Battery Fire
Discussion in 'Gen 2 Prius Technical Discussion' started by strawbrad, Jun 9, 2015.
  1. strawbrad
    strawbrad http://minnesotahybridbatteries.com
    953
    1,007
    I will start with a little background info. I rebuild batteries and advertise on Craigslist. A customer took a chance on a Gen I Prius from Co-Part insurance auctions. I know this is the Gen II forum but the fire damage and risk applies to all generation Prius and I thought more members would see the thread here than in the smaller Gen I forum. The cars damage was described as interior fire. What had burned was the traction battery. This is worth sharing so everyone can learn and be careful.
    Next is the only smoke damage in the rest of car. There is no smell of smoke either. It could have been much worse.
    The carpet over the battery and the panel behind the rear seat melted. I had replacement parts from a parts car.
    The next four pictures show the fire damage. :eek:
    A closer look.
    And another.
    And a shot of the smoke damaged inside cover.
    I pulled the rear bus bars off with the battery still in the car, I wanted to disable the high voltage as quickly as possible. I use a small 12 volt impact driver to undo bus bar nuts. The driver is very quick and its plastic body adds another layer of protection from high voltage. With the impact driver I could tell that something was not right about how the nuts were coming off. So I switched to a hand ratchet and discovered that all the buss bar nuts were at best just snug, not tight.
    This next shot was taken after all the rear bus bars where removed so high voltage was not present. With a good grip from a rubber glove and a bare socket I was able to remove all off the nuts from the front bus bars. It was not easy but I did not need a wrench on the socket,:censored:
    The nuts on the burned modules spun off easily and I did not need a glove for grip.
    The nuts used on the bus bars were not OEM Toyota parts. This picture shows a Toyota nut with a built in washer and the nuts used here have a serrated surface,
    This Gen I battery had been rebuilt with Gen II modules. I could not find any signs of contact between the case and battery terminals.
    I shared this so others can learn and we can all be more careful. This could have been much much worse.
    Brad
  2. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Most informative. Loose connections cause arcing, causing smoldering and eventually fire. Obviously a ordinary mechanic was not electrically astute. Or just forgot to tighten?
    tangerino and orenji like this.
  3. orenji
    orenji Senior Member
    5,887
    3,488
    So the cause was the Gen II batteries being used?
  4. Patrick Wong
    18,210
    6,511
    The cause was loose battery module connections to the bus bars which resulted in electrical resistance in the circuit. That resistance resulted in heat being generated, sufficient to cause a fire which melted the sheet steel battery case.
    The peak current flow to and from the traction battery is ~80A. According to Ohm's Law, I^2 x R = P where I is current, R is resistance and P is power.
    Suppose you have 1 ohm of resistance in the circuit, which is a pretty small amount. 80 x 80 x 1 = 6,400 watts. That is like the heat produced by 4+ hair dryers.
  5. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    Too bad we don't know the whole story. I'd love to know whos handy work that was.
    Avi
    orenji likes this.
  6. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Surprised there aren't more fires esp since so many people seem to cheap out and go for a module swap w/o knowing the torque specs or use the services of a questionable craigslist advertiser.
    No implication implied whatsoever to Strawbrad; he obviously knows what he is doing and discovered the cause: crappy workmanship and incorrect parts.
  7. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Brad. Is there any discoloration of any of the bus bars or terminal nuts due to heat? From your pictures it is difficult to tell.
    Most of the fire damage is or appears to be on the top of the battery, and not at the bus bar area. I am in no way trying to discredit your findings, but trying to make sure 100% the problem was cased by poor bus bar connections although I agree that any resistance due to poor contact is going to produce localized heating. As such I would expect to see melted plastic around the offending terminals.
    Could this fire be caused for instance by a faulty or corroded internal connection between cells close to the area where the most fire damage is.
    The gen2 modules have only one internal connection to the next cell. In the gen3 modules this was altered to give two internal connections to reduce both internal heating and battery resistance.
    John
    #7 Britprius, Dec 18, 2015
  8. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    How do we know that the serrated nuts did not have full contact to the electrical surface so therefore heated up and cause them to become loose?
  9. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    ...looks like plastic burned?
    To be clear these are NiMH batteries, so the electrolyte inside the battery is water-based. So the battery chemistry itself is not sustaining the fire (of course the spark it's giving). Whereas a Lithium battery has flammable electrolyte so the whole battery would have gone up in flames. Of course, greater design safety pre-cautions are taken with Li-batts for this reason.
    Robert Holt likes this.
  10. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    Okay if the load is not going thru the nuts then I will agree with that summation you gave. So what do the small nuts achieve? Just hold downs? My experience is that unless the threads are interfereance type the tightness of the nut onto the surface does make an electrical difference insofar as to achieve the best contact as possible. Thats why in most instances brass is used so that the washer plate deforms to fill in the small gaps to achieve the best electrical contact. Also the amount of tightness make the threads achieve the best contact thread to thread within the fastener.
  11. Britprius
    5,194
    1,922
    Thanks I'll amend my post accordingly.
  12. PriusCamper
    PriusCamper Senior Member
    13,000
    5,285
    Pacific Northwest, USA
    An important thing to note in this failure is it was contained (just barely) by the design of the battery pack and though the failure is the most extreme case I've seen in a Prius, it did not set the rest of the car on fire, which explains alot about why Prius was such a popular vehicle in its first decade of production.
  13. ChapmanF
    18,476
    Somewhere there are photos of a Gen 1 battery fire that did much more extensive damage to the car. They are still vividly in my head from when I saw them maybe a dozen years ago, but I've tried a few times to re-find the link without success so far.
  14. PriusCamper
    13,000
    5,285
    How much of the upholstery did you see burned? Maybe in terms of % of the interior damaged?
  15. ChapmanF
    18,476
    Definitely the headlining, C pillar trim, package shelf, rear seats, center stop light ... pretty much everything you'd see if you were in the front of the car looking back.
  16. PriusCamper
    13,000
    5,285
    It's good to know the two worst examples of battery failure were in Gen1... I wonder if that had any influence on downsizing from 38 modules to 28?
    What I do know is my buddy who's been teaching hybrid repair since Gen 1 days has said more than once that the Gen1 Panasonic modules were horribly designed and he won't work on them anymore.
    tangerino likes this.
  17. ChapmanF
    18,476
    I don't know if there's any basis for saying those are the two worst; they're two I've seen photos of.
  18. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I've seen Pri on auction sites with extensive burn damage in the rear only. Since I have no way of determining the cause (HV, 12v, gas, a cigarette, etc.) I've never considered posting it. Just because one has never seen something doesn't mean it never happens.
  19. orenji
    5,887
    3,488
    You left out arson.
    fotomoto likes this.
  20. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I have a heck of a time convincing people to actually torque the nuts properly. "It can't possibly be that important!". Yes. Yes it is.
