  1. xliderider
    xliderider Senior Member
    7,891
    3,125
    Honolulu, HI
    There are yellow 9005 highbeam bulbs available. :confused:
  2. ncases
    ncases Senior Member
    609
    672
    Chicago
    My prius almost back to stock. Sway bars are left and when removed and Sean's side mirror covers arrives my prius will be traded for the lexus GX460. I never thought I can be a mechanic/ICU nurse. I'm getting ready for my next mod so all of you are welcome in my next adventure at clublexus.com. Thanks to all your support here in priuschat.
    Ramtart, Xterra72, sfv41901 and 4 others like this.
  3. Johnsk93
    Johnsk93 Senior Member
    212
    1,055
    San Jose, CA
    orenji, Ramtart, sonnyd510 and 10 others like this.
  4. TopRamen
    TopRamen Senior Member
    307
    578
    Fremont, Ca.
    Get that alignment?
  5. bluhawk
    bluhawk Junior Member
    25
    40
    Torrance, CA
    i know, but since i got the paint might as well do it :)
  6. TopRamen
    307
    578
    Fremont, Ca.
    Gave my Prii and my wife's Prii C a break and took the family in 66 for a cruise with my Volks Regime car club.
  7. TopRamen
    307
    578
    Fremont, Ca.
    Very nice! My in-laws had a 4-door and now I wished I kept it instead of telling them to sell it.
  8. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    Why are the rear wheel so canted rather than perpendicular to the ground?
  9. chkcee
    chkcee Junior Member
    Los Angeles
    TopRamen likes this.
  10. xliderider
    7,891
    3,125
    Honolulu, HI
    Probably on airbags.
  11. Starbrand
    Starbrand Senior Member
    493
    1,502
    Westmont, IL
    sfv41901, bonchang and TopRamen like this.
  12. Silvertn350
    Silvertn350 Junior Member
    64
    51
    Tennessee
    Not yet installed because of the crap weather we have had lately. Should be installed maybe this weekend. You leave it in, you don't remove after use that would defeat the purpose of it.
  13. LDB
    LDB Member
    279
    71
    So why so much camber. It seems as close to zero as possible would be best for optimum tire wear.
  14. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    The inner sidewall will probably show threading before the treads wear down with such an aggressive camber. Just another sacrifice to make to look good.
    TopRamen and Starbrand like this.
  15. Johnsk93
    212
    1,055
    San Jose, CA
    Installed Valentis and some better shots of my new wheels
  16. Johnsk93
    212
    1,055
    San Jose, CA
    @TopRamen
    Not yet. Probably next weekend I will.
  17. TopRamen
    307
    578
    Fremont, Ca.
    Yes it has more than -0 camber but most VW's have that camber when we slam them. There is a kit to keep the rear wheel straight but no ones really uses it, plus tires we use is $50 a piece. If there is significant tire wear, we'll just flip the tire because they're not directional.
    sfv41901 likes this.
  18. TopRamen
    307
    578
    Fremont, Ca.
    Sorry, not on air bags (Bags are for groceries). This is all static, 2" drop spindles, 4" narrowed beam with Koni shocks up front and 3" drop plates with Koni shocks in the rear. Rides ways better than a car on bags.
  19. TopRamen
    307
    578
    Fremont, Ca.
    Haha, true true but the new Firestone tires have harder tread which has longer tread wear before flipping the tire. Plus I can't really complain about $50 per tire.
  20. TopRamen
    307
    578
    Fremont, Ca.
