Rear Doors not Locking
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sarp1028, Oct 21, 2015.
Tags:
  1. Sarp1028
    Sarp1028 Junior Member
    55
    Atlanta
    After a quick search for similar problems in the forum and finding no similar issues... I'm worried. When I lock the car with the FOB, the door handle, or pressing the lock button on the driver door- the rear doors will not lock. Any input would be appreciated.
    52,021
    are the child locks on?
  3. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Check the child locks within the door. If you had your car recently detailed or cleaned at a carwash, they are notorious for accidently sliding the child lock buttons into position.
  4. Sarp1028
    55
    Atlanta
    UPDATE: So i followed your advice and verified. BOTH child locks were OFF. However I toggled each. NOW the back-right DOES lock and the back-right still will not lock no matter the child-lock position... Already sounds expensive.
  5. Montgomery
    2,254
    2,241
    Orange County, CA
    Sorry it didn't fix your problem. Next step, the dealer.
  6. mrbigh
    3,686
    699
    Long Island, NY
    How deep your wallet is??????
    Look further into the problem, what did it changed before this started?
  7. bisco
    52,021
    sounds like a bad switch? might have to pull the panel off. strange that they are acting funky.
  8. Sarp1028
    55
    Atlanta
    I bought it used a week ago so I am discovering some of the not-so-obvious imperfections as I go. With that being said, I have not changed anything to have it suddenly stop working as usual, this was the way I inherited it.
  9. Mendel Leisk
    41,548
    Shouldn't 2015 still been within warranty?
  10. Sarp1028
    55
    Atlanta
    Perhaps, but my car is a 2010... Forgot to mention that.
  11. Mendel Leisk
    41,548
    And a complete brain bubble on my part: I looked at the year on Montgomery's avatar.
  12. nycrich425
    nycrich425 New Member
    If you do an online search you will see that this is becoming a popular problem. There is a motor in the door actuator module. They will fail completely or start intermittently.
    My front door was intermittent until it failed to lock.
    I ordered a pair of the motors for $12 and will follow the DIY. Dealer wanted $375 each.
    This is on my Prius 2012 III
  13. LaJay007
    LaJay007 Junior Member
    El Segundo, CA
    I replaced both rear doors and the front passenger door yesterday. All done in 2hours. I couldn't be happier w/my recently purchased 2010 Prius with 64K miles. Now all the doors lock and unlock! I bought all three actuators on Ebay from a reputable rebuilder. All three for $275 delivered. Followed the online instructions and knocked it out. So much cheaper than the mechanic charging $500 per door.
    Grit likes this.
