b) it gets the facts exactly backward.
    The reason the seemingly plausible basis doesn't actually matter is physiological: muscle fibers need more than a 60th of a second to relax anyway. Going back to 1969 work by Dalziel and Lee, it's been known that AC, in a frequency range from 10 to 400 Hz, is the most effective for putting muscle fibers into tetany ("can't let go").
    For anybody who's interested, I've done some looking around for easy-to-read papers on the various factors in electrical injury and the nicest one I've found so far is here.
    None of this is to say that you shouldn't be careful around your DC battery. You should be very careful. You just don't need to think it's any more dangerous than 200 volts AC would be.
    -Chap
  5. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    Everyone thanks for your replies. I'm looking at possibly purchasing a grid charger with discharge ready availability. My main question still stands, is discharging at a different voltage than light bulbs better, worse or doesn't matter so long as you are careful not to completely drain the battery's voltage beyond a safe limit.
    My second question is, is there any specific benefit to charging the entire pack at once versus taking the battery out and specifically charging them individually. I saw how some people had to exercise the cells more times than other cells to bring capacity up higher which would seeminly take longer to do on an entire traction battery versus individual modules. I do understand that if one takes the battery out they can identify bad cells and replace them but for the purposes of charging and discharging is taking the battery out more thorough?
    Thanks.
  6. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I really don't want to insult, please don't take it that way, but it really is one of those "if you have to ask, you probably shouldn't do it" areas.
    If you are using a standard lightbulb you are just creating a resistive load. For instance a 100W tungsten filament oldschool incandescent bulb has a resistance of about 9.5 ohms when cold and 144 ohms when hot and lit up. If the pack is 230V, you are just discharging at 24A when you first connect it to 1.6A after a few seconds. The resistance doesn't change with relation to the pack voltage, the discharge current does. As the voltage drops, the current drops for the same R. Take note of Ohm's laws: V/R = I . As V decreases and R stays constant, I must also decrease.
    So to your question of "discharging at a different voltage than lightbulbs", it doesn't make sense. You can of course discharge by using a voltage that is lower. An "infinite" amount of current will flow from the higher voltage to the lower voltage until they are at equilibrium but in practice wires and connections have resistance and then you just get melting wires as "as large a current as the copper can physically take" transfers back and forth between the 2 voltage sources until they are equal or one explodes.
    Using various wattage lightbulbs (like a 40W, 60W, 100W, 150W, etc) will adjust the R and therefore the I. Which maybe is what you were asking?
    Again, this is not a project to just try it out on and see what works. Also since your pack is operating normally now, you have a big chance of ruining a perfectly good pack that could last another 7 years for no gain. There is lots of data on this forum showing that some batteries are down to 20% or less of their original capacity (meaning 80% of new is gone) and the MPG hit is 1-2mpg. Worst case 2mpg is 4% which is pretty insignificant when you can do better than that by just slowing by 5mph on the highways... Prius + big batteries vs. Prius + small batteries makes almost no difference. The fact it has any battery at all is where the magic happens.
    Go do an experiment. Seriously. Take a ice cube tray from the freezer and fill it up so that every square in the row is at the exact same level.
    Filling the entire row with water by only having one input (water hits "cell 0") and one output (excess water flows out of "cell n") is hard. If you go fast, you get erratic results. If you go slowly you have better luck. If one in the middle gets higher than the others, the only solution is to drain all of them a little bit then refill them all again. Lots of cycling.
    Filling them one by one you can go as fast or slow as you want and if you want to adjust the cell, you can do it immediately.
    Hopefully you can see how this analogy applies.
  7. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    Thanks for your help and advice. I think I'll wait for awhile before doing anything. Your analogy is very helpful. In my case, since I don't have a highway route here that I use often I wasn't sure what to expect for mpg. On my first tank it was 39 mpg going up and down steep roads (My house is at 1,500 ft above the local town which is only a 18 minute drive away). The last tank was 33 mpg almost entirely going up and down our local 5,000 foot mountain on only short trips ........ I think if 33mpg is the worst I get, that's still not as bad as my old VW Passat which got 17-22mpg and was a V6. The CVT is very nice on the steep roads.
  8. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    Hello all, I thought I'd chime in again with some questions about my Prius' behavior and ask for any advice.
    Just to recap, I've had this car for three months now and I don't really know how the battery should behave (but I've been told the battery is 7 years old and I'm in hot hot Hawaii) but I want to be proactive about maintenance and not get stuck with a dead traction battery. What worries me is since I've owned the car on two occasions I had something strange happen to me close to home both times while I was driving slowly on the side streets going between stop signs.
