Toyota Prius 2010-2015 Transmission drain and refill
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NutzAboutBolts, Aug 7, 2013.
  1. Greg_M
    Greg_M Member
    151
    35
    NC
    Went ahead and changed the fluid on my 2004 with 183,000 miles. The fluid had never been changed. There was very little on the drain plug magnet and I mean very little. Fluid was darker than the new fluid but it wasn't bad at all.
  2. Mendel Leisk
    41,951
    Thanks for the observation about the magnet's lack of particles. Maybe Toyota knows what they're doing, eliminating the magnet on 3rd gen: the transaxle is different than a typical automatic.
  3. CR94
    CR94 Senior Member
    2,761
    1,210
    Northwestern S.C.
    Right. After I changed mine at 48,429 miles, I stirred the oil in the drain pan thoroughly with a magnet, expecting to pick up some ferrous wear particles. I wasn't sure whether to be disappointed or pleased that the magnet found none, not even one particle large enough to see. Likewise, nothing showed up in the bottom of the drain pan after I slowly poured off the used WS---which looked more like black ink than anything I ever drained out of a transmission before.
  4. Bill Norton
    Bill Norton Senior Member
    2,219
    746
    MONW, Ks.
    2019 Prius
    L Eco
    "Oh by the way I had to remove the whole panel to get to the two plugs, there was no way of accessing it through the oil change door."
    Yes way. 18" extension and a 10mm socket on the end of the extension and a long handle ratchet wrench. It will be tight if this is the 1st time the plugs are removed. A little fluid gets on the panel. Wipe it up with a handful of paper towels and Bob's your uncle.
    #84 Bill Norton, Jun 16, 2015
  5. farmecologist
    farmecologist Senior Member
    1,960
    1,800
    Southern MN
    I just changed ours on our newly acquired 2010 Prius with 58,000 miles.
    By the way, thanks for the video - it really helped. However, I did two things differently :
    • I used the "four ramp" method that was discussed in another thread. I put the front wheels up on ramps, jacked up the back end with a garage jack enough to get clearance, put my second set of ramps under the rear wheels, and then let the back end down on them. I also used four jack stands for safety/paranoia.
    • To fill, I used 5/8" vinyl tubing with a funnel attached. This allowed for a gravity fill from the top of the engine compartment. This just seemed easier to do than the 'pump' method documented in the video. However, it did take a bit of work to get the tubing down through the engine compartment.
    It was a pain to get the engine splash cover off. However, I'm glad I did it because i noticed that the oil fill door is missing! Does anyone have any tips on where to get a new one? I see some inexpensive aftermarket ones out there on the internet. However, there seem to be comments stating that the plastic is 'too thin', etc....
  6. Mendel Leisk
    41,951
    That undercover is one piece, so your only option is to replace the whole cover. Well, or cobble something together to replace just that flap.
    There are some cheap knock-off covers, JUST the plastic, and maybe a few rough edges, for well under $100. The kosher cover is something around $300.
    If you're doing all the maintenance, if you never bend back that flap, take the WHOLE cover off at every oil change or whatever, it'll last forever. It affords you a much better view too, for checking the CV joints, engine block and transmission drips, etcetera.
  7. farmecologist
    1,960
    1,800
    Southern MN
    After poking around the site for a bit, I ended up ordering this one from partsgeek :
    2010-2015 Toyota Prius Undercar Shield - Body Mechanical & Trim - Action Crash 10-15 Prius Undercar Shield - 30440-04120783 - PartsGeek
    I also ordered some clips because some of the ones on the car now are partially broken, etc...
  8. Mendel Leisk
    41,951
    Your existing shield's acoustic panels (or whatever they are) can maybe be can transferred over. Maybe with pop rivets? Whenever you remove the plastic push-in fasteners, rinse them out with soapy water. It'll float grit out of them, help them to last.
  9. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    Here's a video I made showing how I used a funnel w/ extension tube to fill from the top:
    The pw for the video is "prius"
    Also I have a 2013 Prius TWO & I have a OEM magnet attached to the drain plug which has collected a small amount of grey/black residue that wipes off with a paper towel.
    I have observed this at my 30K & 60K drain & fills.
    gliderman likes this.
  10. gliderman
    gliderman Active Member
    751
    225
    What is the OD of the 7/16" tubing?
  11. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    I bought it here:
    McMaster-Carr
    It appears to be the 5/8" variety.
  12. nedear88
    nedear88 My 1st Prius.
    246
    142
    San Bruno, California
  13. Mendel Leisk
    41,951
    Considering that the Owners Manual says to use only Toyota ATF-WS..., sorry: what was the question?
    Seriously, I'd recycle it and get the kosher stuff.
    I mean, it MIGHT be ok, but why use your car as a Guinea Pig?
    #93 Mendel Leisk, Oct 28, 2015
  14. Greg_M
    Greg_M Member
    151
    35
    NC
    Plus the Toyota fluid is less expensive.
  15. Bill Norton
    2,219
    746
    MONW, Ks.
    2019 Prius
    L Eco
    I used it. No problem found. Why not use a high quality 'known' synthetic instead of the no name house brand that they put in everything?
    It has a viscosity very similar to the house brand.
  16. Mendel Leisk
    41,951
    I do not know Bill, because of this?
    When you traded in your Prius, did you let the new owner know what you'd put in there?
  17. nedear88
    246
    142
    Thanks Bill for the response, I will definitely use it, full synthetic is better than the OEM WS fluid. My goal is once the Redline in it and that's it I will not change it until I trade in the car in the next 3 years.
  18. Mendel Leisk
    41,951
    This is why I never buy used. :)
  19. farmecologist
    1,960
    1,800
    Southern MN
    The OEM ATF 'WS' is absolutely required..and Redline is certainly not better for the Prius. I can't stress this enough. This is true because the Prius transaxle is different from a 'normal' car in that it has electrical windings in it, etc... Therefore, it needs a special fluid that will not damage the electrical aspects of the transmission.
    There have been MANY discussions on this topic over the years. Have a look over here :
    WS ATF Question | PriusChat
    Frankly, you are nuts to use anything other than OEM... :whistle:
  20. Mendel Leisk
    41,951
    Even if Redline is ok: WHY ignore toyota's guidance on this?
    Bill evangelized about alternate fluid for the transaxle, maybe 3 years back. Then traded to a Volt, and said "I'm outa here". But can't resist stirring the pot. This is his pet subject. One of mine too. :)
    #100 Mendel Leisk, Oct 29, 2015
