Head Up Display (HUD) does not working!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ahmad Babaa, Nov 14, 2015.
  1. Ahmad Babaa
    Ahmad Babaa New Member
    Jordan
    Hello everyone, I am new here and hope to find a soloution for this problem . My prius HUD stopped working suddenly even though everything is ok and my main dashboard and sppedometer are working perfectly .
    the HUD switch light up when I turn it on but nothing on the screen ! ? any suggestion or help .
    Thanks all
    52,188
    welcome! is there a fuse?
  3. Ahmad Babaa
    Jordan
    I don't know! If there is one , please tell me how to replace it . Thanks
  4. bisco
    52,188
    me either. do you have an owners manual?
  5. Ahmad Babaa
    Jordan
    unfortunately NO.
  6. bisco
    52,188
    you might be able to find one online, search here for threads.
  7. Colin Jones
    Colin Jones Member
    99
    174
    Aberdeen/UK
    Business Edition
    I think if it were the fuse a lot of other stuff would not be working either, as it is shared with various other systems...
    Check however that you have adjusted the position correctly. You can adjust HUD up and down, and if it's at one extreme or the other, it may not be possible for you to see it, depending on your height.
    Use the buttons described here to adjust the HUD position:
  8. ETP
    2,802
    1,170
    Auburdale FL
    Also dash matts will slip and block the view