    The Prius lost nearly all of it's power to accelerate and kind of went into some kind of "limp mode" and the car didn't really want to move even with the pedal pushed all the way down. There were no lights or sounds to indicate the car was doing anything strange. Since the Prius is like a weird computer, I quickly decided to shut the car off in the middle of the road, turned the car on again and was back to normal power. I did notice these past two times when I started the car the battery fan was blowing in the back of the car though I have no idea why the battery fan would kick on when I just started driving the car and it had been sitting for some time in the driveway.
    I recently fixed my A/C system which no doubt is putting more strain on the battery system. Before fixing the A/C, I had recorded fill ups with 43mpg and 48mpg and this past time I got 27mpg (although I had my daughter, a baby sitting in the back napping with A/C system on for several hours and the car's engine kicked on every so often to recharge itself to keep her cool while she napped).
    So with the weird losses of power, the battery fan kicking on and the terrible terrible gas mileage, I'm worried about what to do with this car. My first thought is to invest in a techstream cable to connect to my Windows 7 PC and learn some diagnostics.
    I know that I live in a very hot place that kills normal car batteries in 3 years vs the usual 5 on the mainland. I'm just wondering if I could proactively try to replace bad modules in the battery system and rebuild capacity over time in the cells.
    I was pretty excited to get this car for $4200 with only 132,000 miles on it, but the battery is the ONLY thing that worries me about this car at this point....
    I appreciate any and all thoughts out there and really love hearing from all of you. Much thanks.
  9. epoch_time
    epoch_time Active Member
    236
    110
    las vegas
    HI Tommerdo.
    When you can easily hear the hv battery cooling fan especially at a stop means hv battery is very overheated..
    The hv cooling fan has 6 modes/speeds all are varaible speed. increasing rpm the faster you drive and decreasing as you slow down..
    At modes 1 through 3 the fan is very quiet and turning very slowly while stopped at traffic lights...
    Desending 1500 and 5000 ft elevations will overheat (fact) and overcharge (my opinion) the hv battery. You should be using B (engine brakeing) gear for downhill trips. This B gear/mode uses motor/generator#2 to spin gasoline engine via motor/gen#1. to burn off excess generator charge and save friction bakes as well... If I'm decending large moutains I also like to turn on headlights and air to medium high to burn off excess energy comming from gen2 as downhill B mode doesn't bleed off all the excess energy by itself.
    I use the torque app (which runs on android phone) from the google play store and a blue tooth obdII wireless diagnostic adapter to monitor hv temperature. cooling fan voltage, battery current , voltage and 13 of the paired hv battery modules voltage, and there internal battery resistances, and cell voltages differences. As well as its ability to monitor about 50 other prius parameters.. I also use torque app to manually control of hv battery cooling fan...
    When the hv battery temp reaches about 108 degrees the system starts current limiting.. My untinted prius sitting (turned off) for 3 hours in the las vegas summer will reach 122 degrees and wont cool easily even when if I force cooling fan to mode 5...if driven at this temperature the hv battery after the next shut-down will always self discharge to two bars (I believe hv ecu discharges it for protection) within 1 hour of sitting (car off).
    At eight bars of charge when 80 degree outside the hv battery will begin overheating.. The prius doesn't get very good mileage in mountainous areas...As the climb begins the fully charged hv battery can only provide about 3 minutes of electric motor assist then your mpg is more like a conventional car... when descending the battery will fully charge in three or four minutes (eight bars) after that it is overcharging/overheating.
    When mountain climbing try to keep speed up to 50 mph or above. battery will not discharge below 58% (5 bars) while maintaining 50 + mph. You might want to find out if the hv cooling fan has ever been cleaned..
    also for additional cooling set passinger airconditioner vent pointing to rear battery intake grill. and also open air conditioner intake to outside air (nonrecirculate) . This forces hot battery cooling exhaust out the back of the car..
    I hope all this is not to overwhelming... But you should get many years of hv battery use if you can avoid 8 bars by running accessories and B mode while decending large hills...
  10. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    Interesting. I've never heard anyone tell me to avoid 8 bars. I'm still learning about the whole charge/discharge thing. I was always under the impression that when I parked the car after driving (coming down the hill) I wanted to have a nice topped off battery (as full as possible) so that when I drive the next day it would help me get up the hill (which as you mentioned, the strength is only 3 minutes of charge or less and consequently most of the time my car only gets several hundred feet up the hill before draining to one bar). Not sure how long the car should take to drain from green to pink but it seems that it drains pretty fast going up the hill here.
