no dash lights
Discussion in 'Gen 2 Prius Audio and Electronics' started by Antton, Jan 9, 2016.
  1. Antton
    Antton New Member
    Phoenix
    My 2008 Prius has a dash that won't light up consistently. Also won't turn off until you hold the Start button for about 10 seconds. Upon research I found out my problems were a result of a bad 12v battery. So I changed it and the problem continues. Took the battery out and it tests fine. What else could be the problem and how can I fix it. Thanks
  2. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    iPhone ?
  3. Antton
    Antton New Member
    Phoenix
    Thanks for the info. The copy you sent is very blurry. Is there a website where I can find a clean copy of that letter. Thanks, steve
  4. blackavenger
    blackavenger Junior Member
    32
    Bland Strand
    Four Touring
    The images you shared, sillylilwabbit, are not showing up in my browser.
    Could you describe what they are for me?
    The (2007 Base) Prius I just bought earlier today is exhibiting the same behavior as the OP's.
  5. blackavenger
    32
    Bland Strand
    Four Touring
    *never mind.
