can I put 195/60r15 tires on my prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by krystalstorm, Nov 23, 2015.
  1. krystalstorm
    krystalstorm Junior Member
    coatesville pa
    can I put 195/60r15 tires on my prius, technically there supposed to be 185/65r15. bur i've been told small differences don't matter. is this true?
    #1 krystalstorm, Nov 23, 2015
  2. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    It is my understanding that it's OK to do what you intend. Folk with more expertise than I will most probably chime in, but I think you're OK to put 195s or even 205s on. Good luck, and welcome to PriusChat! :)
    Daves09prius likes this.
  3. bwilson4web
    16,330
  4. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    I just put size 195/60 15 on my 2006, no issues. 205/60 15 is supposed to make your mph closer to actual speed.
    TomK
    #4 kutcht1, Nov 24, 2015
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    yes 205/60r15 is the best choice. accurate speedo and extra traction. I would not recommend sticking with the lousy GY integritys though. some of the worst tires I've ever used.
    Daves09prius and kenoarto like this.
  6. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    The 205/60 15 tires are 24.6" circumference while 195/65 15 tires are 25" circumference, my garmin agrees with my vehicle speedometer when I run 195/65 15 tires, does yours when you run smaller circumference tires?
  7. Mendel Leisk
    41,824
    Wrong generation, oh evil overlord.
  8. 69shovlhed
    2,170
    752
    Delaware
    I don't have a garmin, but since the oem 185/65r15 are shorter than 205/60's, the speedo is more accurate with the 205's. the only evidence I have is the radar speed signs which our local govts. like to use to keep us from speeding (it doesn't work). with oem 185's, my speedo will read 1-2 mph faster than the sign tells me I'm going. with 205/60, its usually right on.
  9. Lucifer
    1,014
    486
    Nh
    Right, on my '06 the 205/60 15 tires are 24.6" circumference while 195/65 15 tires are 25" circumference, my garmin agrees with my vehicle speedometer when I run 195/65 15 tires, does yours when you run smaller circumference tires?
    Thinking you should be ignored;)
  10. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    My best experience was with the 205/60/R15, until I switched to my new rims. The small tire size might be less money, but I'd spend the extra few dollars to get the 205's.
  11. 69shovlhed
    2,170
    752
    Delaware
    I guess if accuracy of the speedo is very important to you the 195's might be a better choice. the 205/60 probably handles a little better, and definitely looks a little better too. sure wish I could have fit those 225's I got with my traklites... just couldn't bring myself to modify the wheel openings.