    I have been using the B mode anywhere I would use a normal car's engine braking and it seems that the car has naturally done this as well when the 8th green bar is filled up. Interesting what you said about going uphill and higher speeds. That seems right in my experience I seem to get better gas mileage going uphill faster unless I get stuck behind someone slow (which when you are driving in a Prius makes you grit your teeth somewhat). Still, thanks for advice about going uphill. And I'll check the fan at some point. I had no battery fan turn on today, and I think the reason might have been that the battery was not fully green when I parked. Some people apparently drain their battery on purpose after parking it in the driveway to a certain point (sounds a little anal retentive to me, but then again I'm just learning about states of charge and battery behaviors).
    Interesting about the torque app. How much is the dongle for that? I'm looking at the Windows 7 / OBD2 cable combo with techstream. Seems pretty cheap to get going.
  11. epoch_time
    236
    110
    las vegas
    QUOTE="Tommerdoo, post: 2252912, member: 137750"]Interesting. I've never heard anyone tell me to avoid 8 bars. I'm still learning about the whole charge/discharge thing. I was always under the impression that when I parked the car after driving (coming down the hill) I wanted to have a nice topped off battery (as full as possible) so that when I drive the next day it would help me get up the hill (which as you mentioned, the strength is only 3 minutes of charge or less and consequently most of the time my car only gets several hundred feet up the hill before draining to one bar). Not sure how long the car should take to drain from green to pink but it seems that it drains pretty fast going up the hill here.
    Interesting about the torque app. How much is the dongle for that? [/QUOTE]
    If hv battery is cold 80 degrees or lower when starting your decent 8 bars may be ok..The 8 bar no no I talk about is temperature dependent.
    If hv battery starts at 100 degrees before your decent and if you park the car immediately at the bottom the battery tempurature will increase probably 15 more degrees while sitting...
    How fast are you going uphill when you have only 1 bar of charge? must be 40 or below mph?
    I've bought the cheap chineese ones anywhere from 8-15 dollars...The only problem they all have the same blue tooth address.
    The torque apk. has trial version with less features... the pro-version is around 5 dollars..
  12. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    Thanks for the info. I just did a test on my Prius which someone in another forum was doing on their Prius.
    I turned off all electricity (A/C, lights, radio etc) and engaged the parking brake and turned the car on and put it into drive and counted the seconds it took for the battery bars to go from 8 green down to 2 pink. I'm kinda scared by the results which seem to indicate the capacity of this battery is a fraction of what it was a long time ago. I've posted the info here if anyone is interested or can comment on the results.
    I'm not sure how scientific this test is (if at all) but here are the results...
    Bars Time
    8 to 7 - 1:46
    7 to 6 - 3:19
    6 to 5 - 1:28
    5 to 4 - :19
    4 to 3 - :20
    3 to 2 - :28
    Total time to go from 8 GREEN to 2 PINK: 7 minutes 40 seconds
    In another forum another poster mentioned their car would stay at 6 bars for a full 13 minutes when it was new and when it was nearly shot was around 2 minutes.
  13. epoch_time
    236
    110
    las vegas
    Hi Tommordoo..
    I have been doing similar test from the first day I bought the car new till now. However my test doesnot put the car in drive.
    In drive with foot off brake and parking break on. the system will pull 3 to 5 amps. depending on how level the prius is..
    With everything off and 12volt batttery fully charged and not in drive the system will pull about 1 amp from the hv battery..
    Manufacture clams the prius never charges above 80% and never lets is discharge below 40% thats 40% of battery capacity.
    Factor that the hv battery is rated at 6.5 amps per hour (6.5ah or maybe genII is only 6ah) and only 40% of its capacity being used discharging from 80% down to 40% when gas engine starts to recharge. Anyway 40% of 6.5 ah battery is 2.6 ah capacity. Theoreticly I should be able to let my prius. system on pulling 1 amp run 2.6 hours before engine start up to recharge battery... NEVER HAPPENS...The longest time my prius could set is 20 minutes under 1 amp load this when brand new and still pretty much the same at 76000 mile of use..And every prius post on priuschat pretty much confirms my results on all prius's...
    I think your battery is in very good condition as you are pull 3 more amps in your test compaired to my test and getting 13 minutes (very good).
    Also note SOC is a mathmatical calculation and 7 or 8 bars left overnight will not power the car 13-15 minutes .. However a fresh charge to 7-8 bars will power for that long and probably a few minutes longer..
    Also setting idle (engine off) the fuel injectors on any car will leak unburned gasoline into engine poluting the oil.
