Need buy one tire cause of stupid nail. Ok buy just one? Prius has 15k miles
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nanoxnano, Nov 15, 2015.
  1. nanoxnano
    nanoxnano Junior Member
    26
    So last night I got a nail on my back tire (passenger side). Luckily it happened right before the Tire Shops closed and the news was, it is not repairable cause it is too close to the sidewall. My 2015 Prius (Model: II) only has 15k miles. Is it okay to buy just one (same exact tire, Ecopia EP20), or do I need to buy two tires.
    52,093
    one is fine. put them on the rear until the next rotation.
    GrGramps likes this.
  3. nanoxnano
    26
    Do you think my mpg will be affected by a lot having one brand new tire in the back?
  4. Former Member 68813
    3,524
    983
    US
    IMHO, this is an excuse to sell you new tires. Last time this happened to me, i purchased $8 quality tire repair kit, and used it several times now saving $$$.
  5. Mendel Leisk
    41,643
    How close to the sidewall, did they show you? I've been told that, with a finishing nail 1" from the edge of the tread, decided what the heck and plug repaired it. About 3 years back, no problems.
    I appreciate it's frowned on, but it worked for me.
  6. bisco
    52,093
    no, it won't affect your mpg's.
  7. JC91006
    JC91006 Senior Member
    16,780
    8,575
    Any nail that is not on the very edge of the tire or on the sidewall, is repairable. If the shop refuses to repair it, then just buy 1 tire, they might even have a good used tire to sell you.....
  8. CR94
    CR94 Senior Member
    2,709
    1,178
    Northwestern S.C.
    It will affect fuel consumption, but only insignificantly, about ¼ as much as replacing all the tires with new ones. Why worry about that?
  9. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Buy 2, they are almost 50% worn, put the new tires on the front.
  10. nanoxnano
    26
    Ok here are the photos. Is this ok to repair??
  11. usnavystgc
    3,159
    990
    Tucson, AZ
    Oh hell yes that's ok to repair and you can do it yourself. Installing a plug in a tire is about the easiest thing you can do. Buy a plug kit from your local auto parts store or Wal Mart and follow the instructions.
  12. Mendel Leisk
    41,643
    I would, just DIY plug repair.
    I've had a couple of punctures, both more-or-less exactly as you show, except near the outside edge. One was a small finishing nail our OEM Michelin Pilot's, the other a somewhat larger bolt in our Michelin X-Ice snow tires. Both repairs have held up fine.
    I got one of these kits, for around $60 I think:
    Kt-340 - BlackJack Tire Repair
    It'll last a lifetime. Or you can get a cheap but effective kit at Walmart for around $10.
    Check on Youtube for tire plug repair videos. You basically:
    1. Remove the nail.
    2. Ream the hole with reamer tool.
    3. Thread plug through needle eye of plug repair tool, about half it's length, and apply a little goop to it. *
    4. Push the needle through the puncture hole. This takes some effort, especially with tire partially deflated. Once you get through, push in until there's only about 1/2" of plug still protruding.
    5. Pull the needle back out quickly. This is the magic part: the plug slips through the slot in needle tip, leaving a loop inside the tire.
    6. Cut off excess plug with razor blade or what have you.
    * It's worthwhile to do this step in advance of steps 1 and 2, to reduce the time air is leaking freely out of the tire.
    #12 Mendel Leisk, Nov 16, 2015
  13. Former Member 68813
    3,524
    983
    US
    this is a very common location for nails/screws, especially in city driving. i repaired several tires like that including almost a new one in my prius.
    weird, pricy and no glue. i prefer the vulcanizing ones that are rated as permanent repair for $10 for 6 plugs.
    the cheapest ones are at HF: $5 for 5 plugs: 9 Piece Tubeless Tire Repair Kit
  14. nanoxnano
    26
    Thanks! Save me couple bucks! :)
  15. Mendel Leisk
    41,643
    The Black Jack kit comes with 20 small and 20 large VERY tacky plugs, and a tub of some sorta goop. Very solid handles on the tools, and nice case. The needle's replaceable, and a spare is included. The goop tub has hexagonal walls, sits in a similar recess, you so can unscrew the cap with one hand, it's locked in there.
    All depends on what you want to spend.
    #15 Mendel Leisk, Nov 16, 2015
  16. fuzzy1
    10,520
    The cost of that 40-plug kit would keep me away, especially when 37 or 38 of them will be wasted by aging.
    At my household's normal rate, only a couple plugs will ever get used before the kit is too old. The 4 to 6 plugs in the small kits are plenty.
  17. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Never Mind.
    Plenty of answers here.
    I need coffee....
    Good Luck.
    #17 The Electric Me, Nov 16, 2015
  18. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Yikes. Never go back to that shop again. I've got a repair at that location on one of my front tires right now.
    If you have an America's Tires near you, I'd suggest going there. They patched me up for free despite not buying the tires from them. They patched me up despite the dealer not being able to identify the source of the leak. Guess who I went to replace the tires when they wore out.
  19. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    If you post a more specific location in your profile (ie San Francisco, Los Angeles, etc), we might be able to suggest better tire shops.
