Net Zero (house and two cars) in Minnesota
Discussion in 'Environmental Discussion' started by Zythryn, Nov 9, 2015.
  1. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    Hey all, I would love to hear any suggestions, ideas, or discuss any aspects of our net zero home, currently under construction.
    Our website is at Driven to Net Zero - Home
    The direct link to the blog is Driven to Net Zero - Blog
    The definition of "net zero" we are using is a house that produces as much energy as it uses on an annual basis. We have, however, added a twist.
    The twist is, that we include the energy we use to drive our two electric cars.
    We are having a lot of fun, and I have learned a lot about building a house. We are at about the halfway mark this week.
    Geothermal wells are in, tubing is roughed in to the mechanical room.
    Solar array is planned, but not yet installed.
    Insulation started last week and concrete is curing.
    I'd be happy to answer any questions here, or at the site.
  2. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Sounds wonderful. I hope one day all building codes require net zero, as a transition to net plus. :)
    pilotgrrl likes this.
  3. Zythryn
    6,408
    4,407
    Net Plus would be nice.
    I believe some countries are moving in that direction (requiring net zero).
    I suspect we will get to net plus when we trade in our Model S for a Model 3.
  4. Zythryn
    6,408
    4,407
  5. Zythryn
    6,408
    4,407
    Well, it has been a while, many more delays than we expected, but the house is nearing completions! About 6 weeks to go.
    But the solar is being installed!
    Racks are up on both house and garage. Wiring and optimizers are in place for the house.
    Two inverters are in place on the outside of the house, and one is being installed downstairs.
    Unfortunately, we have rain and thunderstorms the rest of today. Monday we should see more activity.
    Jon Senum, iplug, hyo silver and 2 others like this.
  6. Zythryn
    6,408
    4,407
    Today was a very big day!
    It started with a power outage for the neighborhood:(
    Work at the house is moving forward, but slowly, we are still at least 3 to 4 weeks out.
    However, at about 1pm today, our utility installed our production meter and a net metering meter. Our panels are producing and feeding into the grid!
    We don't have internet yet, as soon as we do we will be measuring the energy draw of a number of parts of the house (HVAC, sump pumps, EVs, large appliances, etc).
    Jon Senum, hyo silver, fuzzy1 and 2 others like this.
  7. Eastside
    Eastside Member
    129
    82
    NorthVirginia
    You may want to sign up with these folks. Fat Spaniel Technologies | Power-One
    “ . . . Founded in 2003, Fat Spaniel Technologies is the leading independent provider of critical monitoring and reporting services for the renewable energy industry. “
    10/24/2016 - Update. FatSpaniel was bought out by Power-One. Then, ABB bought Power-One in 2013, taking the business global.
    #8 Eastside, Jul 6, 2016
  8. tochatihu
    tochatihu Senior Member
    9,850
    3,806
    Kunming Yunnan China
    2001 Prius
    "...we borrow it from our children". Everyone here likes what Zythryn is doing, Might I stretch this out a little bit. With detail, what structures might be of most use to folks 50 or 100 years later, and why?
    hyo silver likes this.
  9. Zythryn
    6,408
    4,407
    IMG_0371.PNG Well, we have been in our house about 6 weeks now.
    Our energy monitoring setup has been in place about 3 weeks.
    Just like the Prius' instant mpg feedback helped me be a more efficient driver, this system (eGauge) has already helped me with energy efficiency around the house.
    One of the bigger surprises was that our LED light strip is drawing 80 Watts. While I knew it was a long strip of lights, I didn't realize it was drawing that much until I saw it on the graph.
    We are much more careful about turning that off when not needed :)
    I have more details about the eGauge system in my latest blog at Driven to Net Zero - Blog
    It is rather cool to see how the morning shading affects our different solar arrays (3 inverters). Each is represented in the image by one of the dashed green lines.
    The lowest generating solar inverter on the left of the graph are panels on our garage roof. These have some shading in the early morning (shaded by our house roof). Just after 9:15 that shade starts disappearing and it quickly takes the number 2 spot.
    I'm hoping to set up a system that will set synchronize the car charging with the amount of solar energy being generated.
    I have a couple of friends that have already done this, so it shouldn't be too difficult.
    Above, the bulk of the energy draw starting about 9:20am is me charging my car.
    One of our inverters though is intermittently resetting itself.
    This was happening so often that inverter was only generating 80% of the power it should have been.
    After a firmware upgrade, it is up around 98%, but we are still trying to nail down exactly what is happening and why.
    #10 Zythryn, Oct 23, 2016
    tochatihu likes this.