    All injectors have leakage (no problem for continous running engines) the acceptable rate of injector leakage is one drop per injector per 8 minute interval..GenII prius is noted for fuel dilluted oil (mostly city driving) Not a problem when hwy driven.. Full engine warmup temperatures will burn off this fuel diluted oil .. I recomend long drive (one hour hwy drive) once a month to burn off fuel from oil..
  14. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    Epoch,
    Well, as I mentioned in my test above, I never got 13 minutes. That was what another poster got on their test when they did the same test (which was the time from the start of blue bar 6 until drop to blue bar 5). What I got from that same drop was 1 min 28 sec. So I have my time was 11% of his time when his battery was brand new. As for the total time to drain from 8 bars down to 2 bars (7 min 40 sec), that entire time doesn't even match his one bar change from 6 blue bars to 5 blue bars. Basically I think I purchased a Prius that has a nearly worn out traction battery. Being that we live in hot hot Hawaii it doesn't surprise me that it's tired (everyone get's tired from the hot weather here).
    I'm also curious as to how my test was different from your test. You said I pulled 3-5 amps. Was your test just powering the car on and letting it sit there? Just curious...
  15. epoch_time
    236
    110
    las vegas
    Yes my test was just powering on the car and letting it sit there...or sometime just pulling into a park and timing it bar by bar. 2 to 2.5 minutes per bar is all I've ever gotton (at its best under ideal condition)...even when bran new. I bought the car new from dealer with 9 miles on it..
    I re-read your post. I still think your battery is not to bad 8 bars down to 5 bars seems exactly all mine ever did without extra load of being in gear. AND YOUR TEST HAD EXTRA LOAD OF BEING IN GEAR ?
    I think maybe you should read the post again that states one bar drop took 13 minute under the load of being in gear...IMPOSSIBLE unless he has plugin hybrid it which case he has 10 times the capacity of the regular prius..
    When in drive and foot brake on lighty or parking brake only and you see yellow arrows on color display screen flowing from battry icon to motor icon is when the prius pulls 3 - 5 amps..
    When in drive with brakes on and yellow arrows not flowing the prius is pulling about 1.2 amps (everything else off, 12 volt batt charged) ..
    My test with the lightest possible load imho is the best test...All other tests with load run hv battery down to fast.. Big loads like airconditioner on very hot day (22 amps} will sometimes take two or more bars away at the SAME time (with perfect hv battery) .
    The 26 battery modules are monitered pair by pair (13 pairs total) There individual internal resistances of all pairs can all be displayed at the same time with the android apk (torque).
    The internal resistances are computed while battery is under load (up to just over 100 amps full throttle acceleration from dead stop) and up to 97 amps full regenerative braking... HARD TO BELIEVE. BOGGLES THE MIND THAT A 6.5 AMP HOUR CAN TAKE IT..
    60 amps of charge is about the average current seen when moderately braking. but its duration is only for maybe 7-8 seconds?
    Anyway internal resistance is the only true way to tell if a batter is good or bad..
    A NEW 12volt 80 ah car battery has an internal resistance of 3-4 miliohms (seen with harber freight cen tek battery analyzer)..
    The nickel metal hydrid AA (2 ah) rechargable batteries purchased at walmart, kmart, target, etc brand new show 50 milliohms (with opus batt analzer/charger/conditioner)..
    The prius nickel metal hydrid 7.2volt paired modules show 18 milliohms brand new at 70 degrees farenhight (with torque apk).
    Mine (prius 76000 miles) which have taken alot of hv battery abuse. run from 23milliohms when cold to 29milliohms when hot (120 degrees)..
    And I will tell you and everyone reading this. the prius batteries are continously balanced by hybrid ecu! (easily seen with torque app displaying high and low voltage module pairs...(high and low voltage pair number changes every second )
    I could drain a 7 bar charge when new with airconditioner running 75% full. On 115 degree day at a traffic signal in only 2 minutes.
    The airconditioner running full on pulls about 22 amps...
    But normally I run at say 20 percent airconditioning only pulls 5 amps at 99 degrees farenheight .At 20 % air it can run 5 to 7 minutes at traffic light without engine starting to recharge the battery...
    All my testing watching and timing bar by bar discharge shows no consistent results... SOC while charging and discharging (under high battery temperatures) imho cannot be calculated accurately with the prius software . SOC in only an estimation (usually pretty good) but not in high battery temp. situations).
