PriusIV 12v battery (smart car type) problems.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ScouterDP, Oct 31, 2015.
  1. ScouterDP
    ScouterDP New Member
    Dana Point, CA
    Have great difficulty getting the car to jump start. Got it running briefly, clicked fob lock unlock system to break the anti theft interlock with doors left unlocked. Tried to put it in gear and it died. Cannot get it to jump start again. The hatch lock has no manual override to open it that I can find.
    Any suggestions for getting into the hatch to get my stuff out and access the battery will be appreciated.
  2. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Welcome to the site.
    I am confused. After the jump it should have stayed in Ready and putting it in gear would have no effect.
    If the polarity was reversed for the second attempt the failure would be expected as at best the fusible link would have been fried.
    The manual release for the hatch is under the little plastic cover by the latch on the deck. Drop the rear seats & pull your stuff out through the rear doors. Crawl to the back, pop the cover, reach down & trip the release.
  3. bisco
    51,843
    pop the hood, use the jump point in the fuse box, open the hatch and replace with a new battery.
    welcome to priuschat.
  4. ScouterDP
    Dana Point, CA
    Polarity was not reversed. Thanks for info to find (excavate) the manual hatch release. Of course, I had it fully loaded!!!
    Any idea for a good non-OEM battery for a smart car?
    That was our intent, but no go.
    #4 ScouterDP, Oct 31, 2015
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'm a little unclear as to the genesis of your problems.
    When you say you got it running briefly, was this after a jump start attempt?
    I would just start doing things 1 thing at a time. The first being getting your hatch open, which should be possible regardless of everything else.
    Then you can attempt another/or first? Jump Start...or replace battery. Or discover that you have bigger problems.
    If you had it running and it died when you put it in gear you may have some other problem(s).
  6. bisco
    51,843
    there are a few aftermarket options. optima, exide, duracell and others. 'good' can only be determined by each user, and it's been hit or miss.
    #6 bisco, Oct 31, 2015
  7. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    The underhood jump start can be iffy because it's conductive on only one face. Some jumper clips conduct to only the fixed jaw so it's possible to fail that way.
    I recommend leaving the driver door open so you can see the dome light come on once you've oriented the jumper clip properly.
    Robert Holt likes this.
  8. JimN
    7,028
    1,117
    South Jersey
    Search for "2010 prius battery" and a number of options will be returned. When reviewing the selection through amazon compare the price to that on the seller's website. One will probably be cheaper.
    Regardless of the brand you choose there will be someone who had a problem with them. As long as it is a DS46B24R it will be a direct fit.
    I bought an optima from elearnaid. It arrived quickly & fully charged.
    ScouterDP likes this.
  9. Former Member 68813
    3,524
    983
    US
    what is smart car type?
  10. bisco
    51,843
    sks, smart entry and start. keep the key in your pocket vs having to push the fob button to unlock doors or slide into dash to start car.
  11. Former Member 68813
    3,524
    983
    US
    i thought that was smartkey,not smartcar.
    the only smartcar i know is this:
    CR94 likes this.
  12. Mendel Leisk
    41,328
    Friendly, I bet a lot of readers where scratching their heads over that, just thinking "whatever". :)
  13. bisco
    51,843
    prius is 'a' smart car, not 'the' smart car. non sks is dumb.:cool:
  14. ScouterDP
    Dana Point, CA
    Thank you all.
    Have gotten access to the battery after manually popping the hatch. On a charger now.
    Can anyone recommend a trickle-down charger for this particular battery?
  15. Mendel Leisk
    41,328
    I have a CTEK3300, so partial to that. It charges at 3.3 amps, well under the 4 point something ceiling in the spec. It's a smart charger, can be left on indefinitely.
  16. ScouterDP
    Dana Point, CA
    Thank you. Anyone else have models to recommend or to avoid?
  17. bisco
    51,843
    go with mendel's, he's the battery king.(y)
    #17 bisco, Nov 3, 2015
  18. Mendel Leisk
    41,328
    Well, if you can find it. CTEK makes some newer chargers in the same range. But there seems to be a lot of CTEK 3300 in stock still. It's a good name, very hard shell case, and they come with a decent, Velcro flapped bag to contain all the cords.
    The 4.3's another option: newer, 4.3 amps, more charging stages, a little pricier too I think:
    Battery Chargers - CTEK Battery Chargers
  19. JimN
    7,028
    1,117
    South Jersey
    I use a BatteryMINDer for trickle charging. $30 on amazon, $25 on Northern Tool. Mendel's recommendation is more capable. You get what you pay for.
