Replacing Tire Repair Kit with a Donut
Discussion in 'Gen 4 Prius Main Forum' started by 155, Jan 24, 2016.
  1. 155
    155 Member
    56
    31
    Four Touring
    I was wondering if anyone knew what parts I would specifically need, if it's feasible to replace the tire repait kit in the back of my Four Touring with a real donut and have it look somewhat nice. I couldn't figure out how to remove the sytrofoam cover to look at what was under it and see if there was a spot to even hold a donut.
    Also the touring models have larger tires, so they might need a different size wheel/donut?
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    No, the emergency spare is fine with either the 15" wheels or the 17" wheels. The overall diameter of the two wheel/tyre combos is almost the same.
    You will need to learn how to remove the styrofoam, because you will have to get a new piece of it for the emergency spare parts to fit in. You will also need to remove it to see if the tyre holddown is in the car (I suspect it's under there). Note that the "stuff" that's in the rear of each car is designed to help with collision energy absorption, so if you change it you need to be aware of what you might be loosing. This is why you should stick with the entire stock setup for each option. In other words, if you want the emergency spare, replace all the parts that you currently have with the parts that come with the vehicles with the emergency spare.
    155 likes this.
  3. bisco
    52,286
    don't the models with no spare have the lower hatch floor?
  4. 155
    155 Member
    56
    31
    Four Touring
    Under the hatch, they have a large styrofoam piece that seems not designed to be removed, which holds the tire repair kit.
    Does anyone who works for a dealership know what parts I would specifically need to replace in the back to replicate a stock with a spare tire?
    Connor Smith likes this.
  5. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    Here are some graphics from Tideland Prius ...not too much detail. I am not thinking you have much space under the styrofoam.
    With spare (or E-Four AWD)
    457L = 16.1 cu. ft.
    Without spare:
  6. Mendel Leisk
    41,826
    @155 Did you know going in it didn't have the spare? 3T does I think.
  7. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    I see a few German automakers have a collapsible donut spare that needs to be inflated. Also they have storage bag for donut spares so you can put in your trunk a little more neatly.
    Kurt Weiske likes this.
  8. DallasGuy
    DallasGuy Junior Member
    25
    Palm Springs
    Great idea. Any links to these parts please?
  9. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Yes, sounds good idea.
    For a bag - when I had a car with the tyre [tire] exposed in the boot [trunk] in my first VOLVO 164, I simply got a large plastic bag and put the tyre in it. It was very handy when I had a flat on a wet/muddy road - the contents of the boot didn't get muddy.
    Like this - only with the tyre in a bag (GOOGLE image).
  10. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Couldn't you just put it in a box?
    RRxing, kithmo, Priifan and 4 others like this.
  11. SneezyKevinA
    SneezyKevinA Junior Member
    26
    47
    New Yuck
    2018 Prius
    Do you NEED a spare?
    Just asking. I have not needed a town or a spare since I think in 94 when I had my truck. That was probably half a million miles ago.
    Also, most people forget (and not all dealers really check) the air in a spare anyway.
    2 of 4 cars have inflation kits.
    I'm not trying to be a jerk or anything, just trying to figure out why people get hung up on not having a spare, that's all.
    #11 SneezyKevinA, Apr 18, 2018
    krmcg likes this.
  12. David Beale
    5,963
    1,989
    Edmonton Alberta
    When you need it you need it. It will happen.
    As for never checking the pressure in the spare, Toyota, in their "wisdom", store the spare in Pearl S with the valve -down-. You have to remove it to check it! I guess nobody's perfect?
  13. Mendel Leisk
    41,826
    Honda does that too. :(
    RCO likes this.
  14. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Suspect it's so they can fit bits and bobs in the cavity of the wheel and they never even considered the pressure check.:whistle:
    kithmo and Mendel Leisk like this.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    I suspect the valve is down to protect it if (when?) the driver tosses stuff in there on the tire.
    A spare is sure cheaper than roadside assistance, and usually way faster. I have needed and used a spare three times in the past five years.
    kithmo, breakfast, Priifan and 2 others like this.
  16. Priifan
    Priifan Member
    93
    143
    Cary, NC
    Right on, Jerry! A spare may add years to your life depending on your location at that time. Especially for a woman on a rainy night in Georgia or wherever. AAA only works if you have cell service. Please bring back spares, Toyota.
  17. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Is this a report that Georgia is less civilized than North Carolina? Just checking...:LOL:
    Since2002 and Prodigyplace like this.
  18. Prodigyplace
    12,629
    11,808
    Central Virginia
    That would be rough.
    From what I have seen, North Carolina is less civilized than Virginia .;)
  19. Since2002
    936
    1,098
    Duluth, GA
    I would comment but I've got to go get my clothes off the line before it rains :D
    kithmo and jerrymildred like this.
  20. jerrymildred
    11,517
    14,157
    Tampa, FL
    LOL!! Not to worry. I think I got your reference. ;) But I wouldn't like changing tires in the rain in any state.
    RCO, Since2002 and Mendel Leisk like this.