    #15 epoch_time, Oct 14, 2015
  16. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    Thanks for your posts. It's interesting to hear your thoughts on the battery. Maybe my battery isn't so bad after all. I wish that I could drive it somewhere really flat so I could better gauge the highway mileage. The crazy long hills and short commutes here has my MPG at about 40 at the moment, which considering the landscape probably is the best I could do.
    All in all, it's way better than my old VW Passat which got around 21mpg on the highway and used PREMIUM gas. Hah! I just sold it last week and I'm so relieved to have it gone from my driveway. It had 206,000 miles on it and was at the point of having some minor problem every month. I'm quite pleased that there is so little long term maintenance on the Prius, even if I get to the point of replacing the battery, it would be worth it as my car has only 130,000 miles on it.
    I think I'll definitely get the mini cable and hook it up to PC or go with the torque app. Is one better than the other?
  17. epoch_time
    236
    110
    las vegas
    I like the torque apk because of its portable-ness. I leave my blue tooth obdII pluged in continously.. Before I had bluetooth with torque I used scanguage which only allowed 4 gauges at a time to be displayed (very usefull but Couldn't display all data) and the scanguage was also connected perminantly... I won't drive prius without my telemetry (no fun without it)..
    PC may even read more data than torque apk but may be combersome (ok for noncontinous use).
  18. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    Thank you, that's good stuff. I agree, telemetry is nice to have. That will open up a new conversation when I have that running. Until then, my battery seems fine and the fan hasn't come on again since. I think it only came on because I had parked with a full state of charge on hot days in the lot. I'm sure my battery gets quite the workout living on the hill with me here. Everyday it goes up the big hill, depletes to one bar, gets cycled all day and comes down the hill fully charged. That plus living in Hawaii must mean that it gets pretty "stretched" in this situation. I'm guessing at some point in the near future I'll be looking for Gen 3 batteries or the Dorman reman that a friend of mine can get at a local parts store.
  19. epoch_time
    236
    110
    las vegas
    Tommerdoo,
    Tell me a little about your daily mountain climb (road discription).
    Are there traffic signals that stop your climb? (accelerating stopped prius on a steep incline takes alot of battery (traction) power to get up to speed).
    What is the speed limit of the mountain/hill climb? Does the speed limit change to lower speed limit sometime during the climb?
    At around 40mph (level road) generator number 2 provides all the traction energy where the hv battery is not needed. Perhaps 50 mph on steep incline will be needed for generator 2 to provide all the traction energy to mg1 (traction motor/generator/constant-variable-gear-selector/overdrive-gear-selector)...
    Did the previous prius owner commute on level ground?
    Did previous owner drive all city stop and go traffic? (harder on hv battry)
    Or did previous owner drive all higway commute? (low hv battery use)
    Get yourself a good digital tire pressure guage (my talking sears guage has 1/2 psi resolution but it may be obsollet). each pound of pressure loss on my genII with orignal tires results in one mile per gallon loss.. (I seem to loose about 1/2 pound per week. uniform across all tires)
    What Brand of tires does your prius have? Check priuschat for users with your tires and see what presures they use...The easier you prius will roll up hill will help.. Some people run 44 psi on the front. check your tire sidewall specification for maximum pressure.. I dont think you should run 44 psi..but some people do .. I only run 35 front 33 back on orignals... and have always got 50mph (paper calculation ) 53 mph (prius computer displayed).
    #19 epoch_time, Oct 17, 2015
  20. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    Well, the climb in the morning up a narrow residential road so I can't go too fast and it climbs about 500 feet. There is some stop and go with speed bumps too which of course slows one down. I'm not sure what the previous owner did with the car but I think it was used also in a hilly / city neighborhood as she lives on the other side of the Big Island, Hilo. Hilo has similar characteristics as Kona (we're all living on volcanic hillsides).
    Regarding tires, I'm buying one of those air compressors that Scotty Kilmer recommended...I think it's VIAIR or something. Nice unit for $41 or something like that. I've been using 42 front / 40 back like many on Priuschat. Last I checked all tires were in the zone except one front had lost 3 psi....thus a need for a compressor so I don't have to pay a dollar everytime I need a few psi. The tires themselves are Falken Ziex ZE912 which I've heard are not the greatest but not a low rolling resistance tire.
    I was changing out my spark plugs yesterday (and my pcv valve) because I don't know much of the maintenance history of the car (which I've had 3 months now) and found the spark plug looked dipped in oil. There may be some correlation with mpg there as well. I'm going to replace the valve cover gasket today, pcv valve and all spark plugs and see where that takes me next (as well as check the level of oil so that it is not too high).
    Thanks for your ideas. I'll post my results later.
