New 2015 Prius Two
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jkautz, Jan 20, 2016.
  1. jkautz
    jkautz New Member
    I just purchased a new Prius a couple days ago. When is the first scheduled maintenance interval? My dealership told me 10,000 miles for the first oil change? I've always been under the impression that you need to do the first service as soon as possible with a brand new vehicle? To rid the oil of metal shavings and break-in oil.
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  3. jkautz
    jkautz New Member
    Thank you for the link JimboPalmer. That'll come in handy. Does everyone do their rotations at 5k and oil changes at 10k? It'd seem to me, it'd be a lot more convenient if you just do the oil & tire rotation at 10k
  4. bisco
    51,952
    10k is too long for tyres, plus they inspect a bunch of things. 15k is a cabin air filter check, so you should either go every 5k, or do the work yourself.
    keep in mind, the first 2 years or 25,000 miles is free.
    i did my engine oil at 5k and 15k. now every 10 from there, or once a year, whichever comes first.
  5. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    It use to be oil changes every 5k. Based on my preowned car, the previous owner did oil changes every 5k miles.
    Now, Toyota changed it to every 10k miles.
    iPhone ?
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Not everyone follows Toyota's recommendations, as you can see by the "What tire do I buy?" threads
  7. jkautz
    jkautz New Member
    I opted for the synthetic oil changes for life through the dealership, so I'll be going through them for maintenance. I was just hoping some people go 10k on their tires between rotations.
    Why did Toyota decide to go from 5k miles to 10k miles??
  8. bisco
    51,952
    changed from dino to synthetic.
    you can certainly go 10k between tyre rotates, it's just a bit more time that might cause premature wear on one or more tyres. so, it might reduce your miles before replacing. every car is different.
    jkautz likes this.
  9. PR1U$
    PR1U$ Junior Member
    29
    Far Nor Cal
    But, wouldn't that even out if you waited the same amount of miles for the next rotation?
  10. bisco
    51,952
    you might have a theory there.(y) but sometimes, the wear is so uneven, the tyres get noisy, and rotating doesn't help. another problem is, toyota recommends front to back rotation, but some people say that cross rotation is better for evening out the wear.
    PR1U$ likes this.
  11. jkautz
    jkautz New Member
    That is true. If you go by the standard rotation, front straight to back. Back crosses to front. That would put 20k miles on one side before it moved its way over to the other side. So, something to think about. I just don't like making appointments for just a tire rotation, I'd rather do oil & tires at once. lol
  12. Mendel Leisk
    41,467
    One advantage to staying with Toyota's recommendation of keep wheels on the same side: only two of your rims are prone to curb rash.
    PR1U$ likes this.
