AC Compressor Problems
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius242, Jan 31, 2016.
  1. Prius242
    Prius242 New Member
    Bahamas
    My 2010 Prius ac compressor isn't working. It is not turning on. Any thoughts?
  2. Patrick Wong
    18,200
    6,471
    Probably the system has a small leak, the refrigerant leaked out, and the AC low pressure switch has activated so that the compressor will not turn on.
  3. BZzap!
    BZzap! Senior Member
    1,607
    877
    You might want to start by checking the fuse. Then go from there.
