Mpg keeps getting worse.
Discussion in 'Gen 3 Prius Fuel Economy' started by kyle7, Jan 1, 2016.
Tags:
  1. kyle7
    kyle7 New Member
    washington
    I bought my 2014 Prius in May of 2014. Now has 42k miles. I once remember getting over 50mpg, typically would get 45-47mpg. I take it in every 5k miles for its service and it comes back good according to them. The mpg has gotten worse and worse. I made a fishing trip and put about 700 miles on it in 3 days, averaged maybe 35 mpg. The current tank I'm on is less than 30mpg. Only thing the dealer said is that i can do an engine flush and it MIGHT help. And words of advice?
    This is a little frustrating since i bought the car for the same reason everyone else has but my mpg is much worse than what many others get.
  2. frodoz737
    frodoz737 Top Wrench
    4,711
    2,512
    33
    At 42,000 miles would it be right to assume you have new tires now? Checked the pressures lately?
  3. CR94
    CR94 Senior Member
    2,697
    1,174
    Northwestern S.C.
    Any chance the weather has been cooler lately than it was when you were getting 45-47 mpg? Something must be different in conditions now, or you're driving faster?
  4. kyle7
    kyle7 New Member
    washington
    Tires are a little lower than what most prius drivers have theirs at.
    It has been cold lately, but last winter the mpg wasn't this low and as it got into this last summer, my mpg didn't increase at all. Dropped into the winter and never went up. My driving i would say I've gotten more conservative with.
    If you think a both cold and lower pressure changes mpg by 15+ i think thats crazy, but I'll pump my tires up to 42/40 and see how my next tank goes.
  5. bisco
    52,035
    welcome! at your mileage, there doesn't seem to be anything that would normally apply to higher mileage vehicles. nix on the 'engine flush' whatever that is. are the tyres original? how is alignment? any accidents? 12 volt health? what are your driving routes like? how is your oil level? air filter clean? 87 octane gas?
    Phatlife and N.J.PRIUS like this.
  6. kyle7
    kyle7 New Member
    washington
    Tires just got changed. Alignment got done with the tires. No accidents. Havent checked the battery, driving routes change due to place of next fishing trip. Oil just got changed. Air filter is clean. Only thing left would be gas according to your post, not sure of the octane level, but shouldn't make that much of a difference right? I'd love to get over 50mpg like other prius drivers.
  7. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Have you looked to see if you are dragging a brake?
    N.J.PRIUS and bisco like this.
  8. Mendel Leisk
    41,572
    What are your new tires?
  9. bwilson4web
    16,237
    Start with basics: Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new | PriusChat
    When you are ready, the follow-up is to test the car to determine if there is something wrong with it.
    BTW, is that Washington State or DC?
    Thanks,
  10. Manhal K Alrashdan
    Manhal K Alrashdan Junior Member
    81
    jordan
    Try this method :disconnect your 12v battery's negative terminal for about 10 minutes. This will reset the car's data and may improve your mpg rate.I know few who tried it and got good results.
  11. frodoz737
    4,711
    2,512
    33
    Tires, tire pressures seem to have the biggest effect on mpg for during normal operations assuming the wheels are stock. Most new tires will reduce mpg 3-10 mpg depending on your choice and time required to cut them in. Hot summer and cold winter temps can drop another 2-7 mpg.
  12. kenichols29
    kenichols29 Active Member
    250
    109
    Mckinney, Texas
    Try a fuel system treatment. My mpg dropped so I added one around 37,000 miles and I picked up a couple mpgs after that my mpgs went back up to where it was when I got the car.
  13. kyle7
    kyle7 New Member
    washington
    I got the yokohama avid ascend
    Would this possibly help improve the 15+mpg I have lost since i got the car?
    So I've pumped up my tires and unplugged the battery to reset the car, ive managed to add 3-5mpg but im still under 35mpg according to my car. Havent drove a full tank to calculate it, but the computer is usually 1-2mpg over what i actually get and im at 34mpg right now.
    #13 kyle7, Jan 7, 2016
  14. Mendel Leisk
    41,572
    What sort of driving, what speed? Really high speeds are tough on mpg.
    Right after a drive, feel all 4 wheels, see if any feel hot, could indicate a dragging brake.
  15. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Feel the brake rotors, not the wheels, carefully in case they're really hot. ;)
  16. kenichols29
    250
    109
    Mckinney, Texas
    Are you calculating by hand or are you using the HSI display?
    Not that much but you might pick up 2 to 5.
  17. bwilson4web
    16,237
    Hey, I got the same thing yesterday:
    After helping my wife in the house and taking care of our dogs, I forgot to turn off the car. It ran all night and instead of +50 MPG for ~120 miles, it was down to 36 MPG for ~120 miles. It happens but the car was nice and toasty.
  18. bisco
    52,035
    i hear ya.:coffee:
  19. vday
    vday Member
    312
    Israel
    Sounds to me like a hybrid battery problem
    Get the Battery checked
  20. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    What does it mean to drag a break and how can it be fixed?
    SM-G925F ?
