Do you have the '16 Prius? Does it beep in reverse?
Discussion in 'Gen 4 Prius Main Forum' started by lamontcranston, Jan 18, 2016.
  1. lamontcranston
    lamontcranston Umbra Tenet
    212
    17
    Southern California
    Hi all...
    getting back into this forum after an absence since I'm thinking about buying a Gen4 Prius. Folks here were extremely helpful when I bought by '10 Prius because I would not have bought ANY vehicle that continuously beeps in reverse.
    So I'm asking if anyone has taken delivery of a '16 yet, and had the dealership change it to one single beep in reverse. I want to be 100% sure it can be done.
  2. krmcg
    2,592
    2,392
    Whittier, CA
    It beeps.
  3. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    From the manual (see page below), it looks like you can do it yourself but I would ask (tell) them to do it as a condition of sale.
    Correction: Column 1 means you can do it by MFD, Column 2 means you can do it if you have Entune and Column 3 means it can be done by dealer. In this case only Column 3 option is shown so for now dealer is the only way to go. Making it a condition of sale is thus important rather than just being easier.
    #3 energyandair, Jan 18, 2016
    xliderider likes this.
  4. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    I am under shock they actually still left this useless annoying and irritating inside beeping. Like as if other cars have it or like as if other cars make a special engine noise or have some special lights telling you are in reverse....
    We can all thank you can have it turned off (dealer only unfortunately), but you can still do it.
  5. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    They had to use some kind of audible signal, because the "gear" selector is self centering, so one cannot determine if the car is in reverse or drive by looking at it. Yes, I know you can see the indicator on the dash display. But they felt the need to make it as idiot proof as possible. :rolleyes:
  6. bwilson4web
    16,202
    The Gen-3 can turn it on or off to a single beep with a miniVCI. We need to find out if miniVCI works with the Gen-4.
  7. arescec
    arescec Active Member
    238
    105
    Croatia
    Actually, there were some people that forgot that they were in reverse and simply floored it. That's why that beep is there and it's probably not even Toyota's choosing, but law. Same as with seatbelt beep in Gen3.
  8. Kekoa
    Kekoa Junior Member
    Orange County
    Four Touring
    Can that beeping be heard from outside? I should know this since I've had my '16 for a week now, but curious nonetheless.
  9. krmcg
    2,592
    2,392
    Whittier, CA
    no.
  10. bisco
    51,895
    unless your windows are open.
  11. energyandair
    905
    339
    Victoria BC Canada
    Or the hatch!
  12. Mendel Leisk
    41,402
    ^ That'll give you another beep, lol.
    My 2 cents: the beep is there for a reason, a patch for the anonymity of the return-to-center shifter. You have to living a sheltered life to get into a lather over something that occurs for 5 or 10 seconds, and may just help you out some distracted day.
  13. energyandair
    905
    339
    Victoria BC Canada
    I found the continuous beeping distracting and view it as a safety hazard.
    It's enough of a challenge figuring out what's hiding behind the rear quarters without anything else making it harder.
  14. bwilson4web
    16,202
    BTW, I bought a 'beeping back-up, LED light' on eBay and fitted it on our 2003 Prius. It doesn't have much effect on pedestrians but the volume is right inside and outside.
    Although I understand the reason, a single beep is enough. Better still, a quick, double beep, and then turn it off so we can both look and listen.
  15. bisco
    51,895
    but only one barely audible 'cheep' when you're gonna run out of gas.
    Kramah313, energyandair and krmcg like this.
  16. Bisque
    Bisque Member
    40
    27
    No. Not at all. It beeps every time I start the car. Sometimes for 2-3 weeks :)
    Absolu22 likes this.
  17. bisco
    51,895
    really? not mine.:(
  18. lensovet
    2,615
    496
    Burlington, NJ
    definitely beeps every time you start the car. unless you fill up immediately after ;-)
  19. bisco
    51,895
    really gotta get those hearing aids...
    fuzzy1 likes this.
  20. HGS
    HGS Member
    307
    123
    The reverse beep does not bother me at all. I what it there for my wife: too risky to take a chance turning it off for her. I'm used to not being distracted by noises (decades of professional flying).
    Just try not to "turn off the noises" too much. The old joke: "why did you land with the landing gear up?". Answer: "I was so distracted by the gear up warning horn beeping at me I forgot to put the gear down"
