When the 12V battery dies and you need to get to the battery....
Discussion in 'Gen 2 Prius Technical Discussion' started by Bob Greenough, Nov 14, 2015.
  1. Bob Greenough
    Bob Greenough Junior Member
    Laguna Hills, Ca
    Problem: I left a dome light while in the airport parking lot when I went on week long trip. When I returned the 12V battery was dead.
    Question: How do you get to the 12v battery in the rear of the car? Rear hatch will not open without power.
    Using the key to get in the drivers door, I had to get someone to crawl over the back seat and connect cables to jump start the car.
    What am I missing? Is there a better way to jump start the car? Is there another way to open the rear hatch without the 12v battery power?
  2. JC91006
    JC91006 Senior Member
    16,762
    8,562
    There's a jump point in the front of the car. There's also a manual lever to open the hatch, but you would still have to crawl to the back to access it.
    Bob Greenough likes this.
  3. Bob Greenough
    Laguna Hills, Ca
    Thanks for the prompt feed back. I will look for both.
    Where, approximately is the manual lever for releasing the hatch?
    Thanks again.
    Bob
  4. Bob Greenough
    Laguna Hills, Ca
    After reading your post I did go and look a little closer and found the lever you were speaking about.
    I appreciate your time in providing this feedback.
    Thanks again, you have been helpful.
    Bob
  5. Mendel Leisk
    41,326
    The under the hood jump point is in the fuse box. It's got a red, hinged cover. You depress a tab, pivot back the cover and you have a copper bar to clamp positive lead too. There's a protruding bolt just to the left (EGR valve hold-down bolt) that's good for connecting negative lead.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Be aware the little AGM 12 volter when discharged at such a perfectly low rate and then allowed to sit dead for a week will certainly sulphate that battery beyond repair.
    Its done.
    Get a new battery installed asap. Subjecting a Prius to jump starts on a stone dead battery is very very dangerous to your wallet.
  7. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    You really should read the manual for the two specific solutions to your exact questions.
  8. Bob Greenough
    Laguna Hills, Ca
    Thanks again for the info. I posted a picture of the connector in the fuse box.
    Andyprius1 likes this.
  9. Bob Greenough
    Laguna Hills, Ca
    Thanks for the information. I posted a picture of the latch (See silver arm in Pic) that you directed me to. Thanks.
