Gen 4 Noise and Comfort level
Discussion in 'Gen 4 Prius Main Forum' started by VicD, Jan 27, 2016.
  1. VicD
    VicD Junior Member
    52
    Ohio
    for all Gen 4 owners, please comment on your new prius's noise and comfort level compare to a gen 3.
    I have heard that Toyota have done NVH improvement onto this chassis. But real world experience will be always different.
    I appreciate your input.
  2. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    Seems to be a very subjektive experience!
    Some reviewers noticed a big improvement while others said it's only marginal noticeable.
    If it's only a slight improvement it would be a bit dissapointing,because Toyota claimed in their teaser videos it even surpasses quietness of luxury vehicles.
    Maybe it also depends on the wheels you have,the 15- or 17" !?
    A big weakness gen 3 . has is the poor insulation,if any,of the wheel housing and therefore a great deal of tyre noise .
    I know they improved the floor insulation,but to be honest I haven't read a word about improvement on wheel housing insulation .
  3. bisco
    52,232
    i wonder if they all get the same tyres.
  4. kitkit201
    kitkit201 Member
    136
    88
    Bay Area, CA
    My Prius 4 has Toyo Tires. They are kinda on the loud side on the freeway
    Coast Cruiser likes this.
  5. civicdriver06
    797
    324
    Germany
    Are you taking about gen. 3 or gen. 4 ?
  6. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    My Gen-4 Prius 3 has Bridgestone Ecopia EP422 plus tires (P195/65R15) and another member with a Prius 2 eco indicated they have the same tires.
    #6 BigFan, Jan 27, 2016
  7. bisco
    52,232
    yes, that is very odd. someone said they got toyo tyres, no spec though.
  8. kitkit201
    kitkit201 Member
    136
    88
    Bay Area, CA
    I have a 2016 Prius 4. Just updated my information.
  9. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    Would you share the Toyo tire details? (i.e., the specific model information)
    Maxwell61 likes this.
  10. Maxwell61
    Maxwell61 Active Member
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    In Japan, the trims with the 17" are equipped with a never seen before Toyo Nanoenergy R41 , i'm wondering if kitkit Prius 4 "flat" have the same Toyo R41 line but 15"
    + BigFan request.
    Oddly enough, the 17" Prius alloy wheel is a RONAL R41.
  11. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    This is really a story to investigate upon...
  12. krmcg
    2,592
    2,392
    Whittier, CA
    My Toyos on my Prius Four. I don't find them noisy at all...
  13. Mendel Leisk
    41,786
    @Maxwell61
    Maybe a modified Ronal R41? There's some spy shots with bare 17" rims, showing some (very utilitarian) lugs at each spoke, presumably to hold the plastic pieces.
    Hopefully some 4th gen touring owners'll post pics, rim with plastic removed.
  14. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    Very likely.
    Same thing for those Toyo tires that seems customized for Toyota: at the moment does'nt exist any trace on the web for any Toyo Nanoenergy R41 or Nanoenergy A29.
    The Nano R41 thread design seems a close fit of my Nanoenergy 2, which is excellent news for rolling resistance (not so good news for wet grip) don't know for those A29 posted because you can't see the threads.
  15. priusgto
    priusgto Active Member
    194
    231
    Northern Arizona
    My new 2016 Two Eco has the same Toyo Nanoenergy tires. My 110 mile trip home from the dealer was enough to put these on my short list of things to replace with a better quality. They resonate into the cabin much more than any tire I had on my 05 , Michelin fuel saver, X radial or the GY Integrity.
    Coast Cruiser, kitkit201 and bisco like this.
  16. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Makes sense, 30% stiffer around the doors and tires that don't absorbe as much energy, seems buyers beware, it you want to feel like your driving a rolls, get a rolls, if you want 55+ mpg, get a gen4 Eco
  17. priusgto
    194
    231
    Northern Arizona
    Plenty of better choices with 195/65-15 tires.
  18. kitkit201
    kitkit201 Member
    136
    88
    Bay Area, CA
    Yes, my tires are also Toyo Nanoenergy A29 and I find them loud after going past 40mph. I've had Energy Saver X before and I can say these are louders.
  19. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    Not sure what tires I have on my 2016 4 Touring, but the cabin is MUCH quieter than my wife's 2010.
    Of note, my car lacks the spare and apart from a few cavities, the filler piece under he carpet has a great deal of sound deadening material. Not sure how much cabin noise comes from the rear, but that has to make a difference.
  20. bisco
    52,232
    this was my fear. the problem is, if you replace the tyres, do you wind up with a two non eco?
