Fire in a prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by E Silver, Dec 5, 2015.
  1. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    We can go over 20 if there is good content and there is
  2. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    So we have two gen 3's referenced in this thread with supposed combustion having occurred at the passenger side headlight area. A 2010 and a 2011. Kbb's was a package III, which infers the standard halogen headlight assuming no modification. E Silver doesn't tell us which package her 2011 is/was, but her wheels would suggest a halogen set-up also. Just in thinking out loud, the Gen 3 headlight harness TSB is for 2010/2011 which pop headlight bulbs at an unacceptable rate:
    T-SB-0204-12_ 2010 2011 Prius Headlight issue.pdf - Google Drive
    Link lifted from 3prongpaul's thread regarding said TSB:
    Gen3 2010 2011 Headlight bulb longevity - upgrade to HID? | PriusChat
    Is this known wonky headlight harness a prime suspect in these supposed fires? Who knows...this is just where I ended up going in trying to make sense of these two similar occurrences. I do feel this is a valid thread, although E Silver really needs to return and communicate in order to achieve reasonable credibility.
    John Regan and Mendel Leisk like this.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Say's the guy who becomes post number 21.
    m.wynn likes this.
  4. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    The OP stopped by "Today at 2:37 PM" but evidently had nothing to say to us.
  5. bisco
    52,254
    still recovering from shock.
    Firnaz likes this.
  6. Firnaz
    Firnaz New Member
    Harrow
    Can someone assist me with what to do regarding my Toyota prius car caught fire and it burned completely.
    while I was driving I smelled something burning and I thought it was because of the car heater and I turned it off. Then within two mints I seen few unusual lights appeared on my dashboard and started to smoke,I quickly stopped the car to have look but it quickly cought fire. Within 15 mints that London fire brigade come to put the fire away, it burned pretty badly and they said it might be an electrical issue which caused it.
    Milage was 130000, All the service and other jobs done by Toyota, until this happen the car was running perfectly and I did not come across any problem. As I am having third party only Insurence, I am not covered with my Insurence.
    I wonder anything Toyota GB can do for me with regarding this issue.
    Please assist me.
    #26 Firnaz, Dec 13, 2015
    sfv41901 likes this.
  7. bisco
    52,254
    you can call the toyota owners service line, it's in your warranty manual. if they won't help, your only option is through the legal system. i imagine the magistrates won't take kindly to companies whose products catch fire. do you have a national transportation safety board? have you spoken with the dealer?
  8. Firnaz
    Firnaz New Member
    Harrow
    Thank you ! I have spoke with Toyota GB about this and they have opened up a case. Waiting for them to call me on Monday.
    Hope for the best.
    Hope for the best.
  9. bisco
    52,254
    all the best!(y)
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Wow.......funny That the left headlight is still light after the fire.
    VS980 4G ?
  11. bisco
    52,254
    cool spot.
    m.wynn likes this.
  12. hussain ahmed
    hussain ahmed New Member
    London
    The same thing happened to me.
    I was driving my car I saw a bit of smoke so I decided to pull over and check the next you know my car was on fire, with in minutes the whole engine was gone.
    Does any know what I should do
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Call your insurance company, that's what you pay them for.
    Car fires are common enough occurrences, and with the millions of Prii on the road, statistics say some will burn. In just the United States (I realize you are in the land of Boris) there's an average of 150,000 vehicles fire per year, 17 an hour. Fires resulting from collisions were about 4% of that number. So as you can see, in just the US, 144K vehicles burned for no other reason than "just because".
    Sorry you were one of the unlucky chosen few.
    wjtracy likes this.
  14. macman408
    1,179
    368
    I would suggest exiting the vehicle, proceeding to a safe distance, and calling the fire department. (On your side of the pond, you may want to ask for the fire brigade instead.)
    :D
  15. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    It's a very rare thing. But you have electricity, gasoline, oxygen and heat there, so it can happen.
  16. bisco
    52,254
    i suppose it's possible...
  17. bisco
    52,254
    welcome! i understand you can get salvage engines fairly inexpensively. all the best!(y)
  18. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    hussain ahmed (post 32) has not been seen here since three minutes after he made that post last Thursday.
  19. savany71
    savany71 Junior Member
    Seattle
    I'm the one who had 2010 Prius fire in front of my driveway, Bottom line is that, Toyota will not do anything,no evidence. I'm sorry this happed to you as well.
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Old posts but I'm thinking it may have been the headlight socket based on the Op's picture and the fire in the passenger front corner.
    There's nothing there really but the headlights. Whats hot there?
    I replaced my G2 headlight sockets a few years ago as they were intermittent and they were pretty burned up. I used to drive the car myself alot then and used the headlights like a DRL car on all the time in the daytime.
    If halogens the socket gets really really hot. They get extremely hot if you have replaced them with the Phillips after market super bright lights.
    They pull alot of power.
    I would be curious to know if they use DRL.
