Toyota Unveils Advanced Prius Tech
Discussion in 'Gen 4 Prius Main Forum' started by Jeff N, Oct 13, 2015.
  1. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    yeah, new Prius is not only 60% stiffer than old one, it is also a lot stiffer than Lexus GS, car that wins handling comparos left and right, and was previously the stiffest car in the TMC empire. This allows them fit softer springs, and together with multilink at the rear, it leads to 3x better bump absorption than before.
  2. mozdzen
    mozdzen Active Member
    719
    295
    Phoenix
    2015 Tesla Model S
    I wonder if Toyota will put their best effort into the PiP version, or do a half-hearted job just because everyone expects a PiP version?
  3. john1701a
    john1701a Prius Guru
    12,805
    5,291
    57
    How would you quantify best effort?
  4. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    If they are serious about selling them in January they should be releasing numbers about this time.
    the rigidity of gen4 is improved, and it has lower CG, so all this should be addressed.
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    To me, the current PiP is the best effort. They tried to put in as much EV miles without robbing cargo space or gas MPG hit. The optimal balance was achieved.
    Despite that, PiP emission is almost the same (a bit better than) as the regular Prius. If Toyota went with bigger battery, it would end up with higher emission such as Ford Energi, Volt, etc.
  6. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Agree that it was the right balance for its (design) time.
    The future PiP should have larger battery if they don't want to stay behind. Volt 2 emission is already lower on US average and the grid is getting greener. Several European main markets have lower carbon intensity grids than US average (and high tax on gasoline).
    #146 giora, Oct 25, 2015
    mozdzen likes this.
  7. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
  8. cyclopathic
    3,292
    547
    2014 Prius c
    it is not the only thing wrong. Gen4 data weight power are wrong too.
  9. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Gen 2 with seats up, Gen 3 with seats down!
  10. austingreen
    austingreen Senior Member
    13,664
    4,204
    Austin, TX, USA
    Awful bad data info graphic. Are the power and weight of the gen IV correct?
  11. spwolf
    3,156
    440
    Eastern Europe
    nope... this was done last month i think.. in any case, it is not correct.
  12. Mendel Leisk
    41,012
    Toyota's logo at the bottom, meaning they've signed off on it. Not good if it's riddled with errors.
    mozdzen likes this.
  13. cyclopathic
    3,292
    547
    2014 Prius c
    I am sure bisco is gonna say Toyota never said anything about it being lighter.
  14. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Looks like a real Volt gen2 beater!
    DBCassidy
  15. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    Cargo space data may not be right,but who knows maybe the are right about system power .
    I still find it hard to believe they reduced system power vs. gen. 3 Prius !
    We will find out about system power on Friday anyway !
  16. spwolf
    3,156
    440
    Eastern Europe
    I dont know where to start answering this... no, Toyota does not sign off any blog article in the world, let alone every... no you dont need Toyota's permission to use their logo or pictures in online articles.
    And no this information is not correct, and it shouldnt have been posted here in the first place. Dont be naive and stop believing nonsense...
    Netcub likes this.
  17. Sergiospl
    3,938
    1,351
    28
    "Attack of the Clone: Is this the 2017 Prius Plug-in Two-Mode Transmission?
    No Prius transmission has ever used clutches but it turns out that Toyota now has a freshly minted “Two-Mode” patent derived from the 3rd generation Prius Hybrid Synergy Drive. The patent, published on January 1, 2015, is US 20150005125.
    Is this the hybrid system Toyota’s customers are looking for?
    The new design uses 2 (or optionally 3) clutches to support the original Prius EVT mode plus a higher-speed EVT mode and a dual motor EV mode intended for a “vehicle such as a plug-in hybrid vehicle, which is frequently placed in an EV drive mode”. The similarities to the Chevrolet Volt transmission cannot go unnoticed."
    Revenge of the Two-Mode Hybrid - HybridCars.com
    #158 Sergiospl, Nov 6, 2015
  18. bisco
    51,561
    it's november 6th, what have we learned?
  19. bwilson4web
    16,127
    Patent "prior art" suggesting Toyota's legal representation was incompetent! But we knew that already.
