CDs getting jammed in CD player for 2010 Prius
Discussion in 'Gen 3 Prius Audio and Electronics' started by Elsie, Feb 1, 2016.
  1. Elsie
    Elsie Junior Member
    I had 3 CDs stuck in my CD player last month. To no avail when I pressed eject, they never ejected nor would they play anymore. Eventually after some noise and clicking sounds the message "cd error" would appear every time I started my car. I made an appointment with the toyota dealership to remove them. After waiting 3 or more hours I was told it would cost me approximately 2,000.00 to fix the problem. I said no thanks. After asking around my town, I found a guy who worked at an auto supply store who thought he could fix my problem. When I brought my car in he said my car was very fancy. It has the navigation package in it. He couldn't fix it. I'm desperate now and find someone else who is an expert in installing stereos, speakers, etc. in vehicles, who agrees to fix my car. He thinks he can fix it even though he hasn't installed things in toyotas before. He suggests unhooking the battery from the car for 10 minutes then rebooking it up and pressing the eject button. Well he did but no need to press the eject button. After the car rebooted, The CD player played all 3 CDs then when I pressed eject, they all came out. Charge $10.00. Can you believe that's all it took?
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Strange as it may sound, you are not the first person to report something like this. Best of luck to you.
  3. Mendel Leisk
    41,400
    Maybe draw this to the attention of Corporate Toyota, they're getting bad press from that dealership.
  4. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    AND these CDs were original, not ones with adhesive labels on them?
  5. bisco
    51,895
    that's what i always recommend, but this might be the first time it's worked.
  6. cyberpriusII
    1,155
    1,768
    Mars Hotel
