Need your help! Prius 4 tire information spreadsheet
Discussion in 'Gen 4 Prius Main Forum' started by kitkit201, Jan 27, 2016.
  1. kitkit201
    kitkit201 Member
    136
    88
    Bay Area, CA
    We are finding that owners of the same trim of Prius with different tires from different manufacturs.
    Please add your username and tire information if you recently bought a Prius 4th gen. Even going to a dealership and adding data points would be good.
    So far, it seems that the Toyo NanoEnergyA29 drone on the highway. Thanks for those that added information already!
    GaryD1 and bisco like this.
  2. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    Just added my info to spreadsheet.
    GaryD1 likes this.
  3. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    like the spreadsheet, but was just thinking, it would be nice to have other columns labeled (MPG)& ect. Just to see if there is a trend for a better tire that works best on gen 4, and yes I know there would be a bunch of variables. Any other thoughts?
  4. bisco
    52,239
    different tyres expected, but not on the two eco.
    anyone with a two eco measure their psi yet?
  5. vince22
    vince22 Active Member
    205
    249
    califorinia
    just added my Two Eco tires Bridgestone Ecopia EP 422 Plus.
    GaryD1 likes this.
  6. GaryD1
    302
    138
    Seagrove, NC
    Max psi on outside of tire 44 or 51 psi?
    Merged
    Max psi on outside of tire 44 psi or 51psi? There are two different tires
    Merged
    Bridgestone Ecopia EP 422 Plusas, you know there are two Max psi tires, would also like to know if toyota is using the 44psi or 51 psi?
  7. nategold
    nategold Member
    117
    Arlington, MA
    Where is the spreadsheet?
  8. bisco
    52,239
    it doesn't always come up, for some reason. maybe it needs time to load?
    Merged.
    toyota doesn't use the max. the recommended pressures are on the drivers door jamb plate. please let us know what it says, and measure your tyres cold, for comparison.
    #8 bisco, Jan 30, 2016
  9. Mendel Leisk
    41,791
    There's apparently two distinct Bridgestone Ecopia EP422 Plus: with different max sidewall, also some other variations, maybe wear index. The tread pattern is different in 195/65R15: one version has 3 wide spaced grooves, the other 4, more tightly space. Someone here even got two of each, and raised a fuss with the shop to get all the same.
    I believe the two different kinds are manufactured in different countries. All of this seems somewhat cavalier attitude on Bridgestone's part, doesn't inspire confidence.
    krousdb and GaryD1 like this.
  10. vince22
    205
    249
    califorinia
    2016 Toyota Prius Tire Pressure guidelines for 15" and 17" tires taken from my local dealership,there were all Bridgestone Ecopia EP422 tires on them.
    Two Eco
    Two Eco Factory inflated for 36PSI ( front & rear)
    Bridgestone Ecopia EP422 (3 grove lines)
    Max load
    #10 vince22, Jan 31, 2016
  11. GaryD1
    302
    138
    Seagrove, NC
    [​IMG]deleted
    #11 GaryD1, Jan 31, 2016
  12. vince22
    205
    249
    califorinia
    updated...check above.
    GaryD1 likes this.
  13. GaryD1
    302
    138
    Seagrove, NC
    thanks vince22 for the good clear pic or the Max pressure, was wandering if they were using the 44 max pressure tires on the two eco also, think you just own the two. I know there are a couple on here that own the two eco already. My thinking was if Totota was inflating the front tires little more on the two eco, they might be using the higher pressure (51 psi) on EP422 tires. Maybe some of the other owners will chime in on the subject. Bisco stated that one owner got their Prius and the car had two tires of each, not matching tires. It pays to look, some people never do.
    ssswilki likes this.
  14. vince22
    205
    249
    califorinia
    all my tires are equally the same brand and 36psi all around.
    GaryD1 likes this.
  15. Mendel Leisk
    41,791
    @vince22 Man, they slicked those tires within an inch of their lives.
  16. bisco
    52,239
    this tyre thing is going to be an mpg issue as these cars get older and owners have no clue when they replace tyres.
    GaryD1 likes this.
  17. vince22
    205
    249
    califorinia
    GaryD1,
    I hope this zoom in photo will clear up your mind that i do indeed have Prius Two Eco model.....
  18. GaryD1
    302
    138
    Seagrove, NC
    Yes the picture does indeed clear it up but your personal details on the left just describes you owning a (two)
    #18 GaryD1, Feb 1, 2016
  19. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    @Danny seems to have left out a 'Two Eco' option from the drop down menu to select from.
  20. chinna
    chinna Member
    162
    44
    Bellevue, WA USA
    Prius 4, I test drove has Bridgestone Ecopia EP422 plus, 15 inch, added to the table.
