P0A0D Code after battery replacement. Won't go away please help!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by fuqya, Nov 11, 2015.
  1. fuqya
    fuqya New Member
    baltimore
    Ok so I am a technician and my boss owns a couple of prius taxis. One of them had the code to replace hybrid battery pack. After checking all the cells and they were all in spec the code came back every single day so he bought a new hybrid battery pack. After installing the new battery pack The car wont go into ready mode with the message check hybrid system. The code that comes up is P0A0D about the service safety plug. It is plugged in properly pushed all the way to the right and so on. The 120 amp fuse inside of it is good I have tried everything I can think of.We had another 2010 in the shop I tried changing the service safety plug, engine ecu, hv ecu, all to no avail with the same problem. If anyone can help it would be greatly appreciated. Thanks a lot in advance.
    51,950
    welcome! most people miss the last step in the plug. have you looked at the youtube video?
  3. Besik Mukhiashvili
    Besik Mukhiashvili Junior Member
    Tbilisi, Georgia
    If you look closely to service safety plug there is additional small contacts. This contacts are used to inform hv ecu that plug inserted correctly. Please check wires from hv ecu to service safety plug socket. (check small additional pins not HV terminals)
  4. mrbigh
    3,686
    699
    Long Island, NY
    Make sure the safety orange plug is properly seated. Then reset the CAN code with an scaner.
  5. fuqya
    fuqya New Member
    baltimore
    Yes. It is properly seated I see the other connection to inform the ecu that the interlock is fully inserted. Unfortunately my problem is not that easily solved.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Just because you can "see" the connection does not mean that it is made. The DTC is telling you that it is not getting the proper input. Check the connection with a voltmeter to verify.
    Not seating the safety plug correctly is the number one problem we hear on here.
  7. fuqya
    fuqya New Member
    baltimore
    I meant that I can see it as in I know that it is there. I have tested it and it is receiving the proper connection all the way to the HV ECU...
  8. fuqya
    fuqya New Member
    baltimore
    Any ideas?
  9. JC91006
    JC91006 Senior Member
    16,769
    8,567
  10. Presurized
    Presurized New Member
    TN
    Does anyone knows if this case was resolved?
  11. JC91006
    16,769
    8,567
    Look at post #9
    m.wynn and Raytheeagle like this.
  12. Presurized
    TN
    Yeah, That did not fix it for me, So far traced it to a broken connection between the main disconnect (the interlock) at the battery and the Hybrid Vehicle Control ECU. I was hoping someone else had the solution but In the process of trying to find the problem i noticed traces of squirrels, So i am pretty sure its a wire somewhere in between.
  13. Presurized
    TN
    SO, i feel like i need to share this. I feel i have found my problem, There is a plug a the back of the car by the battery fan that had corrosion in it, I disconnected it cleaned most of the corrosion, added some dielectric grease and reconnected it, Now the car magically works as expected. It has been 2 days and is still working, I do not know what exactly goes through that connector yet (Big plug 4 wires) 20170812_162158.jpg If anything changes i will share but as of now its fixed!(y).
    i just wonder why is it corroded...:confused:
    I share this just in case someone else find themselves with this problem, Hope it helps someone!:)
  14. bisco
    51,950
    congrats and thank you!(y) corrosion is prius middle name.
  15. RSailor
    RSailor Junior Member
    Cupertino, CA 95014
    Oh thank you great one! This image has saved me so much coin I must worship the ground you walk on. The car will not start unless the “bale” is closed AND slid into the locked position!
    The hybrid battery replacement vultures were circling. My OBD app does not show P0A0D on my 2010 Prius. I downloaded Dr. Prius on iOS which did.
    #15 RSailor, Jul 30, 2019
    Old Wrench It and bisco like this.
  16. Lang
    Lang Junior Member
    Port Townsend
    Wanted to post up the cause of the corrosion, right where the lift supports are mounted to the body of the car get flexed over the years, and end up cracking the factory seam sealer. Water travels through the cracks, into the body, and drips onto this perfectly placed connector. The fix? Clean up the channel with some soapy water, remove the lift support, and get yourself some 3M Drip Check Sealer. Goodluck!
    Old Wrench It and SFO like this.
  17. 473 Prius v
    473 Prius v Junior Member
    27
    Grenada
    2014 Prius v wagon
    Can I please get some help with my 2014 Prius v ? It’s not going into ready mode and I’m getting poaod code I tried the safety plug but that don’t seem to be the issue. Any idea?
  18. ChapmanF
    18,215
    The P0A0D code indicates an open somewhere in the safety interlock circuit, which includes the small side contacts on that safety plug, and also includes some contacts under covers on the inverter under the hood. It's a simple circuit, runs from a pin of the power management control ECU, through all of those contacts, to body ground. So when all of the safeties are properly in place, that ECU pin is grounded; if it isn't, you get the code.
    Naturally, an open anywhere in that circuit will give you the code; it doesn't have to just be one of the places the cover or plug safety contacts are. A break anywhere in the wire connecting them would have the same effect.
    To get to the safety plug contacts, the circuit also passes through a wire harness connector that someone probably disconnected while swapping the battery. Did that get reconnected?
    If it isn't that, a person just takes an ohmmeter and starts tracing the circuit, finds the spot where it conducts to ground from one side of the spot but not from just past it, and then fixes that problem, whatever it turns out to be.
    Brian1954 likes this.
  19. 473 Prius v
    27
    Grenada
    2014 Prius v wagon
    Thanks for the help it most likely is a damaged wire because I checked all the connections and they are good. Is there any possibility that I missed a fuse or relay they might’ve gotten damaged I checked the one in the fuse box but I was told there is a 125 or 140 amp fuse link but I just don’t know where to look for it
  20. ChapmanF
    18,215
