Brand new Prius v - Chemical Smell
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by jst, Oct 21, 2015.
  1. jst
    jst New Member
    DE
    2015 Prius v wagon
    Hello,
    we just picked up our brand new Prius v and there is this distinct chemical smell.
    It's not like the typical, rather sweet "new car smell" - this one smells more chemical.
    Our previous car was a 2011 Prius and I think there was almost no smell, so it surprises me even more that the new Prius v would smell that much.
    Anyone who recently got their factory-new Prius v - what was your experience regarding interior smell? Did you notice anything?
    Thanks!
  2. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    …might be that the salesperson got a bit over-enthusiastic with the can of NuCarSmell (every used-car salesperson's secret-weapon (now available in a spray!)
  3. Mendel Leisk
    41,643
    Our brand new Prius had little or no "new car smell". I think due to the interior plastic being more plant based. It was actually a refreshing change.
    My guess re your smell is it's some sorta cleaner. Maybe used on upholstery/carpet? Or the Heating/Ventilating circuit, some spray used to try to clear mildew?
  4. jst
    jst New Member
    DE
    2015 Prius v wagon
    Thanks for all your responses. I don't think they used NuCarSmell - it's a factory new car.
    I should add that we got it a week ago and the small hasn't decreased since, despite keeping the windows open. The dealership even put the car into a "heat chamber" to heat up the car to 120F for the smell to evaporate - to no avail.
  5. rjparker
    10,238
    6,393
    Could be a freon or coolant leak
  6. WilDavis
    2,493
    2,155
    49
    Coolant leak smells a bit like being in a commercial laundry (…yup, I've had one of those, although not in my Prius!)
  7. bisco
    52,093
    did it smell when you test drove it?
  8. jst
    jst New Member
    DE
    2015 Prius v wagon
    It was built-to-order...
  9. bisco
    52,093
    why aren't they apologizing and doing everything they can to fix it? it's brand new!
  10. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    It would help to know what interior you have, fabric or Softex? Floor mats? Cargo mat? An odor can come from anything.
  11. jst
    jst New Member
    DE
    2015 Prius v wagon
    Well, that's the purpose of my post here. Smell is a subjective thing - and hard to describe. Therefore I'd like to find out what experiences other Prius v owners made, whether it typically has a smell when delivered or not, or if there's something wrong with ours.
    As per the dealership, this is "how hybrids smell" - which is nonsense as our 2011 Prius did not smell.
    Good point, I should check this and remove the mats temporarily.
    It has black interior with fabric seats, and rubber floor mats as well as cargo mat.
    #11 jst, Oct 21, 2015
  12. bisco
    52,093
    i suppose the rubber might smell. my lift back came from the factory, no smell. slip into a new one on the lot to see 'if thats how hybrids smell'.
  13. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The dealer's detail crew could be using a variety of crap on rubber and plastic parts. Armor All, and stuff like to make things shiny. Stain protections on fabrics can smell pretty bad.
    I can tell you that I'm VERY sensitive to perfumes and chemicals, and my 2013 v didn't bother me at all, although it did take a while for the "new" smell to settle down.
    Go find another unit on the dealer's lot with the same interior and drive it to see if it has the same smell. Ask them to keep it overnight if needed.
  14. Bmidd
    Bmidd Junior Member
    Chattanooga
    2015 Prius v wagon
    Ours doesn't smell as much like a new car as the last one did. It has a different odor, hard to describe. It might be because this one has cloth and not leather seating.
  15. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Check that the 12v battery is not leaking, it's in the boot so smells from the battery will enter the cabin. Make sure the battery vent tube is not missing or has come off.
  16. Tabata Simarik
    Tabata Simarik New Member
    Mexico
    2015 Prius c
    This require an exhaustive nose work as old school way, get close to any interior part of your Prius first and smell it, if you can’t find something intense there, go to the engine. A new car don’t have chemical smell, by the way, ask your dealer to do it…
  17. bisco
    52,093
    it could be the o without the b, heck of a time trying to get that out.
