New owner, first service questions please
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by darrell of echo parkay, Jan 23, 2016.
  1. darrell of echo parkay
    Los Anglees
    Hello, love my Prius, approaching first service and I have questions: do I need oil change? (is reg 10-40 advised?), tune up (plugs? timing?), air filter replaced? You know, what one would do with a 'normal' vehicle.
    My thanks in advance, and by the way, I love the car.
    52,074
    congrats! oil and filter change are every 10,000 miles. use toyota or equivalent synthetic alternative. 0w-20 i think, it's on the oil cap and in your manual.
    tyre rotation every 5,000 miles, along with multipoint inspection and fluid check/top up. common items like tyres need inspection, and balancing or alignment as necessary.
    air and cabin filters are inspected replaced very 15,000 miles. nothing else is needed until post 100k when you will get into plugs, fluid changes and etc. it's all in your manual.
    if you plan to keep your car for more tha 150,000 miles, many here recommend changing the tranny fluid early and often. toyota calls it lifetime, but some here have had it tested and feel there are too many contaminants.
    some also like to lube the rear brake pad slide pins every so often.
    all the best!(y)
    #2 bisco, Jan 23, 2016
    Rebound, Newtothewheels and WilDavis like this.
  3. mikefocke
    4,014
    1,817
    Sanford, NC
    First service is a bit vague. Is this a 5k or 10k oil change and tire rotation? On a 2013? Or is it a major service interval service in which case the needs will be spelled out in your owner's manual and the dealer will try to sell you on the need for lots of other stuff. Be prepared for the upsell by reading the manual so you know what the difference is between what Toyota says and what the dealer says.
    CR94 likes this.
  4. darrell of echo parkay
    Los Anglees
    Sorry, I purchased it used at 20k miles, and am now coming up on my first service. Thanks in advance for all assistance. What have peeps found to be diff from what manual says, vs. reality?
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Generally, you want what the manual says, not what the dealer may try to upsale you.
    One additional item I do encourage is an ATF WS drain and fill at 30,000 miles, then 90,000 miles , then every 90,000 miles. Toyota has no service interval for Automatic Transmision Fluid at all, which seems unlikely.
  6. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Reality is the manual, the dealers suggested services beyond that are profit centers for the dealership.
  7. Mendel Leisk
    41,629
    What's sad is how some service departments can be SO disconnected from the Toyota schedule. It's the same story with other manufacturers. I'd be curious what it's like in other countries, Japan for example.
  8. darrell of echo parkay
    Los Anglees
    What sort of oil does one use in a Prius, regular 10-40?
  9. Mendel Leisk
    41,629
    OW-20 is the norm in North America, it's indicated in the Owner's Manual, and printed on the oil filler cap.
  10. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    You say you've got 20K miles on your car? You should still be covered by Toyota's scheduled maintenance plan for this service. Just take your car to a dealer and let them do it.
    ou812 likes this.
  11. Newtothewheels
    Newtothewheels New Member
    NY
    This thread is so helpful. I am going to refer back to it often. I am also purchasing a used Prius.
    socal13 likes this.
  12. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    0W20 SYNTHETIC oil. And the oil filter, of course. It costs more, but lasts 10,000 miles between changes. Mobile One is an excellent choice. 5.5 quarts, I think. But your mileage still qualifies you for free oil changes by the dealer.
  13. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Congrats on your purchase and Welcome to Prius Chat! (y)
    Newtothewheels likes this.
  14. Mendel Leisk
    41,629
    I'm partial to Toyota 0W20, the price for me is really good. Just switched over to bulk purchase, mainly to keep bottles out of the recycle stream.
  15. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    I think its 4.4 to 4.5 quarts for the amount of oil.
  16. Mendel Leisk
    41,629
    Yes, 4.2 liter, or 4.5 quart, with filter change, to put the oil on top mark (which I typically do). I have a single liter bottle of oil as well, to bring it up to 4.2 liter. And a nice one liter graduated pitcher.
    (One of those bottles is slated for our son's Civic. The Toyota 0W20 is just the best deal going for us.)
