I get to play with a 2016 Prius Four!
Discussion in 'Gen 4 Prius Main Forum' started by tmacrp, Dec 1, 2015.
  1. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Not in the Socal desert!
    Light grey is optimal to hide grey dust and dark finishes are a disaster.
    52,373
    i'll be surprised, with the price of gas, if you can't get a discount by next spring.
  3. tmacrp
    tmacrp Junior Member
    74
    47
    Santa Rosa, California
    Yeah... our dealer isnt marking them up and don't see a lot of dealers doing so...
    The ones that do are the ones that markup a Camry or a Corolla.... (n)
  4. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    Lmk when yall have pricing...
    tmacrp likes this.
  5. akhare
    akhare Member
    47
    53
    My dealer said that the default Softex color is likely to be a true black (as on the RAV4). My guess is that Dark Gray / Misty Gray are available as well (in addition to the Harvest Beige), but it seems like the true black might be a good stark contrast to the white areas.
    Anyway, he should have the specific details over the next few days, so let's see.
  6. Netcub
    Netcub Active Member
    344
    170
    Kentucky
    He should have had the Specific Details last month...
    Interior Colors
    1. Moonstone
    Fabric on Prius Two, Prius Two Eco and
    Prius Three
    SofTex® on Prius Three Touring, Prius Four
    and Prius Four Touring
    2. Black
    Fabric on Prius Two, Prius Two Eco and Prius Three
    SofTex® on Prius Three Touring, Prius Four and Prius Four Touring
    3. Harvest Beige
    Fabric on Prius Two, PriusTwo Eco and Prius Three
    SofTex® on Prius Four
    snipercoder and TonyWilkey like this.
  7. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    All the sight lines, especially what were the blind spots in Gen 3--side rear, both sides. Others (though not me) had troubles with the front oblique views because of the pillars.
    How well the safety technology works to deal with whatever blind spots remain.
    How well the safety technology works for the other stuff it's supposed to do. (No, I'm not asking you to almost get in accidents to see . . . . . .)
    As someone who is rapidly getting old, this is important for my next car.
    Thanks!
  8. tmacrp
    74
    47
    The sight lines, especially up front, is greatly improved!
    Safety tech works really well. The ICS actually brought me to a stop a couple times while we were moving it in with cover on. Comes up with a BRAKE warning too!
    The adaptive cruise only works full speed of a car is in front of you. Once a car moves and you're going less than about 25 it'll pause the system.
    kgall likes this.
  9. kgall
    kgall Active Member
    984
    152
    Thanks!
    How did the blind spot cameras work? Or did you get a chance to test them?
  10. Mendel Leisk
    41,889
    There's for sure no 12 volt outlet (cigarette lighter port) in the front, in the dash?
  11. Netcub
    344
    170
    Kentucky
    The adaptive cruise works all the way down to a complete stop, at which point you can tap the throttle, or hit resume on the stalk.
  12. bisco
    52,373
    for sure? i thought there was? i thought there wasn't one in the hatch.
  13. Netcub
    344
    170
    Kentucky
    It's not "in the dash" it's on the console near the armrest. There's also another for the rear passengers.
  14. bisco
    52,373
    thanks!
  15. Tideland Prius
    16,615
    It's between the cupholder and the centre console box. The 2nd one that used to live inside the centre console box is now at the rear of the console box for rear passengers. I don't understand why Toyota can't just offer a USB port to charge. It's universal and almost everyone has a USB charging cable. A 12V outlet means you need to buy a "car charger" or an adapter that has 12V-to-USB.
    bwilson4web likes this.
  16. Mendel Leisk
    41,889
    I was thinking for a garmin. It might have a usb power cable too, not sure. So outlet a bit of a stretch. Suppose you could just wire one in, under dash. So much cobbling tho.
  17. Trollbait
    12,676
    Yeah, I think most car GPS systems are a 12v plug, and so are most small inverters. The 12v is also needed for those high profit smoker's package:rolleyes:.
    A cheap, 12v to USB adapter is easily found. Not pretty, but less work than wiring in an outlet.
  18. bisco
    52,373
    and you need it for the goop compressor in the 'no spare' models, when you get a flat on a cold rainy night in nowheresville usa. there must be a usb somewhere, maybe still inside the console box?
    Trollbait likes this.
  19. Trollbait
    12,676
    But can it charge. The Sonic has a USB port in the glove box for a music stick, but it isn't powered for charging.
  20. bisco
    52,373
    i'm sorry, i meant the 12v outlet. that's why usb isn't the only thing necessary.
    looking at the interior pics, there seem to be two, behind the rear upholder near the center console box. one of each?
