Steering Wheel Buttons
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jim.Biggs, Oct 12, 2008.
  1. Jim.Biggs
    Jim.Biggs Zardoz
    Scottsdale, AZ
    My steering wheel push buttons on the right side ALL stopped working today. Any ideas?
  2. qbee42
    3,079
    I believe the buttons are all connected together, with differing resistance values used to differentiate the individual buttons. Assuming this is correct, I suspect the problem is in the steering wheel. They aggressively cycling all of the buttons a number of times to see if anything loosens up.
  3. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Sounds like a dealer service issue.
  4. patsparks
    10,664
    567
    Adelaide South Australia
    I have the same issue except my buttons now don't work at all. I was wondering if anyone had any success in fixing this issue and what it is likely to be. Could it be the clockspring? I'm thinking the clockspring may be the common link. At first the issue was intermittent, now constant. Any thoughts from the technically minded or experienced would be appreciated.
  5. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Likely it is a faulty clockspring. Keep some button pressed and turn the steering wheel around. If button works at some point then it has to be faulty clockspring (or connectors on it (unlikely)).
