Loss of inverter coolant.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ozark Man, Oct 29, 2015.
  1. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    I have had my certified 2010 Prius since June 2015. Last Saturday I noticed my inverter coolant reservoir was on the low mark. I went to the closest dealer and they topped it off up almost to the full mark for free. I thought it had probably went down from evaporation and I just hadn't noticed it before. Yesterday I went back to the dealer where I purchased it which is about 90 miles away to have the CVT fluid changed. This morning the coolant was back down to almost the low mark. I looked on the ground and can't see any evidence of a leak. Tomorrow I have a appointment to have them check it. Since it is still in the one year certified warranty I don't know how motivated they will be to find the problem when they can't charge me for it. Does anyone know what I should tell them to help and what I should do if they say they can't locate the problem. I don't think the level would have went back down right away if there wasn't a leak somewhere. I checked and there have been no recalls done or called for on it. Any help will be greatly appreciated.
    #1 Ozark Man, Oct 29, 2015
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    When are you checking it? When the car is cool, the coolant will be at the low mark. When the car warms up, the liquid expands and will be at the high mark. The level should only be checked when the car is warmed up.
  3. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    I just started it and let it run until the gas engine shut off and it might have went up slightly but is still nowhere near where it was when they filled it Saturday.
  4. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    You have to drive the car for the inverter coolant to warm up. You are only warming up the engine.
    usnavystgc likes this.
  5. usnavystgc
    3,159
    990
    Tucson, AZ
    What bedrock8x said is correct. You must drive the car or at a minimum, put the car in D with your foot on the brake and give it gas. The inverter is not working much during initial warmup.
  6. Mendel Leisk
    41,901
    It took ours, both engine and coolant circuits, about 4.5 years to get from top to bottom marks. They went pretty much in tandem. I topped both up in early April, neither has moved to speak of since. I see little if any variation in level, cold or hot.
    It seems to me you've got a leak. I'd just tell them what you're seeing, hopefully they figure it out.
  7. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    You were exactly right. I drove it for about 20 miles and the level went up. So I canceled my appointment. I don't know why the service person I called to make the appt. didn't say that this morning. Anyway you saved me from having to get up at 4:30 and drive 90 miles tomorrow. Thank you very much. Have a great day.
  8. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Look around in the engine compartment for dried residue. That leaked coolant had to drip on to something. I wouldn't volunteer that information to the Service Writer as the mechanic should be able to see it as well as you can. If they say they don't see anything then ask them about what you found.
    My inverter coolant was low (probably since the beginning). The dealer didn't top it off so I did. So, like Mendel, one "fill" in 5 years.
  9. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    Mine was sold new in Nov. 2009 so this might have the first time it was added to. Anyway it is about a quarter inch under "F" when hot and maybe a little more than that above "L" when cold. I'm just going to keep an eye on it for a while and if it varies from that I will take it to the dealer.
  10. Mendel Leisk
    41,901
    There could be some variation on ours, hot vs cold, I'm not that attentive. Not a lot though I think, maybe 1/8" variation. I think you're on right track, just continuing to monitor a bit longer.
    I'd still bet something's up though.
  11. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    I sort of agree there may be something up but sometimes I think I'm a hypochondriac about my vehicle.
  12. Mendel Leisk
    41,901
  13. Jim T
    Jim T Junior Member
    22
    New York State
    I had to add coolant recently so I want to clarify that the manual says to check the level and fill when cold:
    "The coolant level is satisfactory if it is between the "FULL" and "LOW" lines on the reservoir when the hybrid system is cold. If the level is on or below the "LOW" line, add coolant up to the "FULL" line."
    I have a certified used 2010 that I bought in 2013. I noticed earlier this year that the engine coolant was just below LOW, and the inverter was right at LOW when cold. I filled them (10 oz engine, 1 oz inverter) to FULL (cold) and they haven't budged in the six months since. I can't be sure that they were never topped off before I bought it, but based on the levels not moving in six months since I filled them, I'm guessing it took five years for the levels to get low. The level does go somewhat above FULL when hot.
    So I'd say if your cold level drops at all in weeks or months it should be checked for a leak.
    Coots and Ozark Man like this.
