Cd player ceased working. Readout: "CD check" stays on screen. no CDs will play. Not a fuse. ??
Discussion in 'Gen 2 Prius Audio and Electronics' started by John Cambardella, Oct 15, 2012.
  1. John Cambardella
    John Cambardella New Member
    Cd player ceased working. Readout: "CD check" stays on screen. no CDs will play. Not a fuse. Any suggestion other than take to dealer?
  2. ipopeye
    ipopeye Junior Member
    new hampsha
    I have this same problem, "Check CD" Any suggestions?
  3. Riaan
    Riaan New Member
    Pretoria, South Africa
    mine does not say anything on the display but wont load cds when you press load the leds flash orange and it does not feed anything, I can hear a motor spinning inside
  4. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
  5. bisco
    52,417
    try disconnecting the 12v for a few minutes?
  6. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    since the oem sound system sucks anyway, aftermarket replacement is the way to go. and I always burn copies of CDs so there is no chance of getting a good one stuck or damaged by a malfunctioning head unit. if the copy gets stuck, no big deal.
  7. jdenenberg
    jdenenberg EE Professor
    3,954
    1,952
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2004 Prius had problems with CD's having "Read" problems and getting stuck in the player. A working salvaged unit only solved the problem for a few months. The permanent fix was going to a car stero shop and installing a good 3rd party stereo unit.
    JeffD
  8. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    If it were the fuse it wouldn't even work at all.
    Another issue is not use labels on CD's especially the full size ones as if youhave a CD stacker unit it will increase the depth of the stack and cause the CD's to not eject/load within the Multi CD player.