  10. Zythryn
    6,408
    4,407
    Well, the last architect event this year is happening Thursday, and with winter approaching it will soon be time to turn on the heat.
    In another thread, which I can't find at the moment, someone was very sceptical of using electricity for e geothermal pump being efficient.
    I believe it was off topic there, so if you come across this, let's continue that conversation here.
    For anyone, in general, we came to the conclusion the ground source heat pump was our most efficient route after considering:
    1) We didn't want to use any natural gas.
    2) Air to Air heat pumps don't work very efficiently in Minnesota winters.
    3) Our house is designed to be extremely well insulated/sealed.
    4) With the 'passive solar' design, much, if not all, of our heating on sunny days is taken car of naturally.
    Our ground source heat pumps supply all of our heating and cooling needs. No backup system is required for those cold MN winter nights.
    Waste heat from the geothermal pumps is shunted to a preheat water tank for our domestic hot water.
    To test out the system, I switched in to 'winter' mode yesterday.
    The standby power draw seems to be 50Watts.
    Of course, until the system is actually heating, we won't see the peak draws. This weekend we are expecting the first snow of the season, so we may need some mechanical heating then.
    Eastside likes this.
  11. lensovet
    2,615
    496
    Burlington, NJ
    Did I miss a blog post with more details about the geothermal setup you have? Really curious how that works and the process of engineering that.
  12. Zythryn
    6,408
    4,407
    Well, I messed up there...
    Seems when I turned the pumps over to heating mode, a group of formerly dormant in-floor sensors and simple thermostats turned on.
    I didn't even think to check on these, and they were set between 70 and 74 degrees.
    The temp in the house is generally in that range, but different zones were calling for heat, not from our programmable thermostats that measure the air temp, but the simple static thermostats that measure each zones floor temps.
    Now that those are correctly set, the standby power on the thermostats is 9 Watts.
    First snow yesterday, and all week is supposed to be in the 30s (0-5C). With only one sunny day in the forecast, this week should be the best test we have had yet!
  13. Zythryn
    6,408
    4,407
    I'm not sure what you have seen ;)
    However, here is a link to one of the site's pages that discusses it a bit: HVAC - Driven to Net Zero
    And here is a blog entry about the insulation, heating tubes, and geothermal: Category: GeoThermal - Driven to Net Zero
    In any of the blogs, over on the right side of the page there are tags for different aspects of the house (e.g. Geothermal, thermal mass, solar, etc).
    The only work I personally assisted with was some of the electrical work, and it wasn't much beyond running wire and stapling it.
    So my ability to answer in depth questions about the engineering process may be limited, but I will do my best:)
    fuzzy1 and lensovet like this.
  14. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,691
    Somewhere in Wisconsin
    2013 Chevy Volt
    I really wish the building code folks would ditch the I don't feel it's legal bs so I could build my square 1.5 story straw bale small home I have had laid out for a decade.
    The affixed unheatef "green house" / sun room enables mostly solar heat, only about 1500 watts would be needed to heat in winter.
    I love the idea of using natural renewables and minimal outside energy
    Zythryn and fuzzy1 like this.
  15. fuzzy1
    10,590
    Having installed a ductless minisplit in my home seven years ago, a heat pump water heater three years ago (both by pros, not DIY except electrical), and helped with a ground source heat pump system on dad's house a year ago, I can help answer some questions too. As long as they aren't deep into the engineering.
  16. Mendel Leisk
    41,828
    I think just adhering to existing codes would help immeasurably. When I had a look at the return and heated air circuits of our forced air furnace, they were a total mess, from the get-go. We were here over twenty year before I took the time to look at it; sad, the slipshod construction that "passes" inspection. :mad:
    RCO likes this.
  17. bwilson4web
    16,332
    We took out the 40 year old evaporator when we put in the high efficiency gas furnace and never looked back. Zone A/C is the way to go.
    Zythryn likes this.
  18. fuzzy1
    10,590
    Just wandering through neighborhood house construction projects while framing was still open, I have found enormous variations in build quality. While most were generally decent, a few were awful with junk wood un-reinforced in important places, crushed and severely crimped ducts, ducts sloppily taped with cheap 'temporary' tape, etc.
    One group of houses was particularly good, so much so that we bid on one them. But we were not up for the bidding war against immigrants from California who had just sold Bay Area homes. In hindsight, our 'starter' home has been all we really need, much cheaper to maintain, and I've been able to upgrade it to a Net Zero house.
  19. Mendel Leisk
    41,828
    Pretty much total lack of responsibility in the inspection process.
