Help! Intake Manifold Removal
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Stangar, Jan 20, 2016.
  1. Stangar
    Stangar Active Member
    174
    174
    Palmdale, CA
    I'm ready to remove my intake manifold (IM) to clean the EGR port on the side and also the little holes inside the IM. However, I do not see how to release the fastener on the top of the IM that holds that big wiring bundle in the center over the IM. (I have everything else accomplished) If you have done this before, I'd greatly appreciate a little help out here in left field. Thanks!
  2. DRACO
    DRACO Member
    362
    78
    Rancho Palos Verdes, California
    2002 Prius
    Post a pic of what you are trying to remove.
  3. mrbigh
    3,686
    699
    Long Island, NY
    Pictures will help enormously
  4. Former Member 68813
    3,524
    983
    US
    OP: are you talking about the wire bundle that is clipped on a bolt? i think i pulled it, but my memory is fuzzy.
  5. Stangar
    174
    174
    Palmdale, CA
    Yep. Only its one of those push in clips for the big wire bundle in the center going over the top of the IM. It's big. You can't miss it Can't see a way to release it without cutting.
  6. Mendel Leisk
    41,791
    Guess I'll jump in. This?:
    Not much detail in Repair Manual, just an indication that there's something there. Pull straight up? See if you can get a side view with a mirror, figure out how it works?
    See where the yellow paint goes across the seam, in the pic above? I bet if you put a screw driver in there and gently pry, it'll pop up.
    Maybe. :ROFLMAO:
    #6 Mendel Leisk, Jan 21, 2016
    DRACO likes this.
  7. Stangar
    174
    174
    Palmdale, CA
    Underneath my finger where that yellow paint mark is located (on the other side) is one of those push in things. I don't want to pry it as it looks like it will be destroyed. Not sure how a Toyota tech would get this baby loose, though
  8. Mendel Leisk
    41,791
    Usually you need to push in the tang. It can take an extreme effort and you need 3 hands in order to yoink on it at the same time. A pair of long needle nose pliers with bent tip sometimes helps.
    I wonder if that little circular cap on the top is part of the puzzle.
    #8 Mendel Leisk, Jan 21, 2016
  9. Stangar
    174
    174
    Palmdale, CA
    OK! Success, without destruction. Screwdriver on either side and push straight in. I'm no Smokey Yunick. Check out the pics. Thank you for your help! image.jpeg image.jpeg
    Mendel Leisk and m.wynn like this.
  10. DRACO
    DRACO Member
    362
    78
    2002 Prius
    Good Job! :D
  11. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    well, thank you for YOUR help/
    who would've figured that out....?
  12. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    I need to do this on mine. I know these IMs don't use a standard paper gasket, but have the rubber insert thingy that seals it to the block. If I pull the IM, do I need to replace it or is it reusable?
  13. Stangar
    174
    174
    Palmdale, CA
    I believe the IM gasket and also the EGR gasket are some kind of silicon and are re-usable. However, I bought new ones just to make sure.
  14. Mendel Leisk
    41,791
    Have you got any documentation, say the torque values? If not I can take a look and post something.
  15. Stangar
    174
    174
    Palmdale, CA
    Thanks, Mendel. I believe the IM is 21 ft lbs and the TB is 14?
    On another note, I see that I have a pool of oil in the bottom of the TB and believe that is normal for an Atkinson engine.
  16. Mendel Leisk
    41,791
    I think you're right for the intake manifold, but I see 7 ft/lb for the throttle body hold down bolts. I'll attach the relevant sections for both. :)
  17. Stangar
    174
    174
    Palmdale, CA
    Thank you, Mendel! You've saved me considerable time and reduced the number of "what 's next" questions. Superb!
  18. ChapmanF
    18,425
    THAT (coupled with plastic components) sounds like a bad day averted. (y)
    Thank goodness there's a FSM that occasionally gets looked at.... :)
    -Chap
  19. Stangar
    174
    174
    Palmdale, CA
    Here's a couple of pics of my effort. By the way, at 130,000 mi, the EGR tube and small ports within the intake were in pretty good shape. 10% of the EGR pipe was filled with gunk.
