oil change at 6k interval - conventional oil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tampaite, Oct 29, 2015.
  1. tampaite
    tampaite Member
    237
    42
    FL
    Can I safely change oil at 6K interval with conventional oil ? Manual says 5K but I read somewhere it was 7.5K earlier. I have a 2007 model.
    What do PC members say ?
    If 6K then, can I just ignore the maintenance light once that turns ON after 5K ? or is there a setting to default it to 6K so the light doesn't turn ON?
  2. JC91006
    JC91006 Senior Member
    16,798
    8,589
    Why not just do it at 5k? Yes it's safe
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Agreed, it is safe. It was changed from 7500 because of lawyers and the sludge problem in some Toyotas in the early 2000's.
    If you're under warranty go with 5k.
  4. Mendel Leisk
    41,736
    I'm not sure the correlation between conventional vs synthetic oil and oil change interval is that clear. Does Toyota actually say anywhere that conventional oil alters the oil change interval? I appreciate manufacturers of synthetic oil tout it's ability to have longer change interval, but what does Toyota actually spell out?
  5. tampaite
    tampaite Member
    237
    42
    FL
    because as an idiot - I didn't pay attention to my dash to see the maintenance light has been ON for over a week and I have driven almost 1k above and beyond the 5k oil change interval limit.
    I plan on getting oil change done later this evening.
    No warranty here - Prius has almost 150K miles on it.
    #5 tampaite, Oct 29, 2015
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    If you are driving a over 1000 miles in a little over a week, then I'd definitely error on the side of changing it more often and sooner as opposed to less often and waiting longer.
    If I was putting that many miles on a vehicle that rapidly, I'd change to synthetic.
  7. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    why not synthetic? then you need to do it every 10k. Price for materials x2 conventional will be about the same as x1 synthetic
  8. bisco
    52,174
    no problem with 6k. no way to change the 5k default, but i think there is a maint. menu in the mfd that you can set for 6k reminder.
  9. roamerr
    roamerr Member
    135
    43
    Winston-Salem, NC
    I doubt even 9k miles matters at 150k miles. I change my 2005 somewhere between 10k and 14k miles but I use Mobil 1 oil and filter. It also is now kinda self changing since it uses a quart every 3000 miles. It really changes itself every 12k. I just drop it, install a new filter, and refill.
    mmmodem, Mendel Leisk and bisco like this.
