Car sits for 4 weeks: problem?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by sillylilwabbit, Dec 7, 2015.
  1. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    As you can see from the picture above, the car has been sitting around for a long azzz time.
    Sept: 8 miles
    Oct: 1 mile
    Nov 1st?: 1 mile
    Nov 17th: 4 miles
    Dec: 0 miles
    Fast forward to November 17, 2015: I test drove the car and put 4 miles on it.
    Fast forward to today, December 7, 2015: the car has sat for an additional 4 weeks since November 17th, and will continue to sit for an additional 3 days'ish or until I pick it up from the dealer lot.
    My question: will there is a problem from the car sitting for so long based on the pic above?
    Will there be any problems for sitting an additional 4 weeks since the last time I test drove it?
    Is there anything I should know, be concerned about or look out for?
    The car is a 2012, so it is 4 years old, however, it has only been used for 3 years of the 4. Don't know how long the 12v battery would last considering it has only been used for 3 years and the car has been sitting for so long.
    Thanks in advance.
    #1 sillylilwabbit, Dec 7, 2015
  2. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Four weeks should not be a problem except for any issues with the 12v battery. If it starts up normally you are good to go.
    sillylilwabbit and fotomoto like this.
  3. sillylilwabbit
    405
    118
    Los Angeles
    2014 Prius Plug-in
    Thanks for the response.
    That was my main concern, the 12v battery being leached on for so long during those months of inactivity.
    I just don't know how it would get recharged without being driven a decent distance.
    Hopefully everything will be ok when I get there.
  4. srl99
    srl99 Member
    113
    2014 Prius Plug-in
    I'd also make sure the dealer isn't going to charge you for storage.
    sillylilwabbit likes this.
  5. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    No driving necessary....Just leave the car parked in the driveway in ready mode for 30 minutes and the 12v will get a good thirty minute charge!
  6. Mendel Leisk
    41,863
    If a car's sat for a protracted time, a bit of idling in the driveway is not going to be enough. Just add a smart charger to your tool kit: it can be used as a maintainer, or to restore a neglected battery.
  7. ETC(SS)
    7,332
    No.
    They sit at the dealership for longer periods.
  8. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    My impression is that the dealerships have an employee who pushes a battery charging cart around and hooks it up to each car every once in awhile to make sure the 12v battery is topped up.
  9. Mendel Leisk
    41,863
    Ours sat for 15 months after manufacture date, by that point 12 volt was toast.
    This is an issue, doesn't get much attention. I would think in slow economic times, there's a lot of battery wastage because of this.
  10. ETC(SS)
    7,332
    Keyword: Every once in a while.
    Here's the thing.
    If a Pip cannot be parked for four weeks without irreparable damage to the car, and if you're one of the few people that have to leave your car in the hangar for 4 weeks, then..........buy another PHEV.
    When I was knocking holes in the ocean for a living, we used to leave our cars parked for MONTHS at a time.
    Sometimes spouses and/or buddies drove them while we were on patrol.
    Sometimes we left them with businesses that start them up every X number of days and drive them around in the warehouse.
    Sometimes we left them in open lots on base.
    Sometimes......the really anal, single people would invent all kinds or zany countermeasures to mitigate the ravages of idleness on the part of the parked vehicle like putting the car on jack stands, removing spark plugs to put oil in the cylinder bores, etc.
    One time, a friend of mine had to beat feet to his boat when they got scrambled to leave, and he had to leave his car in the base parking lot with the windows cracked and the keys in the ignition thinking (erroneously) that a buddy would come and get it when his boat came in.
    I can think of a few occurrences of not being able to crank cars due to depleted 12v batteries, and the guy with the windows cracked had some interesting plant life growing in his car (8 months later) but I've not seen one credible, verifiable case where a car was wrecked or even negatively impacted by being parked for a month in my 32 years as a squid, and for years afterwards.
    Cars just aren't that fragile, even today.....and most people trade them out every 150,000 miles anyway.
    The Pip is a compliance car.
    People buy them to flout HOV laws, Toyota builds them to meet shifting "green" car quotas, and some people buy them because they are Toyotas, or they're suffering from first-world guilt, or because they want to be eco-chic.
    It really doesn't matter, since the PIP is a pretty sorry PHEV.........BUT(!) it's a phenomenal, reliable, affordable and very green 'last year's' commuter car.
    You can get a gently used example for waaaaaaaaaaaaaaay less than 20K, and if you already have one, and you keep it, and you check and top off your oil every 1,000 miles or so then you can expect one to last well over 150,000 miles even if you leave it parked for a month at a time every now and again.
    Try to make sure that the traction battery is mostly charged, and buy a pocket booster.....and familiarize yourself with jump starting a Pruis.......Correctly!!!!
    Of course......if you're going to leave the car parked for more than a week at a time regularly, then a $20 battery tender (NOT a trickle charger!!!!!) will solve the problem entirely.
    Other than maybe having to buy a 12v battery every now and again, you won't impact your car's lifespan one whit even if you leave it parked for a month at a time semi-regularly.
    Period.
  11. bisco
    52,351
    has the hybrid battery been fully charged all these months, or discharged?
  12. sillylilwabbit
    405
    118
    Los Angeles
    2014 Prius Plug-in
    Thanks, I will look that up!
    Yes, discharged all these months.
  13. srl99
    srl99 Member
    113
    2014 Prius Plug-in
    That gigantic battery charger is to try to breathe life into the baby blue car that's been sitting around forever, but matches your baby's eyes - so you just have to have it. "It's the only one like it! This is a very rare color! (thankfully, or they'd be stuck with even more of them)". If they can't breathe life into it for the test drive, they can always warranty the battery in the service dep't in time for delivery.
    "Flouting HOV laws!?!" This isn't the VW PHEV. This Prius has (only) enough AER to qualify for the HOV lane. If you don't like the laws, change your elected officials. And ... vote with your wallet. If you don't buy them, they won't make them.
    "Knocking holes in the ocean" flouts a bunch of laws and treaties depending on whose flag is on your vessel and whose flag is asking.
  14. bisco
    52,351
    that's a good thing. how much are they asking? i should think they're getting fairly desperate by now.
  15. ETC(SS)
    7,332
    Not really.
    There's Innocent passage.
    Innocent passage is a concept in law of the sea which allows for a vessel to pass through the territorial waters of another state subject to certain restrictions.
    Besides....if they never knew you were there.....there are no 'restrictions.' :)
    I'm not sure that applies to pips. People bought every one that they made.
    .......and Toyota stopped making them.
    See also: Insight I
  16. sillylilwabbit
    405
    118
    Los Angeles
    2014 Prius Plug-in
    $14,998.
  17. bisco
    52,351
    is that a good price out there? how many miles on her?
  18. sillylilwabbit
    405
    118
    Los Angeles
    2014 Prius Plug-in
    The price is "ok" for what it is, however, the prices keep taking a dump.
    Mileage is 37k, which is low based on the average person's 12k miles per year should be 48k miles.
    So the low mileage raised the price a little.
    Picked the car a few days ago! Car started up with no problems!
    Thanks all!
  19. bisco
    52,351
    does picked mean bought?
  20. sillylilwabbit
    405
    118
    Los Angeles
    2014 Prius Plug-in
    Yes sir! Bought!
    A screen shot after my drive to work. :p
