  1. SwamppThingg
    SwamppThingg Active Member
    235
    443
    Mount Prospect, IL
    Does anyone know the best way to clean that out?
    I assume pulling the headlight out would be easiest.
  2. xliderider
    xliderider Senior Member
    8,091
    3,239
    Honolulu, HI
    Yes, pull the headlight housing out and look into the projector from the rear bulb mounting hole. You should only see lens and cutoff shield pretty much. Your problem sounds like there's something else above the cutoff shield obstructing some of the light.
  3. A.Reyes
    A.Reyes Active Member
    270
    178
    Beaufort, 29902
    It could possibly be the ground return wire. That should be at the 6 o'clock position.
    iPhone ?
  4. xliderider
    8,091
    3,239
    Honolulu, HI
    6 o'clock position, when mounted. He hasn't confirmed if he does indeed have the proper H11b bulbs though.
  5. SwamppThingg
    235
    443
    Mount Prospect, IL
    It's doesn't mention h11b, just H11. They're from xenon supply. And the ground is in the 6 o'clock position just like the right headlight which casts no shadow.
  6. xliderider
    8,091
    3,239
    Honolulu, HI
    Then the shadow isn't coming from the ground wire, something else is causing the shadow.
  7. SwamppThingg
    235
    443
    Mount Prospect, IL
    That's what I was saying. I'm just wondering how to go about trouble shooting what is causing it
  8. xliderider
    8,091
    3,239
    Honolulu, HI
  9. MPGRaja
    MPGRaja Senior Member
    469
    1,679
    Corona
    image.jpeg 1 year anniversary and I couldn't be happier
  10. SwamppThingg
    235
    443
    Mount Prospect, IL
    Where'd you get the accent covers for the fogs and turns?
    Would love those
  11. MPGRaja
    469
    1,679
    Corona
    Bought them from someone here on priuschat
  12. sonnyd510
    sonnyd510 Active Member
    94
    464
    Los Angeles
    @SwamppThingg You can find those fog covers here: PRIUS ZVW30 Specialty Parts Online Shop - Auto-Style USA - Japan Car Parts JDM Parts
    Speaking of fogs, I had mine installed alongside some new LED's in the housing for them, the headlights, park lights (SMDs) and replaced my signals with some Revier DRLs (factory tinted) to match the bug shield & headlight housing.
    On the fogs, I had the housing sprayed a matt black pre-install to match the DRLs so it wouldn't contrast (black/silver otherwise, and I'm not a Raiders fan).
  13. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Some recent photos. :)
    Burna J, TopRamen, sfv41901 and 6 others like this.
  14. monskie15
    monskie15 Junior Member
    Massachusetts
    Are those leonis navia wheels?
  15. Starbrand
    Starbrand Senior Member
    493
    1,502
    Westmont, IL
    im getting better at dipping... will probably redo mirror covers and few other parts of the car... and yes. I did them during preps and lunch while teaching today :ROFLMAO:
    ePrius, Burna J, Xterra72 and 5 others like this.
  16. ItZGr8t!
    ItZGr8t! Active Member
    75
    284
    IE
    Sharpie paint pen + steady hands
  17. MPGRaja
    469
    1,679
    Corona
    No, these are Enkei pf01
  18. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    Can I mail you my A-Pillars to get dipped? :LOL:
    Starbrand and saulbassfan like this.
  19. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Does that scratch off easy? More worried about that someone accidently scrap it with the nail.
  20. monskie15
    Massachusetts
    Nice looking!
