Catalytic Converter in 2009 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bbkothe, Mar 24, 2013.
  1. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    I'm reviving this old post... Thank you rmsmith1977 for posting that link! I get the annoying P0420 code... I've replaced both the upstream and downstream O2 sensors and the code keeps coming back. I do have over 200,000 miles on my Prius, so it is reasonable that it needs to be replaced. Parts on order from Amazon for $232.18, which is much better than the OEM $1,697.82! With the Prime membership Parts should be delivered by Tuesday 10/27/2015 - which I find to be incredible!
    HaroldW likes this.
  2. Priusyipee
    Priusyipee Active Member
    350
    269
    Upstate New York
    Should have updated this a year ago. The catalytic converter that was installed in 2011 only lasted 3 years. The unit COMPLETELY rusted out from stem to stern. Since I had the original unit, I put it back on the car and welded the muffler directly to the pipe since the connector had rotted away. So far, so good. The aftermarkets are guaranteed for 5 years but only last 3. Never going down that road again...
  3. Daves09prius
    680
    161
    Gettysburg, PA
    That's too bad that it only lasted 3 years... but I guess for about $300 that isn't too bad, and it could be worse. I mean the alternative is $1698 you could replace the CAT assembly almost 4 times for the price of OEM. and in my situation, the CAT I have now is not working.
    Thanks for the update.
  4. Coopers ST
    Coopers ST Junior Member
    51
    Colorado
    Sorry to bump an old thread if you are even still around. How is the FoST treating you? I have a 13 FoST I bought new. I get 24ish mpg around town and 28.5 on the interstate. My biggest issue was a new engine at 31,000 miles.
  5. Daves09prius
    680
    161
    Gettysburg, PA
    I ended up buying a rear O2 sensor from a Toyota dealership so I knew for sure it was stock OEM. As soon as I put it in, no more codes. So it was the non-OEM sensor from a-zon (you know the website) that claimed to be an "OEM replacement."
    offib likes this.
