Brake code C1344 and warning lights!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by greasemonkey007, Dec 3, 2015.
  1. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    I keep getting the C1344 and all the lights. I checked and changed the rear shoes and the light keeps coming back, although not immediately. It takes just a little while.
    I didn't notice any signs of leaking fluid, though I was able to squeeze the LH wheel cylinder in pretty easily by squeezing on the top of the shoes. The drums were not scored and were in spec so I didn't turn them. I never cracked any brake lines loose.
    Any ideas of what I can do to figure out what's going on?
  2. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    read this thread:
    ABS acuatator problem | PriusChat
  3. ChapmanF
    18,391
    Hi greasemonk,
    How are you reading that code, and is the car you're talking about the same one in your profile? I'm just asking because you're posting in the Gen 1 forum and your profile says 2001, but the 2001 brake diagnostic codes are on pages DI-358 and DI-359 of your manual, and C1344 is not one of them. Brake codes stop at C1259 for that year, C1344 seems to have come in with Gen 2.
    -Chap
  4. Patrick Wong
    18,210
    6,511
    If your car is a G2 Prius, C1344 is the actual code being logged, and you don't see any hydraulic fluid leaks, then the brake actuator assembly probably needs to be replaced.
  5. greasemonkey007
    287
    106
    Sorry about the confusion. I've updated my profile to reflect my recent upgrade from the 01. I'm checking with techstream. I plan to try bleeding the brakes tomorrow. My helper could have loosened something up when he changed my pads. Just curious if I can do the bleeding procedure with techstream if it comes to that. I'm just going to bleed at each wheel tomorrow to see if that helps. I was a little surprised at how easy the LH wheel cylinder pressed in when I tried to squeeze the top of the shoes. It's got me wondering if it could be bypassing on the inside.
  6. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Thread moved from the gen 1 forum to the proper gen 2 forum.
  7. greasemonkey007
    287
    106
    I thought I posted in the 2nd gen forum. Sorry
  8. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    No worries, I happened to see the discussion and wanted you the know it was now in the right forum for your vehicles generation. Hope you get the help ya' need, as I am certain you will.
  9. thisoldpruis
    thisoldpruis Junior Member
    Jacksonville, FL, USA
    GreaseMonkey, were you able to solve your problem? I am also having a problem with code C1344 coming up repeatedly. Although my situation is different in two ways:
    1. My car is a 2004 with 199k miles and has not had any brake system work in years.
    2. I've been getting this code for about a year or more now. I would reset it and not see it for several months. The it started coming back more frequently...once a month, every few weeks, and now I can reset it and it comes back on the same day.
    Frequency seems to have increased as the weather has grown colder. Coincidence? I have no idea. I appreciate any thoughts or advice anyone can offer.
  10. greasemonkey007
    287
    106
    Sadly, I have put it on the back burner for some time now. I did try to bleed all 4 brakes by cracking the bleed screws. All fluid, no air seen. For some reason, I could not execute the brake bleed command from Techstream. I tried 2 or 3 times and gave up. Too many important things to do. I plan on changing the rear left wheel cyl. just for kicks and giggles and see what happens. I don't know why I couldn't execute the brake bleed from Techstream though. That did kind of aggravate me.
  11. greasemonkey007
    287
    106
    Here's a little update for this pest that I've ignored for over a year. I recently took my car in to the dealership to see if they could figure out what was going on. They decided to replace my actuator pump since it was covered under some extended warranty from Toyota. Lights stayed off for a whole 20 miles! I was all excited to have a new pump and no brake lights on but it didn't last very long. So I took it to another dealership and had them bleed the entire brake system. The lights came on when I started the car to leave the dealership. So I just took it back and had them check it again.
    They found no leaks anywhere and nothing that needed to be replaced. They did find the left rear brake out of adjustment. There was surface rust on the inside of the drum and no brake dust at all. Imagine that! Not sure how that happened but somehow it didn't self-adjust. I was skeptical that adjusting the clearance would keep the lights off but knock on wood, so far so good. I've been about 100 miles in the last couple of days. No sign of trouble yet!
  12. Vincenzo44
    Vincenzo44 New Member
    France
    Hi @greasemonkey007 . May be (hopefully) you're still around. I've got the same issue on my 2006 Prius with same code error C1344. I went to my Toyota garage, and they want to bleed the entire brake system or they want to change the ABS actuor, witch is of course not the same price...
    I try to tell them that I read your post and that may be the rear brake that is out of adjustment. But they told me that this break was mechanic and no hydraulic, so there is no link to this problem and no link with ABS.
    So, I just wanted to know if your problem came back after they adjust your rear brake.
    Thanks a lot for your answer.
    Sorry for my English as it's not my mother tongue.
  13. dolj
    dolj Senior Member
    8,477
    4,303
    Wellington, New Zealand
    There are 5 INF codes (that you can get from the freeze frame data if you have a good code reader) that will help narrow done the diagnosis a little, but I think your mechanic might just be right. The likely problem areas are:
    • Fluid leakage
    • Brake actuator assembly
    • Disc rotor
    The disc rotor as a possible cause depends on the INF code you have.
  14. stanley kim
    stanley kim New Member
    maricopa ca
    Four Touring
    2nd Time C1344 error was on 2006 prius, my technician replaced ABS actuator big module, but Error appeared again. He drained one tire brake side's brake fluid100mL , then C1344 disappeared, problem was solved eventually. Problem was not the expensive ABS actuator big module. One year ago I and technician had solved the first time trouble C1344 for same car by changing ABS actuator big module, that is expensive repair job( module $300+ replace labor $400). Try draining(removing) one tire brake side's brake fluid100mL before replacing expensive ABS actuator big module, That saves big money !!
