  1. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
    Mine locks by itself too but not all the time. It's weird
  2. andino
    andino Senior Member
    746
    550
    San Jose, CA
    It will lock by itself if you don't open or open and close your door within a few seconds. Any longer, and they'll remain unlocked.
    granTORRESmo and Xterra72 like this.
  3. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    Mine does that. I didn't know it either until it happened. Another nice feature!!
  4. Dealeo
    Dealeo Junior Member
    34
    82
    California Bay Area
    Did the H11 to H9 lowbeam bulb conversion. Followed the advice of the You Tubers.. Got a $36 dremel and it took about 10 min per bulb. Anyway it's almost dark and I have a 50 mile drive ahead of me. I'll post my results when I get home....
  5. granTORRESmo
    237
    648
    Norcal
    Uploaded a video of my prii 3 wheeling:D
  6. Starbrand
    Starbrand Senior Member
    493
    1,502
    Westmont, IL
    thats some "dukes of hazard-type" of hang-time you got there.
  7. Dealeo
    34
    82
    California Bay Area
    Well the H9 bulbs give me a whiter light... A brighter light and more range in all directions. Def feels safer to not be out driving my stock headlights at 65 mph.
    Below is a before and after it doesn't really to justice to the increased range though. Top picture is the H9 bulbs. Yes I have a shadow arm on my right headlight reflector from not getting a bulb securely in the socket last month
    Picture taken out my sunroof not from drivers eye view
  8. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    That shadow is weird, looks like a ground wire shadow from improper type of H11 HID bulbs. It would be interesting to see what's causing the shadow.
  9. Dealeo
    34
    82
    California Bay Area
    The first time I changed my bulbs I drove home and noticed my right light was not very bright. When I got home the bulb was not secured in the socket and I smelled melting plastic. I have tried three different bulbs and the same shadow appears with each. I must have melted some plastic onto the reflector surface inside the headlight housing.
  10. kenichols29
    kenichols29 Active Member
    250
    109
    Mckinney, Texas
    I claybared mine today and then applied a 12 month sealent.
  11. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    KLASSE?
  12. kenichols29
    250
    109
    Mckinney, Texas
    Mothers clay bar kit and turtle wax ice 12 month sealent.
  13. Burna J
    1,064
    3,334
    53
    Long Beach, CA.
    Here's that pic of the weather stripping I used. You'll be able to make a nice circle around the 5 studs and the round hole for the rear brake light wire. Plus I duck tape up the holes were the 2 plastic clips use to snapped into.
  14. xliderider
    7,869
    3,116
    Honolulu, HI
    Duck tape for a duck tail spoiler? ;)
    PriiPrii, Burna J and Accordlayingkit like this.
  15. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
  16. ItZGr8t!
    ItZGr8t! Active Member
    75
    284
    IE
    A teaser for now Can anybody quess? 2wks so far & I'm not even halfway there
  17. Xterra72
    Xterra72 Senior Member
    1,406
    1,658
    Baking, painting, and upgrading your headlights to HIds or leds:D
    ItZGr8t! and apt5020 like this.
  18. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Painting your head light trim?
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    I see a Shroud in the high beam
    iPhone ?
    Dylan Doxey, bonchang and Burna J like this.
  20. Mike101
    Mike101 Junior Member
    31
    60
    Richmond, VA
    Sitting on my floor naked, waiting for new tires...
