iPhone 6s and Entune??
Discussion in 'Gen 3 Prius Audio and Electronics' started by Xterra72, Nov 3, 2015.
  1. Xterra72
    Xterra72 Senior Member
    1,437
    1,681
    So I am going from a Samsung Galaxy S4 to an IPhone 6S.
    My S4 Bluetooth will connect to everything including Entune apps.
    However, the IPhone 6S will only connect to phone functionality.
    When I try to connect to any of the Entune apps, I get the message:
    "Connection failed. Ensure that Entune is running on your device"
    So my question is, is this a common problem? Any fixes?
    I've read that the only way to connect an iPhone without having to use the usb cable is to tether it to your iphone via mobile hotspot. That is crazy.
    I don't want to use the usb because I already have my iPod connected to it. This has my collection of songs that will not fit on my iPhone.
    Is there someway to creat a usb hub to run both iPhone and iPod?
    If anyone has a solution please let me know.
    If I can connect the 6S via Bluetooth, that would be my ultimate goal.
    Thanks guys.
  2. Yakuzahi
    Yakuzahi Junior Member
    85
    Long Island NY
    T
    https://securedp.toyota.com/download-app/toyotaHeadUnits
    Try to install the above update and see if it will fix the problem.
    I did it and it fixed some of the issues I had with Unknown callers.
    #2 Yakuzahi, Nov 6, 2015
  3. Xterra72
    1,437
    1,681
    Do you have an iPhone 6S??.This is only an issue with the iPhone mostly the newer ones
  4. Yakuzahi
    85
    Long Island NY
    Not at the moment. Just give it a try.
  5. Xterra72
    1,437
    1,681
    Unless the link you gave me is an update to the current update, I've already done this upgrade. Thanks anyways.
    When I called support they said that I do have to have Bluetooth on and usb connected to work entunes with an iphone
