Lowered Front Plate...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by sprtent, Jan 28, 2016.
  1. sprtent
    sprtent Member
    104
    75
    SF Bay Area
    ...by about 3-4 inches. Not sure if anyone did and posted this already. Love this clean look :)
  2. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    Yep. Good look and that's how I have mine!
    #2 mrstop, Jan 28, 2016
    PriiPrii, saulbassfan and sprtent like this.
  3. Mendel Leisk
    42,361
    Does it keep 12" clear to the ground?
  4. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    Sure does.. and prevent the painted part of the bumper from getting scuffed up. I moved it a when it was just a few weeks old.
    #4 Sfcyclist, Jan 28, 2016
  5. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
  6. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    @saulbassfan, your car has some serious road holding grip. Must be able to pull some G's. :D
    sfv41901, saulbassfan and sprtent like this.
  7. Mendel Leisk
    42,361
    Yeah I agree, close but legal. You may need to keep your tires aired up though, lol.
  8. Sfcyclist
    1,621
    376
    SF, CA
    What's the requirement in Canada?
    Per CALI. vehicle code 5201 height is pretty loosely defined. I can have it on the touching the ground based on this,
    The rear license plate shall be mounted not less than 12
    inches nor more than 60 inches from the ground, and the front license
    plate shall be mounted not more than 60 inches from the ground,
    except as follows:"
  9. Mendel Leisk
    42,361
    Oh, I just did quick read, saw 12" minimum, didn't differentiate front/rear. There is a difference?
    FWIW I'm happier with the "stock" position, and having the plate lower is sort of a year 'round grill block. And I do grill block through winter, so, it'd be in the way the bit.
  10. Sfcyclist
    1,621
    376
    SF, CA
    In CALI., 12" min on rear. For front, there is only a maximum. So can be low as you can go..
  11. mrbigh
    3,686
    699
    Long Island, NY
    possible scrapping the pavement too............
  12. Tung Huynh
    Tung Huynh Junior Member
    San Jose
    So how did everyone lowered their license plate?
  13. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    I used the factory front plastic plate mounting bracket. It fits the contours very well and sort of clips into the grill. It was then secured in place by some zip ties. Once you take off the bracket it is pretty self explanatory.
    sprtent likes this.
  14. Sfcyclist
    1,621
    376
    SF, CA
    It's great that the factory bracket fits the lower section as well as it does. Almost like it's meant to be there..
    #14 Sfcyclist, Feb 4, 2016
    sprtent likes this.
  15. sprtent
    sprtent Member
    104
    75
    SF Bay Area
    On the top part of the factory plate holder, I use the 2 old screws. On the bottom of the plate holder, I use one screw (extra) right in the center of the bottom part of the holder and straight down (vertically) to the lowest line of the black grille piece.
  16. Sfcyclist
    1,621
    376
    SF, CA
    I just used zip ties. Almost 3 years now without any issues.
