Intake Manifold Gasket Leak ? Toyota Prius 2010
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by C Athula, Nov 29, 2014.
  1. C Athula
    C Athula New Member
    Colombo
    Dear Members,
    I have a prius gen 3 (2010) with the mileage of 65,000 KM. Recently the car has started indicating the error code P0171 (System Too Lean Bank 1).
    I did below mentioned tests as recommended by the mechanic, replaced the air filter, checked the spark plugs, throttle body cleaned, checked for vacuum pipes for any leaks (except the injector cleanup).
    Unfortunately, still i am getting the error even when it is erased from the ICU.
    After resetting the error, it is not showing until the engine gets wormed-up into some level. From the engine cold start, i can run the car about 15 - 30 mins with the engine power without the MIL indication.
    Today, I did notice something in-between the intake manifold and engine head (Orange color rubber part), i think it should be the manifold gasket but I am not too sure whether this is normal and causing the error.
    Appreciate the kind help in this and thank in advance for all the members.
  2. C Athula
    C Athula New Member
    Colombo
    Adding HD video for clear view
  3. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    That's the gasket and its normal, if you want to try locating a intake leak (not a common problem), you can try spraying carburetor cleaner around the intake area and listen for a idle surge (engine running of course).
    I would try cleaning the maf sensor with CRC maf cleaner, its located on the upper right hand corner of this picture of the air box.
    Ebay picture link below:
    2010 2013 Toyota Prius Air Cleaner Assy Airbox Intake Mass Air Flow Sensor | eBay
  4. Former Member 68813
    3,524
    983
    US
    I had 2003 corolla with the same problem and had to replace the intake gasket to fix it. However, it was a very common problem in that car as they used a defective gasket in the factory. Since it's a rare issue in Prius, the problem or may or may not be the intake gasket. While the gasket is cheap, it takes some time to replace it. You need to check/clean MAF, check for any intake leakes downstream to MAF and any exhaust leaks upstream to oxygen sensor first before attempting to replace the gasket.
  5. C Athula
    C Athula New Member
    Colombo
  6. C Athula
    C Athula New Member
    Colombo
    Thank you my dear members. I think it is worth trying both options. I'll give you update later.
    kevtan likes this.
  7. C Athula
    C Athula New Member
    Colombo
    I did clean all the stuff.... including EGR and piping which was clogged very badly. I took the entire intake manifold and its attached components out, such as sensors, throttle body, EGR piping and valve. of course the EGR valve was heavily blocked including the piping and tiny breathing halls in the intake manifold which mixes the cold air with exhaust air was also partially blocked. .....so i did clean them well and assembled them back and make sure any intake leaks not to happen. So far this is what i did.
    1.) Cleaned the air Flow Sensor,
    2.) Cleaned kind of a sensor mounted to the intake manifold (may be the heated air sensor, not sure)
    3.) Replaced a new air filter.
    4.) Checked and clean all the spark plugs with suitable sparking gaps.
    5.) Cleaned the EGR valve.
    6.) Cleaned EGR piping.
    After fixing all these I ran the car in my usual daily routine and i feels there is a slight improvement in the performance.
    However, appearing the MIL (p0171) was not resolved but the frequency of appearing it has reduced.
    As i noticed, most of the occasions where the car is moving just above the ECO line with the slight engine power (just above the middle line of the EV to Engine Power display) this is happening.
    Can someone tell me any area to check ?
  8. tv4fish
    tv4fish Member
    202
    46
  9. C Athula
    C Athula New Member
    Colombo
    Dear Friends,
    I think i have found the problem which is really an unexpected situation at this level of millage of my Gen III prius (2010 - 62,000 Km).... i never thought that fuel injectors can be blocked this early. 20141213_093312.jpg
    edthefox5 likes this.
  10. bisco
    52,398
    you must get some seriously bad fuel down there. is there a fuel filter? i wonder if a bottle of fuel treatment every now and again would be helpful?
  11. C Athula
    C Athula New Member
    Colombo
    Soon after cleaning the injectors, the engine started to perform like a new, no error codes anymore Got the best millage after longtime 22.6kml (53+ MPG) in regular driving...!!!
  12. frodoz737
    frodoz737 Top Wrench
    4,722
    2,517
    33
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Wow. Better pictures of the pintle area of the injectors please. They look really dirty. Maybe byproduct of the EGR sludge? That EGR sludge is a known issue and man it gets really clogged up doesn't it? So maybe good idea if you clean the EGR take a look at the pintles also. Very good stuff thank you.
    Don't understand why no misfire though. That will throw you off the path for sure.
    Good find!
    C Athula likes this.
  14. cocot007
    cocot007 Junior Member
    Bronx NY
    2003 Prius
    How did you clean them?
  15. Mendel Leisk
    41,923
    I'm wondering if the badly clogged EGR could be the cause of the clogging injectors. Clogging EGR is starting to look like a regular, inevitable issue with 3rd gen.
  16. Patrick Wong
    18,210
    6,514
    Good to hear you figured out your car's problem.
    It is interesting to see the RHD JDM model display in your photo is the mirror image of the LHD North American display with regards to the location of the fuel gauge and speedometer, vs. the hybrid drivetrain power indicator and traction battery state of charge gauge.
  17. wetback1
    wetback1 Junior Member
    Courtenay, B.C. Canada
  18. kevin75
    kevin75 New Member
    palo alto
    Hello I have same problem.Could you please show how did you take out injectors ?..Thank you
  19. Prodigyplace
    12,682
    11,833
    Central Virginia
    You will not get a response. That user has not been here for 3 years.
  20. Mendel Leisk
    41,923
    Here's the section from the Repair Manual, covering fuel injector removal, inspection and install. You apparently need to remove the EGR valve and cooler for this, so I've attached that as well.
