Solved, rear wheel bearing removal, easy way
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CrniMilorad, Jan 20, 2016.
  1. CrniMilorad
    CrniMilorad Junior Member
    Technology
    I had warning lights on.
    Dealer listed these codes u0073 and u0293, c0215 and c1239.
    After replacing sensor and cable, i reset lights using 4-13 pin method and all lights are gone, All fine after couple weeks, no lights coming back.
    I had bad abs, speed sensor on rear wheel.
    It is integrated with hub so i had to replace everything
    Procedure.
    1. Raise car, and place stand supports. Block wheels on ground. Release hand brake.
    2. Remove wheel.
    3. Remove negative cable from 12V battery in the trunk. It is necessary because of the calipers are engaged while battery is connected.
    4. Remove caliper and secure it behind the hub. Ensure it is not hanging, either place something underneath or tie it to the shock.
    5. Remove rotor.
    6. Remove four 14mm bolts of the hub.
    7. Remove hub using threaded rod, washers and nuts like shown on the picture. You have to put the rod through hub big hole, place washer from other side and put two nuts. One nut might work, but i used two so i can have bigger contact area on the hub. Place nut on the rod end close to the hub edge. This will also help to remove hub off the sheet dirt metal.
    8. Start tightening nut close to you and hub will go off. Do one side just enough to see gap 1 mm and move to other side.
    9. Do the other side same way. This way hub will go out nicely.
    10. No need for big hammer or chisel.
    #1 CrniMilorad, Jan 20, 2016
    Coots, pjksr02, Boffin and 7 others like this.
  2. gliderman
    gliderman Active Member
    751
    225
    No pictures.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
  4. tankyuong
    1,555
    662
    Central MO
    I just use the slide hammer with 3 whacks and off it goes,make sure abs sensor wire is off before whacking
    danlatu and sfv41901 like this.
  5. CrniMilorad
    Technology
    Check again, i uploaded smaller pictures.
  6. tankyuong
    1,555
    662
    Central MO
    I only see one pic of wheel bearing
  7. ChapmanF
    18,475
    Partly depends, I think, on age of car and where driven (road salt used?).
    At nine years, I used the slide hammer and about five straight minutes of whacks, for a long time it didn't give any sign it would ever move. Finally did. My arm was tired.
    The challenge I'd like to see someone solve is, get the bearing out without damage. For example, if you want to change the brake backplate, but the bearing's ok and you'd rather not spend the $2xx or whatever the price is to replace it.
    Of course slide-hammering from the hub side will leave it all brinnelled even if it was ok before, and I'd be concerned the method shown here would do the same.
    -Chap
    pjksr02 likes this.
  8. CrniMilorad
    Technology
    For what you ask, i can imagine only one solution.
    If toyota made threaded hole like on some rotors.
    I do not se other way here other than hammering ( which i highly do not see as optimal)
    and some sort of hydraulic device or threaded like this one here.
    There is not even an option to push hub from other side as there is sensor on other side and plastic cover.
  9. Former Member 68813
    3,524
    983
    US
    OP thanks for posting this. I'll save this for future reference. The only way i see to improve your procedure is to squirt some penetrating oil and grease the bolt (for ease of turning of the nut).
    pjksr02, Mendel Leisk and CrniMilorad like this.
  10. Mendel Leisk
    41,839
    Same here, thanks. Seems similar to the use of bolts in the brake rotor's threaded holes.
    CrniMilorad likes this.
  11. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    I recently had to break loose the right rear wheel hub. After failing with a slide hammer, I used a pipe wrench + the precisely calibrated tool called "cheater pipe", and liberal use of rust breaking penetrant.
    Coots likes this.
  12. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
    Very smart! Good job. I'm going to try this
    DadofHedgehog likes this.
  13. Katsuranomiya
    Katsuranomiya Junior Member
    Ottawa, ON
    Three Touring
    I had a slightly different experience with the front left hub. The slide hammer didn't so much fail as the bearing did. So the bearing came apart with the hub still snugly holding onto the knuckle. The hub does look like it moved slightly because the upper two bolts don't drive in as far as the bottom two bolts. Stuck sitting on it until I figure out a way to get that hub off, or hiring a garage to press it out.
  14. Mendel Leisk
    41,839
    Seems like the threaded rod approach proposed by the OP is the way to go then?
  15. Katsuranomiya
    Ottawa, ON
    Three Touring
    Not so much. The threaded rod approach requires that bit of wheel which the rotor mounts to to still be attached to provide something for the rod to push against. In my case, the slide hammer actually pulled that piece off, so the inside of the bearing and all the balls just fell out. Right now I don't have anything to attach to the piece that sandwiches onto the dust shield. It does seem to be tilted down slightly because of how the mounting bolts go in differently now, so my two best ideas before having to pay someone to press it out would be chiseling and whacking it on all sides with a hammer, or somehow getting another set of bolts I can mount in from the near side and hope they don't strip if I try to mount something to those bolts to get it going... Or maybe with the original bolts going in the back way, I could use a second set of bolts going in from the outside to put pressure on each other.. maybe that would get enough force to push it out? I just don't want to get into a situation where the threading on the holes in the knuckle get stripped.
  16. Mendel Leisk
    41,839
    Would an air hammer work?
    Wait 103 seconds...
    Wait 83 seconds...
    Wait 68 seconds...
    Wait 52 seconds...
    Wait 21 seconds...
    Wait 3 seconds...
  17. Katsuranomiya
    Ottawa, ON
    Three Touring
    Maybe, but I'm not sure what to attach it to, aside from just using it to vibrate the heck out of the hub. (Correct me if I'm misusing any vehicular anatomy.)
  18. Katsuranomiya
    Ottawa, ON
    Three Touring
    Does anyone know if the 4 mounting holes which secure the hub to the knuckle have threading on the knuckle side of the holes, or is the threading only on the hub side? If the threading is only on the hub side, I might be able to get something in there and use the steering to press out the hub/bearing casing.
  19. danlatu
    danlatu Senior Member
    533
    1,363
    maryland
    1. torch it
    2. blast it.
  20. Mendel Leisk
    41,839
    Looks like WAR!
